tome30
Nov 14, 2011 19:22:01 GMT
I going to be refurbing my wheels as a little winter project. I've seen peolpe use the car as a 'lathe' method for polishing lips, but I've also seen somewhere on here someone who made a power drill/wheel hub combination, which seems safer!! Anyone remember that thread as I can't find it? Sorry for such a bad post. Pic's as penance....
Nov 14, 2011 19:37:19 GMT
Done it loads of times. Works very well and perfectly safe. If FWD you pull the handbrake on and chock the front wheel that's on the ground. Don't do it if you have an LSD - or if you do, have both front wheels off the ground.
I've done it on RWD as well, but this had LSD, so I just jacked the whole back end up, blocked the front wheels and stuck it in gear.
Just take it steady and work your way up through the grades of W&D until you're ready for the autosol/polishing cream treatment.
Foxy
Making pink manly in the north!
Nov 14, 2011 19:39:13 GMT
Its perfectly safe! ;D
I'm the handsome fella with the cheesy white specs or is that the cheesy fella with the handsome white specs?
tome30
Nov 14, 2011 19:44:45 GMT
No axle stands!!!! It's a golf so its front wheel drive. However as it's dark and cold I'd like to see how I could get a similar setup (lower revs) in the shed.
Foxy
Nov 14, 2011 19:47:21 GMT
Thats how we roll oop north, all manly like!
col
wut
Nov 14, 2011 19:48:57 GMT
why didnt someone tell me about this earlier? could have saved so much time.
Last Edit: Nov 14, 2011 19:49:23 GMT by col
Nov 14, 2011 20:20:14 GMT
...However as it's dark and cold I'd like to see how I could get a similar setup (lower revs) in the shed. Wouldn't that involve dying from carbon monoxide poisoning though?
Copey
Nov 14, 2011 20:32:53 GMT
...However as it's dark and cold I'd like to see how I could get a similar setup (lower revs) in the shed. Wouldn't that involve dying from carbon monoxide poisoning though? hose from the exhaust and out a window?
tome30
Nov 14, 2011 20:38:31 GMT
Wouldn't that involve dying from carbon monoxide poisoning though? hose from the exhaust and out a window? No, no, no, the one I saw involved a power drill and a wheel fixed to an old hub, welded up on some kind of stand.
Nov 14, 2011 20:42:25 GMT
like these
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
tome30
Nov 14, 2011 20:49:50 GMT
;DNope like this...
Nov 14, 2011 20:53:51 GMT
And make sure you have a mobile phone handly to call for ambulance if things go wrong and your arm gets ripped off ! I can't believe people are considering doing something so dangerous as using a running car.
Paul H
bortaf
Nov 14, 2011 20:54:33 GMT
Its perfectly safe! ;D That's how i remove the lips off worn drums, reverse em and run the car in gear ;D
R.I.P photobucket
Nov 14, 2011 21:00:29 GMT
I can't believe people are considering doing something so dangerous as using a running car. If the car is properly stabilised/chocked and set-up, what is so dangerous compared to having a mop-head in a drill? It's just a large lathe and, as said, perfectly safe as long as the car is made so that it can't go anywhere. To me, this is far safer than someone angle grinding with thir hoodie drawstrings hanging out (just one example of things I've seen in pics on this very forum)
Nov 14, 2011 21:09:57 GMT
Nov 14, 2011 21:18:46 GMT
And make sure you have a mobile phone handly to call for ambulance if things go wrong and your arm gets ripped off ! I can't believe people are considering doing something so dangerous as using a running car. Paul H Guess you've never done this then? I've used this techniques countless times over the last 20 years + and still have a full compliment of limbs and digits. It's no more dangerous than doing it in a lathe. I some ways it's actually safer than a lathe.
Foxy
Nov 14, 2011 21:21:34 GMT
I've got to admit though, that when I did it, in the newspaper the next day there was a few stories of kittens and nuns suddenly dying!
Seth
Nov 14, 2011 21:21:58 GMT
I some ways it's actually safer than a lathe. You can't leave the chuck key in Handy for refinishing and giving a more authentic look to (fake) Moon discs I found.
tome30
Nov 14, 2011 21:22:46 GMT
The wheel in my detailed diagram is the car wheel, not a polishing wheel. :-D
Nov 14, 2011 21:28:02 GMT
I very much doubt making a rig like that with a drill would provide enough power. Once you start smoothing and polishing it requires a fair bit of torque to keep the rim turning.
