GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
V8 conversion progress.GavinJ
@gavinj
Club Retro Rides Member 209
Jan 28, 2006 16:54:11 GMT
Started stripping the mg down today ready to fit the v8, Tunnel exposed ready for modification, Ready for lift off, Engine out, Empty engine bay, All going well the gearbox and v8 should be in place tomorrow - touch wood everything has come apart easily so far
Nathan
Club RR Member Number: 1
V8 conversion progress.Nathan
@bgtmidget7476
Club Retro Rides Member 1
Jan 28, 2006 19:11:47 GMT
are you not changing the steering rack. looks good whats happening to your old b series
Jan 28, 2006 19:19:46 GMT
cool! is it a standard Rover V8 going in?
Jan 28, 2006 21:32:57 GMT
An old friend of mine in the states has a Ford 302 in his!
Peugeot 307sw - Suzuki SV650S - MX5.
bstardchild
Club RR Member Number: 71
V8 conversion progress.bstardchild
@bstardchild
Club Retro Rides Member 71
^ Looking good
Sorry for the semi threadjack but Are you gonna be putting the B engine up for sale?
Reason I ask is my brother is looking for an engine to rebuild/tune for his BGT over the summer months this year and fit over the winter months at the end of 2006 beginning of 2007
His current engine is running fine (ie doesn't smoke or rattle but is very leggy and a little down on power) but he doesn't want to have the car off the road for ages while he rebuilds the current engine
Plans are
Convert head to unleaded Porting & Webber conversion Mild road cam Decent headers Rebore (maybe 1875 if possible)
Let me know ta
GavinJ
MGB 3.9 v8 Sebring
@gavinj
Jan 29, 2006 18:17:29 GMT
Well to be honest i was going to keep the engine to rebuild as it does have problems.... I had been using the engine regular for trackdays, however when i did my last trackday at Donington in December it starting smoking heavily on the way home So it needs a strip down to see whats gone wrong, suspected piston rings so should be a fairly straight forward rebuild providing it hasn't scored the bores... However, if i change my mind i'll let you know if i plan to sell it Did some more work on the MG today but the progress was a bit slower than i expected but the tunnel is now modified for the lt77 gearbox i will post some pictures later.
GavinJ
MGB 3.9 v8 Sebring
@gavinj
Jan 29, 2006 19:52:02 GMT
Some photo's although some steps are missing as we got a bit carried away and forgot to take pic's Tunnel is cut open from the underneath after the spot welds have been drilled, The front skin of the centre console is then tapped over to allow room for the tunnel to be raised (does not need to be perfect as it will all be hidden by the centre console when its fitted), Then imagine lots of hammering of the tunnel to allow extra clearance (missing pics : once we had got the clearance we wanted. It was then all welded up and you can see the new strips of metal used to join the now higher tunnel, From the top although it was attacked with a hammer again after this pic to raise it even more wilst the metal was hot from the welding as it stretched much easier whilst hot. A picture from the front all welded up and finished, but its a shame on the engine bay pic above you can't see it, but the front of the tunnel originally started off very straight with a double skinned lip and as you can see it now has a curve and is raised. Just needs the welds grinding down and some underseal/paint Should be some more pic's tomorrow....
GavinJ
MGB 3.9 v8 Sebring
@gavinj
Jan 29, 2006 19:59:27 GMT
This is what the shape of the fromt edge of the tunnel was before as demonstrated in paint (the red represents the original shape)
GavinJ
MGB 3.9 v8 Sebring
@gavinj
Feb 18, 2006 15:48:41 GMT
A bit more progress, The v8 after spending a few hours giving it good clean with the help of my dad, This is the second v8 that i bought as i didn't decide to use the first one and this one came with a nice weber carb The tubular manfiolds and you can see the engine mounts that have een fitted, Finally the v8 and box together, Really happy with how well it cleaned up, just can't wait to fit it in now
Feb 18, 2006 17:10:46 GMT
luvverly ;D
Nathan
@bgtmidget7476
Feb 18, 2006 18:30:16 GMT
If you decide to sell the other V8 give me a Shout, thinking of converting my Midget to V8
Feb 18, 2006 20:18:53 GMT
good efforts there gavinj ;D
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Feb 18, 2006 20:31:02 GMT
If you decide to sell the other V8 give me a Shout, thinking of converting my Midget to V8 Are you going to the MG show / spares day at Stoneleigh (just south of Cov) tomorrow? If so, there's loads of Spridget guys (myself included) meeting at the Midget & Sprite Club stand at 1pm
Last Edit: Feb 18, 2006 20:31:38 GMT by Paul H
GavinJ
MGB 3.9 v8 Sebring
@gavinj
Feb 25, 2006 17:04:21 GMT
Finally got the engine in this morning and it went it really well only took about an hour to fit Here's some piccys, The manifolds are very close to the inner wings but this has been the same on every other v8 conversion i've looked at and there is quite a bit of adjustment left on the engine mounts so i'm hoping i can gain a bit more clearance. Just enough clearance for the anti roll bar! I now need to get round this, I'm going to look at getting a smaller filter and there is also a 10mm spacer on the carb that i can remove but i will still need to a bulge of somekind. Things left to do are - modify the gearbox crossmember, connect all the senders, speedo & cooling system, fit rad etc. Sort out the bonnet and then change the diff for something more suitable!
Feb 25, 2006 17:30:15 GMT
Good work and good pics!
Nathan
@bgtmidget7476
Feb 25, 2006 17:32:58 GMT
You could Cut away some of that inner wing, Or what a friend of mine did, and that was to beat it out a bit. Did you change the engine mount rubbers?
Nathan
@bgtmidget7476
Feb 25, 2006 17:35:00 GMT
Ahh curse word Paul H I was supposed to go as well but forgot totally about it (probably due to being out the night before) When is the next one
GavinJ
MGB 3.9 v8 Sebring
@gavinj
Feb 25, 2006 17:38:39 GMT
I've fitted new RV8 engine mounts, with these d/side mount is bigger to give extra clearance for the steering collumn, starter etc. I'm going to see how the mainfolds go before i modify the inner wings but my only concern is that they might knock against the wings under acceleration but i'll find out soon enough!
