Nov 19, 2011 17:39:55 GMT |
original as plan plutot! good luck!
Nov 19, 2011 21:53:58 GMT |
Nov 19, 2011 22:00:29 GMT |
I like the wheels.
Body looks to be in good shape too .
Be nice to see that engine finally fitted in a Kadett !
Nov 19, 2011 22:28:03 GMT |
Be nice to see that engine finally fitted in a Kadett ! Tell me about it lol!
Nov 20, 2011 20:28:14 GMT |
Evening People, I got out and did 40miles in the car today and it was as good as gold, even the missus didn't mind it. Had a few strange looks in sainsburys car park too!  When i got home i went up the workshop to carry on with the engine mounts. I flipped the O/S mount over to finish we;ding it up   Ive been using MIG but TIG would have made a neater job, unfortunately i don't have access to a TIG welder so that's that   the new mount clears the water pipe fine  Then it was back to the other side, where i welded round the tubing that sits on top of the rubber engine mount  Zap  And started on the triangulation to it - at which point my electric ran out so that was the end of that! Last couple of pics were in the dark    James
Nov 21, 2011 21:57:19 GMT |
Greetings good people! I had a couple of spare hours after work tonight so i got on with the inlet manifold. I started with this  I needed to lower the edge closest in the pic so the plate sat flush with the plenum  So i removed this pesky beast and did some more fettling  Getting there   Turning my attention to the manifold its self i removed this water way as it was in the way  i will address this mess later  With that out of the way i could linish the manifold flat and to the required angle  As so  Allowing the plenum sit like this    Getting fed up of holding it i decided to zip tie it in place so i could take some better pics and a few measurements  I'm happy with the way it is sitting now
Nov 22, 2011 20:08:09 GMT |
Pleasingly more Progress was made this evening  Volvo 4 pots stripped  De greased  Hot washed  And dried  Looking much better and ready for some further cleaning  Then back to the manifold - marked the important areas out   Card board lends a hand  All marked out  on to the mill  Test run  First one done  Then there were 3   stage one complete   Then put a nice chamfered profile on the edges  Stage two complete  It came out ok for a 'by eye effort'  The plate goes here on the manifold  And looks like this inside the plenum  I will probably finish the profile by hand to get them spot on Thanks for looking James
madspikes
Wrong wheel drive!
Nov 22, 2011 22:03:49 GMT |
Looking really good - I really enjoy following some nice engineer!
orangecords
yawner extraordinaire
Nov 22, 2011 23:25:50 GMT |
thats a lovely chariot mate. i had one years ago. kinda miss it
I then wanted to start cleaning the interior as it stinks of wood (the material not the smell of a boner) best quote ever!
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Nov 22, 2011 23:56:46 GMT |
GOTTA LOVE A HOME BUILT ENGINE  reckon the rear wheels would look beter with some spacers ,.
facebook: rodney dean / rd transport
robb
Looking sweet, Man! When i was reading this thread i thought to myself that i saw a similar one in my home town of worthing and someone previously posted that it was bought from worthing. I used to see it driving around Worthing every now and then, If i remember correctly there was either a young asian woman or a faily old asian man. Fairly looked after though!
/\ your correct thats the guy and his daughter i brought it from...small world!
78 Kadett C Saloon - V8 turbo.stealthstylz
@stealthstylz
Club Retro Rides Member 174
Nice fab skills. I can't decide whether I think the rear wheels need spacers or not. Some pics say yes, others no.
Matt
Nov 23, 2011 14:58:59 GMT |
That looks so good that you could turn a Ford man to the darkside ;-)
Nov 23, 2011 16:53:06 GMT |
GOTTA LOVE A HOME BUILT ENGINE  reckon the rear wheels would look beter with some spacers ,. Nice fab skills. I can't decide whether I think the rear wheels need spacers or not. Some pics say yes, others no. Matt I know where you are both coming from here, the new axle will space the wheels out any way so i may not need spacers or have a choice once its fitted. Ideally i would like the rims to be wider with more dish but they will do for now
Nov 23, 2011 16:59:51 GMT |
That looks so good that you could turn a Ford man to the darkside ;-) Now thats a true compliment ;D
Nov 24, 2011 21:52:52 GMT |
Looking forward to more progress on the mounts and installation as I have got most of the bits for a similar (corsa GSi non turbo/ type 9 'box) job. Wont be as nice as yours with all that neat machining and ally work though!
Sittin' here in a hired tuxedo. Wanna see my bacon torpedo?
Nov 26, 2011 18:59:35 GMT |
Thanks Curryracer i would be interested to see what your up to with yours! I've made a small amount of progress with the manifold however i have been working on my 944 today so i haven't had any time for the Kadett  Manifold progress I machined this edge off to help the air flow inside the manifold  Then chopped off the excess Ali from the back plate (annoyingly my plasma needs a new tip so it was a pita to cut up neatly)  And neatened it up a little - nearly ready for welding!
tsp
Nov 27, 2011 20:38:18 GMT |
You are one talented dude  You can build an engine for my mk1 if you like...
what did you use for lowering did you use coilovers or just cut the springs !!!!
DREAMER
