Still plodding away, LOL!
Carrying on from last time, I treated the rust behind the radiator and blasted it with paint...
The 'frunk' was looking a bit battle worn...
...so it got a splash too...
Back to the headlights. I replaced the wiring and diodes on the motors...
The paint was very thick but flaky. Rather than use the 'scratch it off with a screwdriver method' I took them to work and attacked them with a DA sander...
Then everything was painted...
I decided to replace the manky old sealed beam units with state of the art HID units and clear lenses (ebay, same as Mazda MX5!). I forgot to take pics and I'm still trying to sort out the wiring...
But I've managed to stick the headlamps units together, what do you think?
The guy I bought the lamps off threw in a few LED sidelight bulbs, I wont be needing them as I have something lined up for that so I stuck one in the fibre optic dash thingy. As I mentioned before, my car has fibre optics in the dash (years before BMW and Merc started using them!) to light up all the switches. They run off a puny 501 bulb so the LED bulb should make a big difference...
Another worthwhile ebay purchase was some door seals. The seals run round one door frame, along the roof at the back then round the other frame. There is a guy on ebay selling them for £30 a side or you can do what I done and buy 7 metres of universal stuff for less than half that...
Fitted perfectly. The edges of the roof have their own seals along the sides which are a bit thicker but an E46 BMW at work donated a door seal that was just right for them! LOL!
