iant
May 11, 2013 16:08:34 GMT
I've spent several enjoyable hours (not all at one sitting!) reading through your whole thread and have to say that the work you are putting into this car is nothing short of incredible. Talk about dedication!
Thanks for sharing, it has given me much pleasure and I wish you all the very best in your continued efforts!
The aircon gas will escape at the hint of a leak. I have a newer jag and I have to have the aircon refilled every 3-4 years. To make yours work you would need to replace all the o rings, dessicator and expansion valve if fitted. oh, and pull a vaccuum on the system and check after 24 hours.
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
foxy99
Thank very much iant. Posting all this up takes time but makes the journey a bit less lonely. Dedication it is but I still wonder how doing something like this takes so long. I just put my blinkers on and try to think of nothing else and jut keep at it. It's a bit extreme but I can't see how you would finish a project otherwise. It does seem like there are so many that run out of steam and after the distance I've came I have to finish it. I'm tempted to crack open the main pipe maybachman and see what happens
May 13, 2013 16:24:17 GMT
This is actually a thermal voltage regulator, not a resistor. It contains a bimetallic strip, heated up by a coil of wire wrapped around it, which regulates the output voltage to the instruments at around 10V, else if driven direct from the battery, they would fluctuate as the battery charges and discharges.
foxy99
Thanks Waxoyling Lyrical. I hadn't properly checked the manual/diagram on that part when I was updating the thread but I looked a little closer tonight and coupled with your knowledge it`s shown me why the green wire that seems to hop between all the instruments does so. It will be to regulate the voltage on all of them. item 64 L2 is the bimetalllic thingyits regulating magic travels through green or light green/black wires to the 4 small instruments and the tachojust found out here that my guess (last pic May 11 post)at putting the black earth wire from the warning-lights loom to the spare terminal on the battery gauge is correct
Last Edit: May 15, 2013 3:05:21 GMT by foxy99
May 15, 2013 21:43:43 GMT
No problem, glad to be of some help.
foxy99
Last Edit: May 17, 2013 3:06:19 GMT by foxy99
Mark
This is interesting as I'll be doing the same on the e3 - very interested to see how you get on!
jpsmit
could you try steam on the dents? perhaps from an iron?
May 17, 2013 17:16:57 GMT
when/if you do it again put a thin sheet of wood/ plastic between the material and the clamp!
foxy99
Eh. Perhaps not lol. The hardener seems to have disintegrated its bottle and the 'varnish' is solid. Bet the burnishing cream still works tho. A new kit isn't dear but I could maybe just use varnish.
djay
Fantastic job you are doing on your car. The varnish looks like it could be Shellac based, although it seems a bit of a late model for that to be used. Wiki Shellac for the properties. On the trim pieces try spray gluing the fabric to the foam and double edge tape on the back. Try a hair dryer on the creases, that can make the fabric more malleable.
Last Edit: May 18, 2013 7:46:33 GMT by djay
polo6n1600i
All I need is WD40 & Duck tape!
May 18, 2013 12:59:26 GMT
I have access to a complete engine minus the block! A friend of mine broke up a v12 xj about 8 months ago - he has used the block to make a "topgear" type table. But the interior is in storage and the rest of the mechanical parts maybe available to a good home - i'm up near Perth and the parts are near by - i'll go and do and hunt and see whats there!
2002 Vw Polo 1.9 TDI sport - Daily Diesel 2006 Vw Passat 3.2 v6 estate - family wagon 1990 Rover Montego 1.6 LX - Project 41
foxy99
May 28, 2013 15:32:19 GMT
Hi folks. Just to let you know my PC has been on the blink for over a week so I can't keep the thread up to date just now I've popped into the library on my break from work so not even got time to answer recent posts. Work continues on the VDP however NB. My PC stopped working when I took nthe fans/CPU etc out for cleaning dust away. Now all I have is a blank screen and whirring fans. Appears it is a common problem :/
foxy99
Well, it's been nearly a month and I have still been working on the VDP but I got a 2nd hand PC at the weekend so should be posting again regularly.
I have finally got the curved pipe welded to the OS front/mid silencer and it's pretty much spot on.
I'll post some more pics etc soon
Last Edit: Jun 20, 2013 2:44:22 GMT by foxy99
Jun 19, 2013 10:18:17 GMT
When this was released in 1968 it cos the modern equivalent of nearly £80,000 and cost twice what the XJ6 did!
Superb car this one, its amazing what you can get even nowadays for the money, my next expensive purchase will definitely be a Jag or a Daimler, i can see it coming....
foxy99
Jun 19, 2013 23:02:49 GMT
Last Edit: Jun 20, 2013 9:34:20 GMT by foxy99
I like the cunning plan of making a jig to get the exhaust pipe in the correct orientation. Shame it didnt work.
Great project thread. I have bullied my cousin into reading it to help inspire him to finish his 1960' S-type!
And for a budget press, can you wedge a trolley jack and the bushes to be pressed between two big hard immovable objects? I did this once using a tree, a building and a bottle jack.
foxy99
haha jimspolicev8sdi. I actually tried jacking the bush and arm between the front crossmember the other night hoping the considerable weight of the front of the car would pop it in but it didn't seem to budge.
I must've spent 20 hours or more trying to get them in so I'm not gonna be too hard on myself for giving up on the budget route.
Last Edit: Jun 20, 2013 9:36:33 GMT by foxy99
Jun 20, 2013 12:15:55 GMT
Yeah I'm sure if you get a press you can make real good use of it for the bushes and lots of things.
This thread is a great read and my favourite diary entry so far. On page 3 March 2009 you write...
Friday 20th - 'on way to barn stopped in Village for chips and saw Jillianne L****aw out for fag with mini skirt. really questioned myself on arrival at barn: what the f**k am I doing here.
Brilliant!
