May 11, 2023 15:45:11 GMT
Bit of a long term ask for help. Is anyone on here familiar with TunerStudio? I am using Microsquirt and TunerStudio is the tool for setting it up. I'm slowly getting there with it (albeit a near vertical learning curve). I know there will be parts of it I will struggle with so is there anybody on here who could help if I asked eg by PM.
Much appreciated.
May 11, 2023 16:09:37 GMT
best to just ask, i know a bit and i am struggling with stuff too, maybe stuff you need to know i do too!
May 11, 2023 16:12:12 GMT
Fair answer thanks. I was overthinking it again.
May 11, 2023 16:39:08 GMT
how far are you with it? whats it going on? I have microsquirt on a bmw e36 compact with a b230 volvo engine, and speeduino on a rover 100...
May 11, 2023 17:00:53 GMT
It's going on a Ford 2.0 dohc out of a Granada. It's in wifeys Ford Pop project. It's all wired, sensors are working, most parameters entered as much as I can. It's the afr table that's causing angst, I'm really struggling with it as in I have no idea how to build the table. I know how it works but relating that to a figure that needs to go in the box(s) is not computing.
Last Edit: May 11, 2023 17:01:38 GMT by crockpot
May 11, 2023 19:11:48 GMT
ah ok that s the bit that over my head too, do you have the paid version of tuner studio? Also do you have a wide band lambda in it? The bmw i have i took it to efi in runcorn and he set it up, with the r100, I'm basically at the same point as you with it. My mate came around and he put in some advance curve, then ran the auto tune and it was starting to sound better and better. not had it running again sice to do more. have you synced the ignition timing properly first too? WATCH THISi am interested in what other people say about this too .
Last Edit: May 11, 2023 19:13:17 GMT by bmw2101
May 11, 2023 21:36:20 GMT
It's not a paid version at the moment. I probably will pay at some point. It has a wideband lambda sensor.
I still have to synchronise the ignition but I'm fairly confident that 80deg is correct as it's using the standard 36-1 internal toothed wheel and standard sensor position.
Last Edit: May 11, 2023 21:39:56 GMT by crockpot
andyborris
May 11, 2023 22:34:29 GMT
The MS forums might be a help (if they're still active!) I know when I did my Triumph, I got a basic 6 cylinder OHV map and went from there using AutoTune.
goldnrust
West Midlands
Minimalist
May 11, 2023 22:43:09 GMT
The AFR table is a target table, to help guide the ECU as to what air fuel ratio it’s aiming for when it’s running in closed loop (constantly referencing the lambda reading and adjusting trims to try and get you on target) or when you are using the ‘auto tune’ feature to find tune your VE table.
The AFR table doesn’t need to be especially complicated, many of the cells will be the same as each other. Theres plenty of discussion online about what AFRs give the best performance and economy, but below is my rough understanding.
14.7 AFR is the mathematical ‘perfect burn’, and you could do worse than setting the whole table to this value, it would be like you were tuning with a narrow band lambda sensor.
Best full throttle power, for NA applications, is found at 12.7-13.5 AFR, depending on your specific engines needs. So set your top couple of N/A rows, say 80-100kpa (presuming you’re tuning using speed-density) to this.
On older engines you may find the engine will struggle to idle smoothly at 14.7, it might be happier at high 13s, low 14s, you can experiment with different values in the idle area. Just remember you’ll need to put it back to 14.7 to give you best chance of passing an MOT emissions test.
You may find that you can eke out a few more MPG by cruising leaner than 14.7, somewhere in the 15s, maybe even as lean as mid 16s depending on the engine. Once you’re up and running you can find out where the engine is on your table when sat doing 40-60mph on a flat road and populate this part of the table with leaner values. You may need to alter the ignition timing to maximise the gains here and keep an eye on temps and an ear out for knock. It might be easier to just leave it at 14.7 for cruise and save all the hassle for a few percentage if mpg… haha.
Finally if you are boosted then your low boost values will want to be 12.5ish, as the boost builds (say past 1 bar) you may find it better to be running as rich as mid 11s. Or you engine might not need it, depending on the fuel you’re using, the efficiency of your intercooler etc. boost is a whole other can of worms. Main thing, it’ll be richer than the n/a part of the table!
Andyborris, the Mega squirt forums seem to be almost dead, very little activity on them. Goldnrust, thanks for that. I am familiar with all that, just over thinking it all with regard to the afr table. I really should just make a decision and get on with it. No issues with emissions as it will be checked at the BIVA test and it's old enough to only need the basic test, doesn't even need a cat on it.
Last Edit: May 12, 2023 7:47:18 GMT by crockpot
goldnrust
West Midlands
Minimalist
May 12, 2023 12:02:10 GMT
As I said before don't worry too much about the AFR table, as long as its ball park, it will be fine, especially with an N/A build. For reference, here is a quick table I put together for a friends Mr2 turbo build. Note that it's a turbo car, so the KPA values on the vertical axis go up to 1 bar of boost. You will still want it idling pretty close to 14.7 in order ot pass a basic emissions test
May 12, 2023 13:18:04 GMT
That engine was originally a lean burn unit so you should be able to fairly weak under part load, but as said above I would start with around 14.7 across the board and richen it for the 80% load and above then play with the part load stuff later.
May 12, 2023 15:54:27 GMT
Thanks Goldnrust and Kevins. Some of the issue has been that despite being a new project the tables that came up were clearly for a turbo motor. I changed the scales to suit straight away and then started to ponder on what to put in the cells.
Kevins, thanks for that nugget of information, just the sort of thing that helps. I have put together afr and ignition tables that should get me in the ballpark initially. I'm reasonably confident of the rest but proof of the pudding and all that.
May 12, 2023 20:18:56 GMT
It's not a paid version at the moment. I probably will pay at some point. It has a wideband lambda sensor. I still have to synchronise the ignition but I'm fairly confident that 80deg is correct as it's using the standard 36-1 internal toothed wheel and standard sensor position. Defo get the timing light on it and check it, it makes a difference. ... and I'm learning a lot from this all too! thanks!
May 15, 2023 11:37:53 GMT
I set to yesterday and made a timing indicator tag. There's no timing marks on these engines but I did notice a small notch on the crank pulley. I also had a hunch that I had left the engine at tdc on number one bore. Plug out and quick check; yup, good to go. I made a tag wit 0 degrees and 5, 10 and 15 btdc on it. All ready to check the timing in the ECU. I'll detail that in my build thread.
goldnrust
West Midlands
Minimalist
May 15, 2023 19:40:12 GMT
Good luck! Remember to use the fixed timing mode in tuner studio when syncing the computer to the engjne 🙂
May 19, 2023 13:27:05 GMT
I appear to have a problem with the crank sensor. Tuner studio sort of sees it initially (rpm) but then its gone. The synchronisation error light is on as well. I have done a tooth log and it doesn't look at all right. Oh, also the pulse width is off the dial!! Any thoughts/ideas?
Last Edit: May 19, 2023 13:28:12 GMT by crockpot
May 19, 2023 13:50:13 GMT
Answering my own question. It seems that this is normal for a tooth log with a VR sensor. the one thing that is odd is that it is registering two bars for the missing tooth. Could it be a 36-2 sensor wheel?
May 19, 2023 16:21:56 GMT
the way its going up and down in waves isnt right its getting confused. " try a 10K resistor in parallel with the crank sensor" click hereon my bmw with the cossie crank sensor i have to use the resistor.
goldnrust
West Midlands
Minimalist
May 19, 2023 18:44:18 GMT
Each bar represents the amount of time since the last trigger. A subtle wave pattern is normal due to the engine slowing on the starter as each compression stroke comes to its top.
That wave looks excessive though. How fast is the engine turning over? If it’s turning quite slow and struggling that could cause it
The double pulse at the missing tooth could be caused by various things. Might be worth starting by double checking that you’re using the correct trigger edge (rising vs falling), and check the sensor itself it wired the correct way round?
