55 standardDeleted
@Deleted
Had a go at making a side exit for it today......
Not realy happy with how it turned out..
The floor is nearly in line with the bottoms of the sills. So doesnt give me much room.. Meaning it comes out at the rear arch at an angle I'm not HUGELY happy with. And closer to the floor than id like...
I'm going to have to cut and turn it very slightly. And mount it with some very solid rubber to prevent it slapping the floor...
Pics when done..
But it sounds better ;D
55 standardDeleted
@Deleted
Hmmmm not sure on this.... Spitfire steering wheel... Cant stand wheels that are out of place in classics.. But not sure if this can get away with being the right era for the standard (assuming this was a factory racer) Need to paint it obviously. But wanted to find out if the splines were the same.. Which they are ;D Will get better pics when ive got room to open the door properly.. Oh and thats the standards horn push in there... As it fits...
Nice to see this one still going
55 standardDeleted
@Deleted
Nice to see this one still going Got an email to confirm my parts are on there way now too.. Should see some disc brakes in the next weeks ;D A sorted exhaust and some welding done.. And then a proper thorough service and "leak fix" as its properly marking its spot out there... Then I'm gonna enjoy it this summer ;D
55 standardDeleted
@Deleted
Apr 11, 2013 15:39:19 GMT
Well slowly getting there.. All my parts arrived from *canley classics *rimmer bros *some other ebay sellers... Ive now got one alloy caliper bracket bolted up, one disc installed and wheelbearings greased (drivers side) Tommorow ill do the other side and make some progress on rebuilding the calipers ready for it.. Although i now have to wait on the fitting kits as i forgot to order some.. Ill get some pics up
55 standardDeleted
@Deleted
Apr 12, 2013 17:22:19 GMT
Mock up to make sure they fit... Yep... Think thatll work ;D Just gotta rebuild the calipers, And give it all a lick of paint...
55 standardDeleted
@Deleted
Well i went out there yesterday (in the rain) to try and finish the brakes... Turns out i have the wrong hub so now I'm trying to source ONE type 14 hub.. Realy annoying as i was hoping to get it running/ driving and legal to be able to do some shows and the beaulieu autojumble too.. Think thats going to be on hold untill i can source a hub. That said, I guess i can do some other small things like the exhaust, Some tidying and fix some oil leaks... But the car is still imobile so cant get it to anywhere were welding can be started.
Seth
Does that photo show the clearance problem between hub and caliper? I'm pretty sure this has been mentioned in the past on the Club Triumph forum. You'd be fine to tickle a few mm off the rim of the hub with a grinder if that's all it needs.
55 standardDeleted
@Deleted
Apr 15, 2013 12:31:45 GMT
Does that photo show the clearance problem between hub and caliper? I'm pretty sure this has been mentioned in the past on the Club Triumph forum. You'd be fine to tickle a few mm off the rim of the hub with a grinder if that's all it needs. I was considering removing a small amount, Or even getting my engineer neighbour to spin it on a lathe ... But i think its more than a few MM. I'm going to knock the studs out of it and face it against the one that does fit to see how much larger it is. Strange, realy.. My guess is that its a type 12 hub, As I'm assuming those calipers are smaller? Ill try get a proper pic off my phone. I took a few but not sure how they came out.
55 standardDeleted
@Deleted
Apr 15, 2013 12:33:05 GMT
Oh and that photo above is the one that does fit... On the side that doesnt, The caliper hits the hub at its closest point in the above pic.. By probably 25mm... So quite a bit in the grand scheme of things...
55 standardDeleted
@Deleted
Apr 16, 2013 21:05:06 GMT
Phone wont send the pics to the laptop...... And.. I tried to bleed the brakes today.. All went well with no leaks and a nice firm peddle. But...... Both front calipers locked up solid.... Turns out they are pretty fubar.. I pulled the pads out and pumped the pistons out as far as possible. But after a while they jam again.. They are pretty damn rusty even down the piston sides, So definatly need a new set of calipers now.. One step forward and eight back.. But at least these bugs will be ironed out I guess.
Last Edit: Apr 16, 2013 21:05:40 GMT by Deleted
LowStandards
Can I have your wheels ;D
55 standardDeleted
@Deleted
Apr 17, 2013 20:48:41 GMT
Can I have your wheels ;D haha, Nope lol. One needs straigtening anoyingly.. The N/S front isnt great... Sware i saw some for sale recently somewhere... Ill keep an eye out Oh and in good news... After a little spend today, Ive got another hub, And a set of NEW CALIPERS ;D , also got some new pads and fitting kits.... So tommorow should see some proper progress in the way of FINALLY FINISHING THE BRAKES..
55 standardDeleted
@Deleted
It drives again ;D
Only drove it to the garage to empty all the surplus bits from the boot...
But it works...
Runs fine now, Brakes work but need a re-bleed as i did it the one man method first time round..
And i need to fix the exhaust up at the rear since i did the side exit..
So Theres a few things i need to do before driving it any distance realy..
*sump gasket and oil change (well overdue) *fuel filter *welding to the spring hanger (need to remove tank for that) *exhaust *bleed brakes again *temp weld the sill before i get a new pair of sills for it..
55 standardDeleted
@Deleted
Sump gasket done, Oil change and gauze filter in sump all cleaned. Also new oil filter fitted, As the 60's PUROLATOR item seemed a bit past its best Also fitted a new fuel filter in a place where it wont rub on the starter motor Got pics to update with once I download some updates for my phone..
Last Edit: Apr 22, 2013 6:45:12 GMT by Deleted
Kev
Apr 23, 2013 17:21:10 GMT
She sits so well
Sophers
Club RR Member Number: 80
55 standardSophers
@sophers
Club Retro Rides Member 80
Apr 23, 2013 19:29:28 GMT
What a beaut! Great work ;D
55 standardDeleted
@Deleted
Apr 23, 2013 21:29:10 GMT
brilliant
55 standardstealthstylz
@stealthstylz
Club Retro Rides Member 174
Apr 23, 2013 21:37:21 GMT
Looks fantastic.
Apr 23, 2013 22:09:53 GMT
Loving this keep it up 'thumbs up'
