Nov 29, 2011 11:15:37 GMT |
Fantastic fabrication work.  Car looks brilliant too.
qwerty
Club RR Member Number: 52
Nov 29, 2011 15:06:08 GMT |
Lovely looking work and a fantastic car. Look forward to reading more progress.
Nov 29, 2011 21:25:20 GMT |
Thanks Guys much appreciated ;D
Nov 29, 2011 21:37:58 GMT |
Proper job there! I love to see clean, welded ally. You are going to have to move the fuel supply connection on the fuel rail, but that should be nothing to a man of your talents. Be interested to see what connectors you are using too. The Goodridge ones don't have the same male taper as OE fittings.
Sittin' here in a hired tuxedo. Wanna see my bacon torpedo?
Thanks CR yer the fuel rail needs sorting (there is another type that fits the 1.6 so I will try that first) then there's the custom option too. Hopefully the gearbox will arrive this week so I can start fitting things!
Presents arrived today ;D What could this be??  You guessed it - yep omega 3Ltr V6 box. R25 - R28    along with these  Selector  Rear box support bracket  Release mechanism  Let the fun begin!
Man, I just read the whole thing - fair play. That manifold looks great, I hope you explain the amount of work that went into it to everyone that ever sees it! Bookmarked
MaDSeB
Big things in small packages
I'm loving reading this. very impressed with the fabricatio thats goign on, cant wait to see this finished. keep up the good work
Dec 11, 2011 20:32:09 GMT |
Dec 17, 2011 16:35:09 GMT |
yet another nice project James! You still using the engines from Ayrshire? Cheers, Jamie
 1965 Mk1 Mini 1989 Porsche 911 3.2 Carrera Sport 2004 Audi A2 TDi 2007 Lotus Exige S 2011 Mini Cooper SD
sumpcracker
No, realy, I would rather have a modern car, I'm just poor.
Dec 17, 2011 22:44:28 GMT |
As per - top drawer.
Dec 18, 2011 13:02:38 GMT |
Why isn't this flooded with comments? Awesomly cool car, loving the colour, and the wheels look great for what they are. The fabrication is also great, would love to have access to a mill and lathe myself  Bookmarked!
qwerty
Dec 18, 2011 17:10:58 GMT |
That fannymold looks fantastic, as you say very OE. Looking forward to seeing the engine in the bay! Going to be quite a sleeper!
Dec 18, 2011 17:22:34 GMT |
Why isn't this flooded with comments? Well , quite . A great base car to start with , looking great in those last pics and some fabrication work to die for - hats off , keep it coming .
As above. Lovely car with some cracking metal work to boot. Nice to see something other than a C20XE being swapped in too.
Dec 20, 2011 17:08:57 GMT |
Thanks Chaps - I'm trying to put my stamp on it. Hopfully i will make some more progress over the christmas period. It would do me wonders if i could decide what i was going to do about the rear axle!
Dec 20, 2011 22:34:57 GMT |
Lets hope we ALL get some time to get on with our projects! Looking forward to your seasonal update ;D You do have a few choices depending on power output / effort / availability etc 1. Manta A axle with LSD. Just need to find one! Benefits are its an easy known swap. Power capacity may be marginal depending on above. I know some Manta owners running 2.0XE power still use the original (wider) axle without grief! 2. 5-link something else with fabbed brackets, links and body boxes etc. Ford/Atlas (expensive). Volvo (availability? - re-drill hubs) Salsbury (Scimitar/Jag etc) (as above) Again, these have been done before so some parts are off-the-shelf. 3. Mount any of the above by another means such as those discussed in your other thread These will take a lot more time / effort and need more work on the shell. Good luck with your ponderings
Thanks Curryracer i'm still pondering  and I don't want to completely immobilize the car and take the engine out etc until I have a plan of action. I am also considering something a little different however i'm unsure if it will work yet.
