Apr 25, 2021 18:42:47 GMT
This is my latest project, a 1972 Chevelle Malibu sports sedan. Having fixed up and sold a couple of my retro cars to fund a house deposit, I found myself wanting another old car to play with, and for the first time ever I actually have some decent parking and a garage to work in. I've been after something american for a while now but always found them a bit too expensive, so I started looking into imporing one myself. The process actually looked fairly straightforward, especially for an older car, and with car prices in the states being so much lower I decided that was the way to go. I wasn't overly fussy about what car i wanted really - there are lots of old american cars i'd like to own - but in the end I settled on a 68-72 GM A-Body (Chevy Chevelle, Pontiac LeMans, Oldsmobile Cutlass & Buick Skylark). Theres still plenty of these things knocking around in the states, and aftermarket support for them is excellent, so after a bit of searching I purchased a 1972 Chevy Chevelle Malibu Sports Sedan and set about getting it shipped over. Here are a few pictures from the advert. It's generally pretty undesirable being a 4 door, but that also means it's much much cheaper than a 2 door of similar condition. It's also 'only' a 307 or 5.0L V8, 72 was the first year for unleaded fuel and Net power ratings, so this 307ci powerhouse pumps out a full 140hp with its 8:1 compression ratio. I bought the car back in Jan, and with so much uncertainty over shipping delays and port congestion I wasn't really expecting to see the car for a while yet. I knew it was on a ship and due to be in port 2nd week of april, but hadn't heard anythign from the UK side of the shippers. Then I checked my junk email folder to find about 6 emails from them confirming they had my car, it had cleared customs and was due to be unloaded from the container in the next day or so. So I sorted out payment for them and for the customs charges and organised collection of it from their faciity in Milton Keynes last friday. Now, this all happened quicker than expected, and I think theres even a chance I can get it to the weekender, so theres the challenge: get this chevelle registered, roadworthy and a bit cooler looking and take it down to goodwood!
Apr 25, 2021 19:03:35 GMT
Cool. Get the V55/5 sent off as soon as you can in that case.
Last Edit: Apr 25, 2021 19:03:54 GMT by Deleted
Apr 25, 2021 19:09:00 GMT
It's generally pretty undesirable being a 4 door, but that also means it's much much cheaper than a 2 door of similar condition. I've always though that four door pillarless hardtops were the best of both worlds, and usually much prefer them to the two door versions!
Apr 25, 2021 19:52:53 GMT
First job was to get the thing running and see what does and doesnt work. It was sold as a running and driving car, but the shippers couldnt get it running in the UK. It ran on brake cleaner, so I chucked a couple of gallons of fuel into it and she fired right up! Next was a quick drive around the housing estate - again all seemed good, transmission works, brakes work, even the parking brake works well! Checked all the lights and they all work as well! so far so good then. Heres a few more pics of it sat on the drive in the sun. So first impressions are pretty good, but time to dig a bit deeper. The engine looks pretty good, the air filter is brand new, as is the oil filter but the oil, although I doubt its done many miles, looks decidedly old so a service is clearly required. The distributor has been replaced with a later HEI unit from any number of 80s GM vehicles, and has some good quality leads fitted, so we'll call that good enough. On the running gear front, the brakes look to have been replaced recently, including the hardlines, flexis and parking brake cables, but I did find this very dry looking front wheel bearing, so added that to the order list. Also, all of the weatherstripping around the side windows is crumbling away to nothing. Since it does occasionally rain in the UK i figured this was a fairly high priority so ordered this as well. Amazingly there is a company that still makes weatherstripping for a 72 Chevelle 4 door hardtop, but man, it aint cheap! Next step is check for rust - I knew it needed a boot floor (the seller provided a boot floor patch panel), so I thought that was probably a good place to start. That is some fairly advanced weight reduction... The patch panel will cover most of it, but the very outside edges will need to be fabricated, as will several parts near the boot catch. I have ordered the rear tail panel (bit that holds the boot seal along the rear edge) as honestly there isn't enough left to make a template from! It would be nice to take luggage to goodwood and not have half of it fall through the boot floor, so i've started stripping the rear for a mini weldathon. Onlt 1 bumper bolt needed some persuation, but annoyingly both tank strap bolts will need cutting off. That is about it for now, i'll update you as parts arrive/things get done...
Last Edit: Apr 25, 2021 20:01:16 GMT by Splitty456
Apr 25, 2021 19:53:49 GMT
Cool. Get the V55/5 sent off as soon as you can in that case. V55/5 sent off monday last week - lets see how efficient the DVLA are feeling!
Apr 25, 2021 20:15:08 GMT
" nurse, bhp at 140, give me 300 horses stat!"
Apr 26, 2021 18:35:02 GMT
“140”
Question is does she do a burn out? 😜
'91 BMW E30 318is '91 BMW E31 850i '96 BMW E38 750i '68 Singer Chamois (Yamaha R1 Engine... ) '95 Mini 1.3i '61 Lamborghini 2241r '64 Lamborghini 1R '57 Lamborghini DL25C Plus a few others...
Apr 26, 2021 18:41:20 GMT
Simply put.
100% loving this.
Apr 26, 2021 18:41:49 GMT
Simply put.
100% loving this.
So much, I mentioned it twice.
Last Edit: Apr 26, 2021 18:42:28 GMT by grizz
Paul Y
Apr 26, 2021 19:55:28 GMT
“140” Question is does she do a burn out? 😜 I am on my way..... You can make the 307 sort of respectable for not a lot of cash - grab a cold snack and watch Derek show you how.... Rare to see a pillar less 4 door chevelle in the uk, would look epic with an adjustment in altitude and a set of big wheels. Along for the ride. P.
Last Edit: Aug 18, 2021 19:23:24 GMT by Paul Y
Apr 27, 2021 11:39:26 GMT
Thanks for the comments guys! “140” Question is does she do a burn out? 😜 I am on my way..... You can make the 307 sort of respectable for not a lot of cash - grab a cold snack and watch Derek show you how.... Rare to see a 4 pillar less 4 door chevelle in the uk, would look epic with an adjustment in altitude and a set of big wheels. Along for the ride. P. Big fan of vice grip garage! I've already been collecting parts to fix the horsepower issue, just trying to get all the boring stuff out of the way first.
Paul Y
Apr 27, 2021 13:22:19 GMT
[/quote]Big fan of vice grip garage! I've already been collecting parts to fix the horsepower issue, just trying to get all the boring stuff out of the way first.[/quote] Probably one of my favourite shows on YouTube. Nearly 300hp and the over that number on torque for $700 is a bargain. Or you could just gap the rings and add a turbo as the compression is so low.... P.
tofufi
South West
Apr 27, 2021 13:52:40 GMT
Love it A big American car is something I'd love to own at some point. Looks great as a pillarless 4-door in that colour, too
75swb
Beta Tester
Club RR Member Number: 181
Apr 27, 2021 23:55:32 GMT
Epic buy, and ambitious timescale! I'm in for the ride.
Oh, now that is a cracking looking bit of kit!
Well done sir, great purchase.
At least you won't have to drill the spot welds out on the old boot floor haha
As above really, cool to see a 4 door pillarless Chevelle, let alone in the UK!
Was that ShipMyCar you used in MK?
Most importantly, how does she sound? Video?
squonk
Apr 28, 2021 10:32:50 GMT
I've been hankering after an 70s/80s/90s American pickup for a while but prices in the UK are stupid for what are basically scrappers. Consequently, I have also been thinking about buying and importing myself. Can I ask where you found this car advertised and how much it cost to ship?
Paul Y
Apr 28, 2021 11:24:08 GMT
If you want a recommendation for a US based 'chap' can I suggest Ray at Ray's classics? I have used him a few times to source cars for friends and they have always been more than happy. Super easy to deal with and a nice guy to boot. His website is a bit out of date but if you are serious then let me know and I can make an intro for you. Based in California so rust is not too big an issue. I didn't get my PU from him but he collect it from the seller, arranged shipping, paperwork and allowed me to fill the bed up with parts. The other place to look - if you re after a C10 - is C10sales on Instagram. We now return you to your scheduled programming.... P.
Apr 28, 2021 12:36:35 GMT
I've been hankering after an 70s/80s/90s American pickup for a while but prices in the UK are stupid for what are basically scrappers. Consequently, I have also been thinking about buying and importing myself. Can I ask where you found this car advertised and how much it cost to ship? I actually bought this from Ebay.com, but was looking on craigslist and facebook marketplace as well. Facebook definitely seems more popular for selling cars over there compared to ebay or even craigslist, but really you need a contact to go view and make the sale on your behalf. I found very few people willing to deal with an overseas buyer directly, one guy even thought i was trying to scam him! For shipping I used CFR Rinkens, but it turns out ShipMyCar are their UK agent. I found both companies very easy to deal with and would happily use them again. For this car from Massechusetts to New Jersey to Milton Keynes shipping was roughly £1650. From the west coast you'd probably add another £500 to that price. And bear in mind that shipping the car from its location to the US port can add up quite quickly, so shopping for cars realively near a shipping port can save some money.
squonk
Apr 28, 2021 14:26:14 GMT
Brilliant! Thanks for the info, it's very useful. I think that when we are over this Covid stuff I may take a holiday in America and go car shopping in person. Probably not a bad idea as any parts I need I can get while I'm there.
Ideally it would be great to fly to the west coast, buy a pickup there and take a couple of weeks to drive to the east coast in it and then get it shipped.
Apr 28, 2021 20:31:31 GMT
