55 standardDeleted
@Deleted
Feb 12, 2013 20:32:06 GMT
Got a lovely parcel from Rimmer Bros today ;D Decided i didnt like the steel rocker cover and horrid little oil cap. So ordered a rocker cover , cap and gasket Its trial fitted here with the old nuts... Will come off again as theres alot of tidying to be done in here first
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
55 standardspeedy88
@speedy88
Club Retro Rides Member 118
Feb 13, 2013 18:45:32 GMT
Good on yer for getting back on your horse and getting some new tools. Look forward to seeing where this project is going
55 standardDeleted
@Deleted
Feb 13, 2013 22:10:10 GMT
Good on yer for getting back on your horse and getting some new tools. Look forward to seeing where this project is going Should have a little progress this weekend if i can. Gotta do a driveshaft boot on the carlton then its time to crack on with this little curse word ;D
`state
Yorkshire and The Humber
Feb 13, 2013 22:47:41 GMT
Nice one on the tools.Ive had my halfords set for years and although ive had to fit new rachet mechs now and then they`ve served me well.You cant go wrong for the money.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
55 standardDeleted
@Deleted
Feb 15, 2013 17:02:40 GMT
Well i found out the reason for the fuel pi**ing everywhere.. 8PSI of fuel pressure!! Ive had tyres with less than that in Seems the pump , Although supposedly right for a early herald (same engine) Wont work on this motor without some serious standing off from the cam That said, I now know the original old pump wasnt at fault. So that will go back on for the time being to get it driveable. At least to and from the garage. Long term itll be going twin carbed with a pressure reg and electric fuel pump.... So not too worried. Still cant get over how it was producing 8PSI
Feb 15, 2013 20:08:42 GMT
Well I found out the reason for the fuel pi**ing everywhere.. 8PSI of fuel pressure!! Ive had tyres with less than that in Seems the pump , Although supposedly right for a early herald (same engine) Wont work on this motor without some serious standing off from the cam That said, I now know the original old pump wasnt at fault. So that will go back on for the time being to get it driveable. At least to and from the garage. Long term itll be going twin carbed with a pressure reg and electric fuel pump.... So not too worried. Still cant get over how it was producing 8PSI d2jw81rkebrcvk.cloudfront.net/assetscdx/Anims/TD%202%20Fuel%20Systems/AU-Fuel%20Systems-Mechanical%20fuel%20pump%20V1.swfSplit linkage in the pump compromised , possibly by the lever being in the incorrect relationship with the cam. The pump design maximum pressure is then overcome by the lever action. Hope this helps
55 standardDeleted
@Deleted
Feb 15, 2013 20:42:57 GMT
Well I found out the reason for the fuel pi**ing everywhere.. 8PSI of fuel pressure!! Ive had tyres with less than that in Seems the pump , Although supposedly right for a early herald (same engine) Wont work on this motor without some serious standing off from the cam That said, I now know the original old pump wasnt at fault. So that will go back on for the time being to get it driveable. At least to and from the garage. Long term itll be going twin carbed with a pressure reg and electric fuel pump.... So not too worried. Still cant get over how it was producing 8PSI d2jw81rkebrcvk.cloudfront.net/assetscdx/Anims/TD%202%20Fuel%20Systems/AU-Fuel%20Systems-Mechanical%20fuel%20pump%20V1.swfSplit linkage in the pump compromised , possibly by the lever being in the incorrect relationship with the cam. The pump design maximum pressure is then overcome by the lever action. Hope this helps Wow cheers for that Ill keep that in mind. Gonna whip the pump off tommorow for a look
Feb 15, 2013 20:43:52 GMT
^ Or the stroke is simply too long - the further it gets pulled, the harder the spring will be pushing the diaphragm and the higher the fuel pressure.
In the Imp service manual it states that to lower fuel pressure you should increase the number of fuel pump gaskets to shim it out.
Last Edit: Feb 15, 2013 20:44:03 GMT by jrevillug
55 standardDeleted
@Deleted
Feb 17, 2013 18:03:45 GMT
^ Or the stroke is simply too long - the further it gets pulled, the harder the spring will be pushing the diaphragm and the higher the fuel pressure. In the Imp service manual it states that to lower fuel pressure you should increase the number of fuel pump gaskets to shim it out. the standard manual says that too. I took the pump off today, turns out that although they are the same while resting. The old pump doesn't "pump" untill alot further into the stroke than the new one. Meaning it would take about 1/4" of spacers to take that into account I refitted the old pump, which took it down to 2psi which is better haha. Only problem now is... The thottle spindle is leaking alot :/
micrat
Building a Kanjo styled Cinquecento :)
Feb 17, 2013 18:05:35 GMT
Really like this little car its a shame about the hurdles that keep cropping up but i imagine it will seem more than worthwhile in the end
55 standardDeleted
@Deleted
Feb 17, 2013 18:29:50 GMT
Really like this little car its a shame about the hurdles that keep cropping up but I imagine it will seem more than worthwhile in the end Hope so. Ive decided I'm going to fit an SU now i think... Had enough of this old POS carb I have a manifold i think i can modify enough to work with it. Its just getting it to run on a totally different carb that might be the issue. ;D
55 standardDeleted
@Deleted
Feb 18, 2013 16:55:43 GMT
Bloody hell. Me and Damien just managed to fit basically a whole Standard 10 in the back of my Carlton estate ;D
I now have all the panels , glass, trim and numerous other small odds and sods from his beige one.
So now hopefully i should be able to make one solid one ;D
Seth
Feb 18, 2013 19:46:37 GMT
That's good news. Later (bigger) Triumph engines have two different sorts of pumps but I thought you'd be OK asking for one for a Standard. It would seem not. I don't think many people are clued up as to which ones fit which engines - well they all 'fit' obviously as the bolts are in the same place but you either get your symptoms or the inverse if the wrong pumps are fitted with/without a spacer.
55 standardDeleted
@Deleted
Feb 18, 2013 20:53:11 GMT
That's good news. Later (bigger) Triumph engines have two different sorts of pumps but I thought you'd be OK asking for one for a Standard. It would seem not. I don't think many people are clued up as to which ones fit which engines - well they all 'fit' obviously as the bolts are in the same place but you either get your symptoms or the inverse if the wrong pumps are fitted with/without a spacer. Well the old pump still seems to do its job, So for now that'll do.. If i have any upsets with that, Ill swap to a hidden electric pump just for piece of mind. As it is, Ive just secured a set of twin carbs and manifold for an early 948 herald too ;D Still blooming love this lil car
LowStandards
I believe I have a pump you can have, its known working as i swapped it on my eight when i was having carb issues
55 standardDeleted
@Deleted
Feb 19, 2013 16:31:09 GMT
I believe I have a pump you can have, its known working as I swapped it on my eight when I was having carb issues Electric? If so then yeah that would be great. the standard one is working ok atm. But might not like twin carbs..
Last Edit: Feb 19, 2013 16:31:28 GMT by Deleted
Feb 19, 2013 18:21:09 GMT
I'd forgotten about the lever arm dampers mounted on the axle. UNSPRING MASS YO! ;D
55 standardDeleted
@Deleted
Feb 19, 2013 20:15:08 GMT
I'd forgotten about the lever arm dampers mounted on the axle. UNSPRING MASS YO! ;D Haha yeah I know, not too good huh. To be fair tho, the shocks don't weigh much ( I have a spare) and the whole axle doesn't seem to.weigh too much.. Maybe 40kg?
Feb 20, 2013 10:16:41 GMT
The whole original axle weighed less than the stripped down mgb axle i had for mine. I'll be over the storage garage in the next few days for the other bits.
1977 datsun 810 180b estate
55 standardDeleted
@Deleted
Feb 20, 2013 18:44:00 GMT
The whole original axle weighed less than the stripped down mgb axle I had for mine. I'll be over the storage garage in the next few days for the other bits. Brilliant, Let me know what you unearth Had a little more progress today... Take one axle Choppy choppy weldy weldy ;D Cant wait to fit it up, Its currently painted and drying along with the leaves..
