Apr 10, 2020 17:50:01 GMT
So, like all of everybody else we're stuck inside. I can go out to the garage and work on the car but ultimately I can't really go out and drive it. So, eBay is in overdrive. I've already bought some small project pieces that I can work on indoors. I bought this carb as a spare for the Pontiac. A few evenings later it's all cleaned up. That wasn't enough, so eBay again- I've been on the hunt for one of these particular machines for ages, one popped up for sale, made an offer and the seller accepted. It was totally jammed up solid- the carriage had become loose and the guide got all snarled up in the positioning gear. Some egregious use of a hammer later and it's freed up enough that it does some typewriter style things again. I'm about to try repair the broken carriage belt and see if I can get the Magic Margins to work. What small tabletop projects have y'all got on the go?
Last Edit: Apr 10, 2020 17:55:07 GMT by PhilA
Apr 10, 2020 17:57:48 GMT
110v drill overhaul? Shameless repost from readers other mods
Still needs work, but by jove it's working. Phil
What a brilliant thread idea. I do not need to do that right now, but suspect many people like MR TIKI would do just that right now, either lacking in garage or workshop space or where current measures stops them from getting to a workshop. Thought a āCopy and Pasteā From February 2016 Could be in order. OK Amigos.......... Let's see some confessions.Went to bed at 01.30 after various chats with friends in Texas, Missouri and Oklahoma as well as my wife's daughter in California. At 06.15 there was a furry thing walking all over me, purring and demanding breakfast. So the lesson really is, unless you have no animals, don't go to sleep so late. With me awake, I sorted the three cats out, they all have different breakfasts WTF..? And a tower of dry food for their grazing through the day. Cuppa tea in hand I checked out the various sites and also Summit Racing's website....... Get me drift yet? Tea done, I went down to the garage in my slippers and a dressing gown (well, it's chilly, so I needed the woolly slippers) But only after setting the oven at 200'C I removed all the masking and plugging from threads, then with gloves on, brought the heads up to the house one at a time. I hear some of you already clearing your throats and shuffling uncomfortably in your chairs. Some, probably the brave and stupid, which is where I fit in....... Knows what next. I managed to just get both heads balanced in the preheated oven with the door completely shut to heat cure the VHT paint for an hour. And in they went. After about 30 minutes it started to smell like a race track in the lounge where I was reading..... So I went into the kitchen to find a light haze of smoke. Easy fix...... Open all the outer doors and windows to the kitchen and rear of the house, isolate from the rest of the house. After the hour, I turned off the heat and opened the oven door for the heads to cool down so I can take them back to the garage later. The place still smelled, but I will leave it all open for a while. Hopefully my next plate of Fish and oven chips does not taste like high mileage multi grade. And of course there will be a Yankee Candle burning in the kitchen most of today.........
Last Edit: Apr 11, 2020 6:40:35 GMT by grizz
Apr 13, 2020 15:05:56 GMT
Range Rover Classic master cylinder rebuild count? Cold outside today, well colder than yesterday Gave me a chance to use my cylinder honing tool that Iāve had for about a year still in its pack Its surprising how much fluid is still in a cylinder when you think youāve drained it Still it polished up the tabletop ok, and swombo hasnāt noticed.....,yet š
60six
(āÆĀ°ā”Ā°ļ¼āÆļøµ ā»āā»
Apr 13, 2020 15:59:45 GMT
Finally decided to face my non-automotive nemesis of a few years ago - The JBE-Mk3 record player! Was given this in exchange for fixing a computer and it needed the tone-arm rewiring - A tricky job considering the width and strength of the wires involved and it was a lot more difficult than I thought. Inside the tone-arm was balsa wood which was a challenge to remove but I persisted - Bought a new cartridge and needle, plugged it into the amplifier it came with and nearly blew the speakers out with BUZZZZZZZZZ - curse word. Must of done something wrong with the tone-arm and decided to just forget about this for a while, until now. Thankfully, the lead between the record player and the amp had shorted, creating the buzz. My wiring was fine! Now just need to replace the power switch on the players control box and it will be running sweet! Amplifier is a LEAK Stereo 30 which had a slight buzz during use - Will see if there is anything I can do about that. Was about to dive into the Blaupunkt radio but valves are a mystery to me so will blast the dust out with a compressor and send it to an expert. The grundig however works fine after some electrical contact cleaner in the volume control.
Apr 13, 2020 16:46:19 GMT
Apr 13, 2020 17:15:46 GMT
Love the old audio stuff, those old radio grams where all the stuffs built into its own cabinet sounded great at the time!
Rich
Club RR Member Number: 160
Apr 13, 2020 18:33:21 GMT
Some lovely old hifi goodness going on in here! I've been building a 1/18 scale (working!) wrecker body for my ZIL 157 (JJRC Q69) (clicky) And making up another speedo clock to order.
Last Edit: Apr 13, 2020 18:35:06 GMT by Rich
Apr 13, 2020 19:47:32 GMT
Love a retro record player. Iāve got a HMV & an AMI jukebox in my 70ās room Blimey....that took me back 40+ years...we had one of those radiograms! Lovely.
Apr 13, 2020 20:00:22 GMT
Love a retro record player. Iāve got a HMV & an AMI jukebox in my 70ās room Blimey....that took me back 40+ years...we had one of those radiograms! Lovely. Yeh it sounds great, it lives here
Apr 13, 2020 20:01:42 GMT
adam73bgt
Club RR Member Number: 58
Apr 13, 2020 20:55:22 GMT
I'm currently working on this which is a compressor for a set of Maserati air horns that I've had sitting about for years now, finally getting round to making them work!
Great idea. I had to take a step back first. I just bought a kitchen table....Next is to find a nice little project
should be a smith-corona then?
Apr 16, 2020 10:45:03 GMT
We had to take our table apart and store, got a dead cheap office desk, as wife thinks this working from home, is going to be for a while
Last Edit: Apr 16, 2020 10:47:43 GMT by shagracer
Please don't throw litter, take it home.
Apr 16, 2020 13:10:53 GMT
should be a smith-corona then? Close, it's one of the big names; Royal. After work yesterday I took this, which had succumbed to the kids' "Hey listen how loud it goes!", and turned it into this Loudspeaker repair is remarkably difficult, even for an assumedly simple thing like replacing the foam suspension. Re above, I have the same Blaupunkt chassis with the piano keys in a sideboard radio that's sadly a bit far gone, however it was one of the first uses of printed circuit boards and does contain some rather silly voltages inside that'll give you a nasty wallop if you aren't careful. They do sound good when running right though, even if it's very German and strange in design electronically... Phil
Last Edit: Apr 17, 2020 4:14:39 GMT by georgeb
^^^ Iām glad to see that you have the most important tool when fixing a landy georgeb, as shown in the first picture š
Brave brave souls... i would have my balls in my pockets if i brought anything car related into the house let alone put something on the table!!
