I've rediscovered my love for American Racing Salt Flat Specials after seeing this image. I have been wanting them on my Amazon for years but never got around to it. Does anyone know if a similar wheel is made by other companies? I am keeping the Amazon bog stock, possibly a very minor lowering in future, so thinking maybe relatively skinny 16"ers or even 15"ers if I had to, can anyone remind me of the offset and width of stock Amazon wheels? Any suggestions of something that may look even better? I am quite liking their AR-500s as well...
Remade In Australia thereimaginarium.com.au
Cragar Bonneville is a nice version too...
can anyone remind me of the offset and width of stock Amazon wheels? Wheel width is 4J for saloons, 4.5J for estates (contrary to perceived knowledge, the 123GTs did NOT have the 4.5J wheels from factory). Offset is 25mm (probably actually 1" seeing as the car is imperial). However, backspacing is critical on Amazons (from memory, stock backspacing is 3 3/4") - on full lock, the stock wheel / tyre set-up is very close to the front inner wings / ARB. Conversely, they are a '50s design, and were designed to run narrow crossplies, so fitting wider wheels with modern tyres is going to put much higher loads on the suspension and wheel bearings than they were ever expected to be subjected to. E.g. 5.5J needs an offset of 12-15mm, whereas 6J is 6-8mm).
Last Edit: Jun 1, 2012 13:33:10 GMT by Paul H
Love the wheels on the car at the top, and the Mooneyes ones look pretty cool too... The comments on fitment have me wondering about this car though - are these the original steels, banded?
can anyone remind me of the offset and width of stock Amazon wheels? Wheel width is 4J for saloons, 4.5J for estates (contrary to perceived knowledge, the 123GTs did NOT have the 4.5J wheels from factory). Offset is 25mm (probably actually 1" seeing as the car is imperial). However, backspacing is critical on Amazons (from memory, stock backspacing is 3 3/4") - on full lock, the stock wheel / tyre set-up is very close to the front inner wings / ARB. Conversely, they are a '50s design, and were designed to run narrow crossplies, so fitting wider wheels with modern tyres is going to put much higher loads on the suspension and wheel bearings than they were ever expected to be subjected to. E.g. 5.5J needs an offset of 12-15mm, whereas 6J is 6-8mm). Thanks, I understand the loadings and wouldn't be going wide, probably go as narrow as possible, going from a 165 to a 185 or 195 tyre won't be the end of the world for the suspension. You're right about the inner clearance too at the front, mine rub ever so slightly at full lock.
topcat
On my brothers old amazon, he brought these wheels looked ace Hi Craig are those wheels the 5.5" wide wheels available from the usual suppliers?
craig1010cc
Club RR Member Number: 35
Volvo Amazon Rimmagecraig1010cc
@craig1010cc
Club Retro Rides Member 35
That rings a bell, it was from a specialist that he brought the inner wing repair panels (for me to weld in for him ) from
ooh, those are quite nice, a lot nicer than most variants I've been able to find. I love that these rims, with the correct sizing, could look like a factory fitment (non-polished ones) with the slots and fairly low-key feel
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
Is the first pic a pshop as it does seem very low for a `Zon. If it isn`t then I would like mine to have the same stance !
More to the point, is the car in the top photo for sale??? That is f*okin lush, even the missus approves!!!!
Looked at it again, does look like a photo shop i think. Looks too perfect. Great idea to to mix those wheels with that car though. Looks soooo good!!
I assumed it was genuine and airbagged, similar to that amazing wagon from a few years ago
mercmad
The white has reveresed rims. We used to do that a lot when we kids. mostly on on Mercury rims of the late 40's The inside was sweet looking and sloped to the center,so we would cut the center out, get it chromed and weld it back in backwards . That is what appears to have been done to the volvo's rims as i can see the safety edge crease.
Jun 10, 2012 10:50:16 GMT
Image do some similar i think, or at least they used to
Jun 10, 2012 12:09:50 GMT
Haven't heard of them before, nothing similar but they do do some nice rims
Jun 10, 2012 12:33:19 GMT
Definitely a photoshop:
