Jul 19, 2006 12:08:26 GMT
I thought you could run banded steels but they had to have been done by a registered place... like Bob Knight (of VW fame) and some Triumph place the name of which escapes me. Bob's are re-rimmed (the centres cut out and then welded into the rim of a wider wheel) which isn't illegal, a good engineer should be able to do it. Banding is illegal...there were too many badly done ones in the past.
Jul 19, 2006 12:38:34 GMT
been running wobbly bolts for donkies on various cars never had a problem i used them to go from a 100 wheel to a 98 pcd any more than this i think you'd be pushing your luck to be honest i have never heard of wobbly steel bolts only for alloys the correct term is PCD corection bolts as opposed to the decidedly dodgy sounding wobbly bolts.
don't be scared of them although they don't suit what you want to do anyway
bstardchild
Club RR Member Number: 71
Jul 19, 2006 12:40:35 GMT
I relly don't get why people are so paranoid about wheels and wheels bolts. The same physics applys to them as it does to any other part on the car! Agreed same physics apply - quite extreme physics if you think about how a car can be potentialy driven........... You have never been overtaken by your own wheel then after one wheel bolt sheared and the load was transfered shared on the remaining oneswhich in turn sheared untill the thing was free to part company with the car Wobble bolts are worse than fitting spacers with the std bolts and thats bad enough!! I just worry that wobble bolts are weaker and are a bodge way of avoiding buying the right wheel
Jul 19, 2006 12:55:02 GMT
as long as all 4 are done up properly there is potentially a 1mm difference in thickness which in all reality is the difference between nipping it up one last time
Jul 19, 2006 12:58:26 GMT
"PCD Correction" bolts ARE dangerous.
the force put on wheel bolts is pretty extreeme at the best of times.
your wheel constantly rotates, and the force on the collars of the bolts it therefore always changing.
If you make the shape a non constant, i.e. offset, you're overstressing these components.
They collar could (and they have done in the past!) snap.
Your wheel is then held in place by a loose stud, this WILL come loose, and something WILL go wrong.
They don't use offset washers for "PCD correction" in industry, it's an aftermarket bodge.
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
Jul 19, 2006 13:01:13 GMT
as long as all 4 are done up properly there is potentially a 1mm difference in thickness which in all reality is the difference between nipping it up one last time you know that harrier that fell out of the sky
Jul 19, 2006 13:05:33 GMT
I don't think they are 'dangerous' as such, of course if crummy cheap ones exist made out of lousy metal, then that is dangerous, but for me as long as the central hole in the wheel centralises the wheel correctly on the hub, I don't see why these offset bolts cannot hold the wheel on adequately.
If the bolt section is 20% less, then OK you need material with a 20% higher yield strength, but thats not impossible.
qwerty
Club RR Member Number: 52
Jul 19, 2006 13:11:58 GMT
Its just I need 4x110PCD which are hard to find but 4x108 aren't
Jul 19, 2006 13:14:29 GMT
Yeah my mazda koop is 4 x 110, its a sod.
qwerty
Jul 19, 2006 13:15:59 GMT
All i want is a set of black 7x13 steels in 4x110 fitment is that SOO much to ask?
bstardchild
Jul 19, 2006 13:16:33 GMT
I don't think they are 'dangerous' as such, of course if crummy cheap ones exist made out of lousy metal, then that is dangerous, but for me as long as the central hole in the wheel centralises the wheel correctly on the hub, I don't see why these offset bolts cannot hold the wheel on adequately. Perfect illustration of what should happen........ but......... what actually happens is (most mail order companies won't even bother to ask any questions just supply you what you ask for) Picture a plastic fantastic saxo with - ET45 wheels corrected by 10mm spacers so that the hub centre is no longer applicable/avaliable as a centre location - PCD 4 x 98 rather than the correct 4 x 100 cos they were cheap of a mate and only slightly kerbed - fastened with "PCD correction bolts" that are probably for std wheels and can't cope with the 10mm spacers as well - No spigot rings and an oversize centre hole (not that it matters anymore cos of the spacers) And the 17yr old muppet hasn't got a torque wrench and has no idea of the importance of doing a few miles and checking all the bolts again and just does em up tight (ish) So perfectly safe for the spotty oik to take your daughter out for a date in it then ;D Does that sound a little far fetched cos round here I see it a lot.....
Jul 19, 2006 13:19:58 GMT
aha! Well theres no accounting for the stupidity of Barries, thats another topic!!
Anyway if my daughter went out with some lad who had a jizzed-up saxo i'd ground her till she was 40.
qwerty
Jul 19, 2006 13:21:15 GMT
*tiny voice* I've got a Saxo *waits for barrage of abuse*
Jul 19, 2006 13:23:47 GMT
Have you barried it up?
Jul 19, 2006 13:24:56 GMT
[pedant]Saxo's are 4x108[/pedant]
bstardchild
Jul 19, 2006 13:25:55 GMT
aha! Well theres no accounting for the stupidity of Barries, thats another topic!! I wasn't making that point although it now looks like I was - what I was trying to make was it's a slippery slope and whilst using one "bodge" might be acceptable you don't know when you say they are OK that there aren't other factors that will make it not OK............. I don't want an argument about the subject either - I'd never recomend their use because of all the other factors Anyway if my daughter went out with some lad who had a jizzed-up saxo i'd ground her till she was 40. LOL - I can believe that too ;D
qwerty
Jul 19, 2006 13:27:36 GMT
NO! Well i've bought a 4" exhaust which I have absloutely no excuse for apart from the fact I need an exhaust to sell it.
bstardchild
Jul 19, 2006 13:28:05 GMT
[pedant]Saxo's are 4x108[/pedant] [notworthy]Thanks - I'll try to remember that [/notworthy]
Jul 19, 2006 13:31:04 GMT
OK well an otherwise-standard spaxo with a 4” exhaust is cast-iron barry, but if you get rid of it quickly and add no further stick-on tat I think you’ll get away with it
qwerty
Jul 19, 2006 13:41:33 GMT
Yeah its blatantly barry. But its been a very Fun quickish car.
