foxy99
lol. I remember that night well. It was a cold, dark Friday and I could have just parked the car up and joined them in the warmth of the pub but, as ever, I forced myself to the barn to work on the dream.
She's put a bit of beef on since 2009 come to think of it, whereas I'm in better shape these days with the walking/cycling to barn and the economy diet I have to save cash.
Jun 21, 2013 14:22:12 GMT
Keep on keeping on Foxy, this'll be on the road some day soon and it'll all be worth it...
Do not forget that you have to smoke cigars whilst driving a Daimler Double-Six (especially a 'VP'), it is actually the law...!!!
***GARAGE CURRENTLY EMPTY***
foxy99
Jun 30, 2013 17:55:12 GMT
Lol. Thanks grifterkidAnyway. Just popping in to let ppl know I haven't thrown in the towel yet. Got this today.... It's the largest breaker bar I've seen and was only £10 (plus £10 p&p). I'm hoping the leverage will be enough to move the stuck engine rather than the 7/8 AF ring spanner that is on the crankshaft just now. Still need to find a 1" drive 7/8AF socket right enough. Or a 3/4" socket and 1" female to 3/4" adaptor. Because of the inertia on the VDP project I have busied myself on another vehicle I have had for 27 years roughly. I've went from the biggest most recently acquired one (the VDP) back to the smallest and longest owned one Honda SS50ZK1-E
Last Edit: Jun 30, 2013 17:57:01 GMT by foxy99
Actually just sat for a few hours and read this from start to end. You’re definitely on the home stretch.
What i really love is the way you reuse and repair as much as you can.
Ive got into the bad habit of replacing stuff because i can because i might as well while everything is off. Which usually ends up costing me three times more than necessary and resulting in the car being off the road for 10 times as long.
Ive been following this for a while and cant wait till its on the road!
foxy99
Thanks AtomicRooster. I do have a bit of a problem psychologically with the drive to repair rather than replace but in some ways that what 'restoration' is all about: hanging onto the past. Actually if I was to live my life over again I'd still be into cars n bikes but instead of starting with a full vehicle I'd find the most stripped out one I could and then there'd be no originality dilemmas. With bikes this is especially true as you can just pick up a frame and build the bike from it. Anyway, to the title of the post. I got a good 7/8 AF socket (deep, six point) and tonight put that and the bad-boy breaker bar on the crankshaft nut and pulled......but it didn't budge. I wasn't too disheartened as I didn't expect it to work really but at least I tried it. I guess next step is to try something other than diesel. Diesel mixed with PlusGas perhaps and once I've given up on that I might as well start taking the engine apart which will be fun but proabably pointless. I'm keeping myself busy working on the SS50 just now which is fun as it's more realistically do-able. large barand good socket but still no movement
Last Edit: Jul 17, 2013 10:12:22 GMT by foxy99
JohnT
Try some heat. Even a Small Propane Torch can help expand the nut enough to break the rust lock on it. Air powered Impact gun does amazing work too.
John T
Fiat 600 60HP, Fiat 850 60HP, 70 Plymouth GTX 500HP
foxy99
Jul 17, 2013 10:11:54 GMT
Thanks JohnT. But it's not the nut that's the problem. The engine is seized
Last Edit: Jul 17, 2013 10:13:47 GMT by foxy99
Jul 17, 2013 11:04:00 GMT
Are you absolutely against taking the head off?
I had an A-Series that sat outside with the head off for five years which i managed to free off using WD40 and by hammering the pistons. (With a piece of wood as not to damage the piston faces)
Might have been wrong, i don't know, but it freed it up and the engine is still going strong.
Jul 17, 2013 11:24:47 GMT
I would use PlusGas neat, rather than mixing it with diesel. Have you tried using the starter motor to crank the engine over? The sudden jolt may free it off.
Alternatively, put the car on the ground, stick it in gear and rock it back and forth.
You could also try a length of scaffolding pole over your breaker bar, for extra leverage.
JohnT
Jul 17, 2013 15:40:02 GMT
I would use PlusGas neat, rather than mixing it with diesel. Have you tried using the starter motor to crank the engine over? The sudden jolt may free it off. Alternatively, put the car on the ground, stick it in gear and rock it back and forth. You could also try a length of scaffolding pole over your breaker bar, for extra leverage. The rockin method is really the bomb; Great idea. If you ever get to the point of engine dis-assembly; which you might want to consider sooner than later, take my experience on a junk block I disassembled for parts. I soaked it for months and used a 12 ton press on the piston top and on the rod. Then I used and impact hammer which peened the top of the piston and made it worse. I ended up using an impact chisel an destroying everything; cracked the block and bent the rod. I think rust could crack a block even before we start removal. This engine was laying around with no sparkplugs and no intake manifold, so it was always filling with water. In your case, I hope it's not as bad.
Last Edit: Jul 17, 2013 15:42:27 GMT by JohnT
John T
foxy99
Hi guys. Thanks for the suggestions but I think the chances of getting the V12 up on a press are slim. I would love to strip it down but I believe the heads can sometimes be almost impossible to get off. Only one way to find out I suppose.... Strange thing is my engine hasn't been outside getting water in it. I put Redex down the bores years ago and it was moving freely less than a year ago so I'm hoping patience, penetrating fluids an the leverage will do the trick. As for the rocking idea. Would that be do-able with an auto? Also the IRS is not on the car just now. I suppose I could hook up the starter but I'd probably strip the teeth on that or the flywheel knowing my luck Time will tell.
JohnT
Hi guys. Thanks for the suggestions but I think the chances of getting the V12 up on a press are slim. I would love to strip it down but I believe the heads can sometimes be almost impossible to get off. Only one way to find out I suppose.... Strange thing is my engine hasn't been outside getting water in it. I put Redex down the bores years ago and it was moving freely less than a year ago so I'm hoping patience, penetrating fluids an the leverage will do the trick. As for the rocking idea. Would that be do-able with an auto? Also the IRS is not on the car just now. I suppose I could hook up the starter but I'd probably strip the teeth on that or the flywheel knowing my luck Time will tell. Oh no An automatic. No way I know of to ROCK with those; plus no rear end. Wouldn't like to be in your shoes and that's why I'm posting to see if I can help. Please understand I didn't mean for you to follow what I did, just wanted to let you know how bad the problem might be. You could break something trying to turn it without knowing what is keeping it locked-up. Might not be rust. Could be something jammed or broken. Try to disassemble things you can get to: timing chains, valves, oil pump or distributor shaft. See if they all rotate. If your running out of patients and can handle risking some damage; try to lock down a long piece of angle iron to the flex plate for more leverage than a small crank nut. Watch this about leverage and maybe relate it to my angle iron idea. It's about transmissions, but what a powerful principle. Let us know what you come up with.
Last Edit: Jul 19, 2013 17:30:29 GMT by JohnT
John T
Paul Y
Jul 19, 2013 12:52:13 GMT
Before launching into a strip down use the magic elixir known as Full Fat Coke, if possible find one with your name on the side for added un sticking properties...
In all seriousness, pour coke down the bores and leave it for a few days, freed off an old Model A engine that had been stood for at least 40 years and after a week started to move, a further week and I could turn it over by hand.
Worth a try.
P.
Jul 19, 2013 15:47:13 GMT
Does it move either way??
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
JohnT
Jul 19, 2013 17:21:36 GMT
Before launching into a strip down use the magic elixir known as Full Fat Coke, if possible find one with your name on the side for added un sticking properties... In all seriousness, pour coke down the bores and leave it for a few days, freed off an old Model A engine that had been stood for at least 40 years and after a week started to move, a further week and I could turn it over by hand. Worth a try. P. I wish Coke would work better for me. I always hear amazing things about it. Even lemon juice or vinegar is Worth a try. Here are some of the sites where I've learned about some new ideas: antique-engines.com/electrol.aspwww.dansmc.com/stuck_engine.htmusers.eastlink.ca/~pspencer/nsaeta/electrolysis.htmlwww.oldengine.org/unfaq/stuck.htmwww.google.com/search?num=50&hl=en&pwst=1&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=repairing+seized+engines&spell=1www.metalwebnews.com/howto/rust/rust.htmlI've soaked many things for months using: Coke, Molasses, Marval Mystery oil, Rust penetrants, WD40, Diesel fuel, ATF and some other combinations like Acetone and Diesel. I would remove one solution before poring in the next. Sometime I would mix them all together. I also work on old chainsaws and kart engines where I can drop the whole thing in a bucket of chemical and leave it for over a year. I did that mostly with Diesel fuel. For automotive engines I take the head off to get better access in filling up the locked up bore. Nothing works in my situations. I'm still learning and always open minded; but I have not had much success with anything but a torch on loosening rusted parts. Heat is Amazing! It's not really just rust but; galvanic corrosion, where everything kind-of melts together. Never tried heating up a cylinder block to get a piston unlocked, but it might work. Not saying that nothing has ever worked; of course getting a rusted nut off is easier with WD40. I get really stuck when I have all the dissimilar metals in a tight fit like a piston in a bore. The alloy piston, steel rings and cast iron block form an amazing environment for galvanic corrosion. All this might be overkill for the situation your in; but thought with more information you can figure out how to get around all this to avoid engine dis-assembly, which I think is your goal; right?
John T
Jul 19, 2013 17:31:56 GMT
I don't know what access is like on these engines but if you can remove the starter you can try turning the flywheel with a screwdriver levering against the ring gear. You can try rocking it both directions like this with a reasonable amount of leverage. I know it sounds stupid but are you sure its not something mechanical locking it up - I can't imagine a year in a dry store would sieze it that tightly. Also beware of snapping the crank pulley bolt if it really is that tight - to be honest i'm surprised it hasn't just undone if you've been trying rocking it both ways?
Paul Y
Jul 19, 2013 19:47:38 GMT
[/quote]I wish Coke would work better for me. I always hear amazing things about it. Even lemon juice or vinegar is Worth a try. Here are some of the sites where I've learned about some new ideas: antique-engines.com/electrol.aspwww.dansmc.com/stuck_engine.htmusers.eastlink.ca/~pspencer/nsaeta/electrolysis.htmlwww.oldengine.org/unfaq/stuck.htmwww.google.com/search?num=50&hl=en&pwst=1&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=repairing+seized+engines&spell=1www.metalwebnews.com/howto/rust/rust.htmlI've soaked many things for months using: Coke, Molasses, Marval Mystery oil, Rust penetrants, WD40, Diesel fuel, ATF and some other combinations like Acetone and Diesel. I would remove one solution before poring in the next. Sometime I would mix them all together. I also work on old chainsaws and kart engines where I can drop the whole thing in a bucket of chemical and leave it for over a year. I did that mostly with Diesel fuel. For automotive engines I take the head off to get better access in filling up the locked up bore. Nothing works in my situations. I'm still learning and always open minded; but I have not had much success with anything but a torch on loosening rusted parts. Heat is Amazing! It's not really just rust but; galvanic corrosion, where everything kind-of melts together. Never tried heating up a cylinder block to get a piston unlocked, but it might work. Not saying that nothing has ever worked; of course getting a rusted nut off is easier with WD40. I get really stuck when I have all the dissimilar metals in a tight fit like a piston in a bore. The alloy piston, steel rings and cast iron block form an amazing environment for galvanic corrosion. All this might be overkill for the situation your in; but thought with more information you can figure out how to get around all this to avoid engine dis-assembly, which I think is your goal; right? [/quote] John, Sometimes things just work and sometimes they just don't. I must admit to being surprised that the coke trick worked but think that it 'could' have been something to do with the age of the components and the differing make up of the metals compared to more modern engines. Interesting links, I am always looking to learn and there is a lot of knowledge out there. P.
foxy99
Wow. Plenty food for thought there guys and no offence taken to any of the comments.
To answer a couple of the points: the nut isn't undoing as it is sort of double bolted to the pulley. I'll find a picture to illustrate what I mean.
I'm also thinking it could be something mechanical but have been under the car and round the engine several times and can't find anything.
Have also tried turning it both ways. Am also worried about putting to much leverage on as I can see the pulley sort of bending...I think.
The starter is off just now and I can see the flywheel so could try levering something on agaisnt it I suppose.
Going back a month or so. Someone mentioned a 2nd hand engine and I wasn't keen as mine is carb not injection. Well, I studied the parts lists and it appears only the very top of the engines differ so theoretically I could put my carbby bits on any XJ12/XJS engine.
Means I could also get the engine bay cleaned and painted nice.
Maybe this time next year it'll all be resolved but once again I really appreciate the input. Thanks
Last Edit: Jul 20, 2013 2:45:16 GMT by foxy99
Rob
atf dextron 3 fluid mixed equal parts with diesel.plugs out, fill to the brim. leave for 2 weeks. see if its gone down and refill. took 6 weekson mine but worked.
jpsmit
Jul 20, 2013 17:47:41 GMT
Hi guys. Thanks for the suggestions but I think the chances of getting the V12 up on a press are slim. I would love to strip it down but I believe the heads can sometimes be almost impossible to get off. Only one way to find out I suppose.... Strange thing is my engine hasn't been outside getting water in it. I put Redex down the bores years ago and it was moving freely less than a year ago so I'm hoping patience, penetrating fluids an the leverage will do the trick. As for the rocking idea. Would that be do-able with an auto? Also the IRS is not on the car just now. I suppose I could hook up the starter but I'd probably strip the teeth on that or the flywheel knowing my luck Time will tell. You have more than once mentioned that the engine moved freely a year ago, and that it has been sitting inside. The more i read, the less i think it is seized but that something else is stuck. Is the transmission stuck? Or stuck in gear? Something binding the flywheel? I just can't help but feel that if you set up a thinking chair next to the car and looked with fresh eyes, you might find the problem is somewhere else.
