Sept 28, 2006 23:26:13 GMT
Having just offloaded a large wodge of cash in exchange for a lot of new steel being inserted in to the offside rear quarter of my Amazon (to replace the fresh air, grp, wag & rust - will post up some before & after piccies next week), I obviously want to stop it rotting out again. Obvious candidates are Waxoyl, Dinitrol & Bilt Hamber. Are Waxoyl's own brand pumps (as sold in places like Halfords) as tragic as I've heard, or is it actually worth getting one? I'm not needing to do much - just inside & underneath the arch, & inside the boot / rear quarter (behind the trim panel). Would an aerosol rustproofer be ok instead, or are they not worth bothering with? Any recommendations / tips etc, especially regarding how to apply without a spray gun (as I don't have one) would be much appreciated! Cheers
mrj
Sept 29, 2006 4:40:19 GMT
i have posted the same question a couple of weeks ago and i tried waxoyl last week. I must say, the pump works fine, but you have to heat the wax properly up..... the only problem i had, was the small white hose (don't know the english word) which you can use for the inside of the sills for example ; i could use it once, but then never again... i think i have to put it into boiling water to get rid of all the wax....
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
slater
Club RR Member Number: 78
Rustproofingslater
@slater
Club Retro Rides Member 78
Sept 29, 2006 5:43:16 GMT
Been very impressed with Dinitrol lately, You can get that in aerosols and witha extension to get in the sills so I'd reccomend you give that a try.
The only reason i use waxoyl is A. its damn cheap so you can use loads and litraly fill up places that dirt would collect with wax. and B. It comes in clear where as dinitrol comes in light brown and black.
For the metro I'm using dinitrol penitrative/cavity wax in in the cavitys and on seams and then blasting over the top with waxyol. Never used Bilt Hamber stuff tho so maybe thats better.
Sept 29, 2006 9:38:53 GMT
Many thanks chaps Heating up waxoyl is sadly out of the question, as it would be guaranteed to make me homeless Looks like an Dinitrol aerosol is the way forward. I've also noticed that the evil machine has decided to leak antifreeze out through the driver's side sill drains, so that will need an appropriate treatment ASAP!
qwerty
Club RR Member Number: 52
Rustproofingqwerty
@qwerty
Club Retro Rides Member 52
Sept 29, 2006 9:39:52 GMT
Have you not got a camping stove or similar??
RustproofingBenzBoy
@benzboy
Sept 29, 2006 9:54:24 GMT
I've used that Waxoyl spraying gizmo before, and it works pretty well once it's going. I didn't heat the canister, but used a bit of white spirit in it instead (it suggested that on the tin as well as heating) - that worked just as well. You could use an electric heat gun to gently warm it up too. Like mrj, I found the little plastic pipe blocked up quite easily too.
RustproofingDarrenW
@darrenw
Club Retro Rides Member 74
Sept 29, 2006 10:00:44 GMT
Many thanks chaps Heating up waxoyl is sadly out of the question, as it would be guaranteed to make me homeless Whenever I do it, I fill a bucket full of boiling water from the kettle and leave the can in it whilst I spray. Just keep the water topped up with hot from the kettle
Sept 29, 2006 10:06:34 GMT
Many thanks chaps Heating up waxoyl is sadly out of the question, as it would be guaranteed to make me homeless Whenever I do it, I fill a bucket full of boiling water from the kettle and leave the can in it whilst I spray. Just keep the water topped up with hot from the kettle Thats how I always used to use it as well. White spirit is the best for cleaning out the sprayers. Wash it with it and spray white spirit with it gets it pretty clean.
Sept 29, 2006 10:10:26 GMT
Good tip Darren, I grabbed the aerosol Waxoyl as a quick preventative, no idea how my mini treatment is going, rust stresses me. It was going ok at first till the fugging can spat the straw out down the B pillar never to be seen again! Watching and learning
RustproofingDarrenW
@darrenw
Sept 29, 2006 10:14:27 GMT
I've got to do our Mini 30 and the Golf again soon, next couple of weeks... I'll probably use an old spray gun with our compressor to be honest but it gets EVERYWHERE ;D Good job I actually LIKE the smell ;D Not so good for in the sills and stuff though, I'll use the spray thing that comes with it so the bucket of boiling water tip will come in handy
Sept 29, 2006 11:04:51 GMT
Good ideas guys - much appreciated! I was thinking of putting it in a large saucepan of water on the hob..... I can't do anything until next weekend at the earliest anyway, so will do some more research on the actual products. Another quick question - the trim strip hasn't been put back on the rear wing as the old wire clips disintegrated. I have ordered some new ones, but I'm imagining that the holes need plugging in some way too. Volvo used what looks like grey blu-tack, but would Dum-Dum be basically the same thing (can't remember as it's such a long time since I last used it)? or should I use something else? Many thanks everyone, & please keep posting up the rustproofing tips / pitfalls & experiences - I'm a complete novice on this topic
bstardchild
Club RR Member Number: 71
Rustproofingbstardchild
@bstardchild
Club Retro Rides Member 71
Sept 29, 2006 11:49:42 GMT
I've always used waxoil - in various formats and like above big bucket of hot water to get some heat into the stuff has always served me well. It's mucky stuff and in hot weather ooozes out of various places but thats probably cos I put too much in!!! I only use waxoil in cavities never on exposed metal like arches and body shells for that I use the paint on underseal with a high waxoil content that goes rubbery when dry but doesn't crack or peel. If it's external vissible surfaces I use the spray stonechip guard that can be painted over (but rarely ever is )
Sept 29, 2006 12:21:29 GMT
anyone know what they do in bodyshops nowadays for reinstating the factory rust protection? Modern cars are so well rustproofed I often wonder if us lot can take advantage of more modern techniques/materials. VW, Mercedes etc must have their own 'brews' of underseals, cavity wax, seam sealants etc which their dealers have to use during crash repairs etc.
Sept 29, 2006 12:31:54 GMT
I'm about to start sorting this over the weekend.
I have the underside of my car stripped. I was planning on wire wheeling any of the krusty parts of metal and the applying a heavy dose of the black stone chip to the whole of the underside of the car.
then after that just use Waxoil for the chassi rails of the car, and any sections that might require it?? I don't want the underside of the car to be a sloppy mesh though, I want it clean and not messy hence stone chip paint stuff as its not a daily drive car so will not see the hrashest of weather.
can anyone tell me if this is a good course of action to take?? Or any other suggestions??
Seth
Sept 29, 2006 12:49:20 GMT
I've had success in the past with one of those WAxoyl sprayers but hate the mess it produces but then I got it second hand and it;s been a curse word to try and clean out properly. I've since bought one of the manual hand pump versions, like a pistol grip spray gun, and that ahs worked pretty well. It might be a little more work but I actually found it quite confortable to use adn more easily controlled.
slater
Rustproofingslater
@slater
Sept 29, 2006 16:34:35 GMT
If I'm back to clean metal I use that hammerite stone chip on the bottom/arches and then waxyol over it. Cant stand 'underseal' once you have had to get it off a few times it gets tedious.
mrj
Sept 29, 2006 16:53:25 GMT
anyone know what they do in bodyshops nowadays for reinstating the factory rust protection? Modern cars are so well rustproofed I often wonder if us lot can take advantage of more modern techniques/materials. VW, Mercedes etc must have their own 'brews' of underseals, cavity wax, seam sealants etc which their dealers have to use during crash repairs etc. most of the modern cars have zink plated body sheets; but, in a time where shareholder value is more important than good quality, the cars are getting worse. I am working at a dealership including a body shop, and you get grey hair when you see 3 to 4 year old cars rusting.... the guys in the body shop shake their heads and promise a lot of MOT welding in the next couple of years.... just an example: compare the Mk2 golf with the Mk3 : i have one here from 1986 (average condition), no rust... but i have seen a lot of Mk3 Golfs already going with chassis rails rusting away.... not to mention the 20 year old Mk2 Scirocco, one of the highest build quality available ever...
Seth - having seen both of waxoyl's own brand pumps, I agree that the hand one looks much better! I've been doing some more research and aside from Waxoyl (easily available locally to me) the other obvious candidates seems to be these: www.bilthamber.com/hydrate80.html (rust converter) www.bilthamber.com/dynaxs50.html (rust inhibitor & cavity wax) Although I can find some info on Dintrol, it all seems to be about which ones are for sale, rather than actually being useful data on how or where they shoudl be used..... Can anyone recommend any specific Dinitrol products, and where they should be used? Waxoyl has the advantage of being cheaper & more easily available than the others, as well as having the two different pumps / applicators . However, I'm not sure about it's ability to penetrate seams (eg wheel arch lips), which is where the Dynax looks ideal. Also Dynax can displace water - does Waxoyl do the same? Their website has hardly any information!!! Basically, I want to fill the (new) wheel arch seam & then spray inside where the welding has been done. Also, once the heater valve has been replaced, I want to inject the driver's side sill. Obviously I will also rustproof other areas too, but these are the priorities. There are also a few other areas that I want to treat, but which are already rusted (both surface & in seams) - this poses a few problems as soon I want to have those areas cut out & welded in the hopefully not too distant future but anti rust stuff is flammable A rust converter would be ideal but almost all require washing down afterwards, which is totally impractical for what I have in mind. Does anyone have any recommendations? However what products or how I use them is also partly dependant on where I end up doing this - out in the street is probably not the best place for using a proper sprayer, but I think that aerosols would be fine as they are more discreet as well as hopefully less messy ;D
Cheers Mr B! Their aerosol rust converter looks like just what I'm after
