Enbloc
Feb 19, 2008 14:17:13 GMT
I've just got these HS8 SU's. I haven't got a clue about SU's, particuly how the linkage works for both the throttle and the choke. Is the choke the plunger set-up on the bottom? Can I use any linkage or does it have to be specific for HS8's? Is the two different linkages. One for throttle, one for choke? Pictures??
Seth
Feb 19, 2008 14:44:25 GMT
Its Obviously SU season! These for your A I presume? Difficult to describe the linkages without showing you.
The throttle linkage is a rod that runs between the ends of the two throttle spindles. An arm on each end of this locates in a plate on the end of the spindle to rotate them - can just see this plate I think on the carb on the right of your photo. Might be missing from the left carb?
The choke mechanism does two things. The cable is attached to and pulls up on a cam. For the initial stage of the cams movement it pushes against an adjustable screw that is part of the throttle linkage, opening the throttle slightly. Then as the choke is pulled out further it operates the lever that pushes the jet (at the base of the carb) away from the carb, richening the mixture. Again the carbs are joined by a spindle between the choke cams so both do the same thing (when adjusted right)
Hope that helps a bit?
Feb 19, 2008 15:05:42 GMT
Cool, what they going on?
horneyâ„¢
Feb 19, 2008 15:12:39 GMT
Mmmmm twin SU's. Had a pair on one of my old minis, sounded the nuts I tell thee.
Nick
Enbloc
Feb 19, 2008 17:01:21 GMT
Thanks Seth, thats the best explaination I've heard. It kinda makes sense now. This is the plan for them... They're a lot bigger than whats currently on there. Looking for more power, better drivability and better fuel consumption! (Aren't we all!?!) Having a quick mock up it seems they are not going to fit behind the bonnet! Mmmm.... Racy...
Last Edit: Feb 19, 2008 17:02:49 GMT by Enbloc
slater
Club RR Member Number: 78
School Me On All Things SU.... slater
@slater
Club Retro Rides Member 78
Feb 19, 2008 18:02:54 GMT
Then you need much smaller carbs! HS8s are mega SUs!
What capacity are those engines?
Feb 19, 2008 18:10:51 GMT
Last Edit: Feb 19, 2008 18:11:39 GMT by tootall
Seth
Feb 19, 2008 18:17:44 GMT
Then you need much smaller carbs! HS8s are mega SUs! What capacity are those engines? I think its around three and a half litres.
Feb 19, 2008 19:43:53 GMT
Lets clear up car terms: "Understeer" is when you hit the fence with the front of the car. "Oversteer" is when you hit the fence with the rear of the car. "Horsepower" is how fast you hit the fence. "Torque" is how far you take the fence with you.
Feb 19, 2008 19:54:01 GMT
HS8s are big ones. You don't really want to put them on an engine making less than 200 horse, or they will be just too oversized.
Enbloc
Feb 19, 2008 20:16:35 GMT
I got given these inchand 3 quarters off a triumph so I cleaned them rebuilt them amd bunged them on a pinto ,went very well and sounded ace in a suckysuckylongtime way:) Great pics. Is the manifold fabbed from exhaust sections?
yes well spotted
Feb 20, 2008 17:49:44 GMT
How long did the paint last? I want to paint mine so bad .
1982 VW Rabbit 4-door (apart) 1992 Passat Wagon Syncro (daily)
Feb 20, 2008 18:00:33 GMT
Didn't Rover P6 V8s have a pair of HS8's, or HD8's... can't remember. But that makes nearer 150 BHP. So I'd think they'd be perfect for your A.
Feb 20, 2008 18:55:40 GMT
No, the rv8 had a pair of HS6s, which is about right for engines starting from 120 horsepower, up to 200.
The 8s really are rare animals. They saw use mostly on jaguars I think.
Feb 20, 2008 19:55:35 GMT
No, the rv8 had a pair of HS6s, which is about right for engines starting from 120 horsepower, up to 200. Where are you getting these figures from??? Twin HS6s were factory fit on many cars with lower power outputs than that.
Feb 20, 2008 20:07:31 GMT
Such as what? I am going mostly by the power range a single one will cover on an A series engine.
Feb 20, 2008 20:10:07 GMT
Old Volvos!
Feb 20, 2008 20:21:10 GMT
Wow, you are right.. that is MADLY overcarbed. A pair of hs2s will flow enough for a mere 80 horsepower!
I have absolutely no idea why they chose blatantly incorrect carbs there. The B16 lump used a pair of HS4s, for exactly the same power output.
The nice thing about an SU, is it doesn't mind being overcarbed too much, since the venturi is adjustable. There is still no excuse for it though, since getting SUs in the right size is hardly difficult. And it will kill your throttle response. I suppose volvo didn't care about that..
Last Edit: Feb 20, 2008 20:22:20 GMT by rustybits
Feb 20, 2008 21:28:26 GMT
