Oct 18, 2004 14:20:04 GMT
How about :- Mini based 4 wheel drive Austin Ant, you can't get much more obscure official variant, although not many were made. S
Cheers S
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Oct 18, 2004 15:57:21 GMT
That's true actually!!
I think I meant not common when new as the saloon was the bigger seller. Then they all rusted away leaving only the cab and coupe. So it is the otherway round now. Not too keen on the saloon tho'. Like the coupe but the cab is a bit of a cliche now!
This space available to rent. Reach literally dozens of people. Cheap rates!
Oct 18, 2004 16:26:02 GMT
Zagato Zimp
BS Nymph Singer Chamois Coupe Series 3 Landy
Oct 18, 2004 16:28:27 GMT
Pics from the Imp clubs website.
Last Edit: Oct 18, 2004 16:29:42 GMT by ImpJimbo
Oct 18, 2004 17:39:14 GMT
Now that is rare, it was designed for Rootes by Zagato, who planned to make it as a kind of upmarket coupe model of the Imp, in the same way as the later Stiletto that made it to production, but Chrysler (they had a 50% share in Rootes even at that time before they owned it totally) made them stop the project. The same goes for the Asp, which was originally designed to be a sportscar version of the Imp, similar to the Clan Crusader only actually made at Linwood and sold at Rootes dealers, but again it got canned.
"He's not the messiah, he's a very naughty boy!"
Oct 18, 2004 18:38:58 GMT
Before the Zimp, Zagato was working on a Mini based coupe which never made it passed the prototype stage called the BMC Mini Cat.
Last Edit: Oct 18, 2004 18:40:20 GMT by Ministrone
Oct 18, 2004 18:42:14 GMT
Chrysler didnt really like the Imp. So they set about killing it off. The Nymph was going to be the Rootes Mini Moke but thanks to Chrysler it ended up as a kit car.
Oct 18, 2004 19:35:10 GMT
Anglia 105e Standard. Spot the differences from a normal one? This one belongs to my Uncle btw.
Oct 18, 2004 19:41:08 GMT
Well apart from the obvious: The half-width painted grille!
I think I'm right in saying that these were proper poverty-spec jobs with very basic trim (e.g. no heater) and (I think) even less power than the more common 105's and 123's variants.
Oct 18, 2004 19:46:54 GMT
Austin Allegro Equipe a hit with the ladies!!
Oct 18, 2004 19:47:30 GMT
Yeah your right Nick, you'll also notice that theres hardly any chrome on the body (painted light surrounds etc). Standards run the 997cc engine while most 105e's run the 1200cc engine, having said that my Uncles also ran the 1200 for a time while he rebuilt the 997cc, pretty sure its back to standard spec (no pun intended) now though.
Oct 18, 2004 22:50:32 GMT
Austin Allegro Equipe a hit with the ladies!! i had one of those once
SkoCan
Quando omni flunkus, mortati
Oct 18, 2004 22:53:36 GMT
Hmmm...hood ornament
Oct 19, 2004 11:12:50 GMT
As to why it's rare, it's the halfway point between a Frogeye, and a conventional Spridget (Sprite / Midget) as it has the later front and rear, but the Frogeye centre section (including sidescreens, interior etc), wheels, mechanicals and rear suspension (1/4 elliptic with radius arms rather than 1/2 elliptic springs). Not many have survived, as they were much more basic than the later versions, but without the distinctive styling of the Frogeye, both of which are far more commonplace now. Note the uninterrupted wing line, due to not having wind-up windows
