A bit niche, what have you got? I submit the M35 'Deuce & a Half' Apparently designed this way as, being a 3 seat abreast military vehicle often used in long distance convoys, you'd want the overdrive to sit as far from the passengers as you could.
Rich
Club RR Member Number: 160
Weird shift patterns ...Rich
@foxmcintyre
Club Retro Rides Member 160
Early military and to a lesser extent civvy truck applications was often odd. This is for a Ural, not sure if It’s the 4320 or the 357.
adam73bgt
Club RR Member Number: 58
Weird shift patterns ...adam73bgt
@adam73bgt
Club Retro Rides Member 58
Maybe not quite as out there as those military patterns, but for a time Keiichi Tsuchiya ran a "3.5" gear in his AE86, replacing the overdrive 5th with a ratio between 3rd and 4th
Droopsnoot Firenza Getrag with ‘dog leg’ first Also David Brown H’ gate, can’t find any images but basically 1st & 2nd are normal then 3rd & 4th are swapped so you are kinda drawing a H shape. You then flick the splitter & go back to what was 1st, which becomes 5th & go around the box again, obviously giving 8
Rich
@foxmcintyre
Droopsnoot Firenza Getrag with ‘dog leg’ first Also David Brown H’ gate, can’t find any images but basically 1st & 2nd are normal then 3rd & 4th are swapped so you are kinda drawing a H shape. You then flick the splitter & go back to what was 1st, which becomes 5th & go around the box again, obviously giving 8 I run a dual splitter switch setup on my gaming rig shifter, 7x4 options totalling a possible 28 gears, flusters me a little if I haven’t played for a while and forget which switch is which range.
This has sent me down a rabbit hole of odd gearboxes now. Suzuki 14 speed anyone? Not an odd shift pattern as it's from a 60s 50cc race bike but you'd just be constantly shifting gears. Was that 12th, or 11th?
This has sent me down a rabbit hole of odd gearboxes now. Suzuki 14 speed anyone? Not an odd shift pattern as it's from a 60s 50cc race bike but you'd just be constantly shifting gears. Was that 12th, or 11th? Yep, all those little racing 2 strokes had huge numbers of gears. Obviously being of small capacity & 2 stroke meant they had a powerband about the width of the rev counter needle & the only way to keep them ‘on it’ was lots of ratios 😀
This has sent me down a rabbit hole of odd gearboxes now. Suzuki 14 speed anyone? Not an odd shift pattern as it's from a 60s 50cc race bike but you'd just be constantly shifting gears. Was that 12th, or 11th? Yep, all those little racing 2 strokes had huge numbers of gears. Obviously being of small capacity & 2 stroke meant they had a powerband about the width of the rev counter needle & the only way to keep them ‘on it’ was lots of ratios 😀 My first bike was a 50cc Kawasaki AR with a 5 speed box, I was constantly shifting riding it around town, though you needed to in order to stop it from bogging down (plus it was just plain awesome). I jumped up to a Suzuki RG after that and felt like I was strapped to a missile for a while.
Looks like a normal H gate but is 18 speed forwards and 3 reverse.
The Doctor
Club RR Member Number: 48
Weird shift patterns ...The Doctor
@thedoctor
Club Retro Rides Member 48
I can't find any pics of it right now, but there's a company in Finland that makes a gearbox for old Toyotas with a weird gear pattern.
The 5th gear is notorious for being the weakest, as its added on the end of a 4 speed box.
For rally they make a gearbox where 1st gear is in place of where 5th is normally.
So it's
2 - 4 - 1 3 - 5 - R
That's going to be a bit of a learning curve!
Looks like a normal H gate but is 18 speed forwards and 3 reverse. Took my class 1 HGV test in one of those 😀 we had literally hundreds of them at the NCB
Last Edit: Mar 6, 2021 14:23:13 GMT by rattlecan
We had this Which I did post in the Wreckers thread. But it had this You will notice it has a basic ‘4 on the floor’ but then you’ll see him flicking up & down the range with the 3 split top right of the steering column. It was a bit of a ‘pat your head & rub your belly’ thing to master. I drove it miles 😀
I can't find any pics of it right now, but there's a company in Finland that makes a gearbox for old Toyotas with a weird gear pattern. The 5th gear is notorious for being the weakest, as its added on the end of a 4 speed box. For rally they make a gearbox where 1st gear is in place of where 5th is normally. So it's 2 - 4 - 1 3 - 5 - R That's going to be a bit of a learning curve! They’ll stick first there because once you’ve gone off the start, other than maybe an odd hairpin you’ll never be in first again. Obviously would be a pita in a road car but they won’t have that issue. Bit like on some race motorcycles, they have a really really tall 1st, so you literally slip the living daylights out of the clutch to start off. But then they are probably never doing less than 40mph again around a whole circuit, so that tall 1st gear gives them huge drive out of said hairpins. Obviously on a bike it’s just an up & down gear selection
Droopsnoot Firenza Getrag with ‘dog leg’ first Droopsnoot Firenza was the ZF box, but the pattern is correct. Twin-cam (HS / HSR) Chevette and VX490 had the Getrag box, which has the same shift pattern.
As did the 190E Cosworth models
Here’s how it’s setup in my Trabant. It’s actually a really good fast shift once you get the hang of it.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
