Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
So. They took it out for a pre session test and thought that it was a bit flat but maybe not worth even doing. Stuck her on the rollers (was told when I bought her that she had nearly 100 BHP at the wheels) - 55 BHP >: That sounded a bit low and it certainly doesn't drive like 55 BHP Anyway, four chokes, main jets, etc etc later 80 BHP ;D That's quite a jump, even if the RR is reading v.low. The mechanic took it out for a test drive and described it as now a complete animal. Which bodes well for sat 11th at Combe
This space available to rent. Reach literally dozens of people. Cheap rates!
my mates 2.0 mk1 golf only had 76 on the rollers and that is a complete animal. good work on the tune up tho.
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Thats quite an impressive gain and goes to show the benifits of a well set up engine. What car are we talking about here, is it your 104, thats gonna be a real animal with nearly 90 bhp. It must wiegh the same as a packet of fags.
Shortcut
Indeed. I'm not convinced about the readout as the standard output for an older (1124cc) ZS was 55 Bhp and I have owned several standard 1360cc ZS's which were all way slower than this one before the tune up. I guess the important figure would be the percentage gain as both power runs would be on the same RR I wonder how they have to be calibrated (like shop scales have to be accurate by law)?
The standard output of 55bhp would be at the flywheel (and many manufacturers' figures are somewhat optimistic, and are often only achieved by disconnecting ALL ancillaries, including waterpump etc) so your 55bhp at the wheels would be not only a considerable gain (as before transmission losses) but could also a much more 'honest' figure, so the rolling road could easily be accurate.
Last Edit: Jun 3, 2005 18:28:43 GMT by Paul H
Which rolling road did you use?
BS Nymph Singer Chamois Coupe Series 3 Landy
Shortcut
Even so the standard figure for a 1360cc ZS is 70 BHP! Mind you that would equate to only a 15 BHP loss through the transmission and I guess that a set of twin 40's set up totally wrong could actually result in less power being generated. So 80 on the rollers would be around 100 at the flywheel, which is maybe not so bad for a 1300 engine.
not bad at all id say ;D my 1700 flat 4 with 40s, lecky ignition and a decent exhaust puts out 60 at the wheels. not impressive on paper, but I'm sure the owners of some powerful cars that ive embarrased could make it sound amazing ;D your 80hp will cause a lot of red faces. ;D ;D ;D
racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
just out of interest what did it cost to have your car set up? its gonna scare and emabarrass a lot of very expensive cars
it cost me £100, don't really know if thats good or bad. he had it on the rollers for almost 2 1/2 hours getting it set up right. i was pretty pleased with the results. ;D
Don't get too worried about Power figures the important thing is the torque readings and how it feels when driving, now you've maximized what you have and it's running better as well so it should last longer to. The best result from a rolling road is a fat grin next time you drive it
£100.00 for 2 1/2 hours sounds about right if you're happy with the results...It's the experiance your'e paying for. Any monkey can buy a rolling road now!
Sounds impressive - likes been said as long as it feels good, probably is
the place i went to, mcdonald racing in co.durham, has been race prepping and racing morgans since the 60s, and is a family run business. they were recomended to me by a guy i know who competes in the hotrod gazette drag racing championship. my torque figure was 90 lb/ft at the wheels ;D
it cost me £100, don't really know if thats good or bad. he had it on the rollers for almost 2 1/2 hours getting it set up right. i was pretty pleased with the results. ;D Seems quite reasonable that price. Good result from it aswell which is even more important Which rolling road did you go to?? I've used SpamSpeed before just north of Bristol & they're a good bunch of chaps there.
Shortcut
it cost me £100, don't really know if thats good or bad. he had it on the rollers for almost 2 1/2 hours getting it set up right. i was pretty pleased with the results. ;D Seems quite reasonable that price. Good result from it aswell which is even more important Which rolling road did you go to?? I've used SpamSpeed before just north of Bristol & they're a good bunch of chaps there. Was a place called Pitstop in Carterton just outside Witney, Oxfordshire. Motoersport specialists, mainly mini's but they looked after my friends Samba rally car for years. cost £285 but most of that was parts as I had 4 choles, 2 sets of mains... well 2 sets over everythings actually as the carbs were sooo wrong! Still probably the cheapest way to get extra bhp though!
Last Edit: Jun 4, 2005 15:07:52 GMT by Shortcut
Just outside Witneys handy for me. I know a few guys who need a rolling road and they will be pleased too have one so close.
Shortcut
Just outside Witneys handy for me. I know a few guys who need a rolling road and they will be pleased too have one so close. So, where ar eyou Jimbo! Didn't think there were any RR guys in these thar parts (Cirencester)
I'm near Banbury Oxon.
