Hello,
So it is already mid morning on Saturday.....
I've finally got the Sunny back on 4 wheels, however I'm off to London for the evening, won't be able to check it out until tomorrow afternoon. There is a slight clunk on one side which I think may be a touch lower than the other side, so probably hitting total drop, will investigate further tomorrow.
What are you up to? Planning to be up to?
qwerty
Club RR Member Number: 52
Apr 16, 2016 10:07:44 GMT
Lowering my brothers Polo and fitting his arb blocks.
Bonding the plastic arches on to the back of my Polo and hopefully getting the dash to all work.
simes
Apr 16, 2016 12:00:31 GMT
Put my Honda back together. Plus new oil, coolant.......
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
Apr 16, 2016 12:10:32 GMT
Last Edit: Apr 16, 2016 12:11:03 GMT by DarrenW
Apr 16, 2016 12:47:17 GMT
Going to newark autojumble. I always forget its on so this can be a little reminder for others
Anglia68
Powered By Boredom.
Apr 16, 2016 13:10:33 GMT
Now that the snow has melted, yes really, I am going to remove both engine mounts and have a go at remaking them so that the engine sits a little lower as at present it is too high as the current mounts are miss mash of steel brackets and rubbers that just don't go together.
Last Edit: Apr 16, 2016 13:11:07 GMT by Anglia68
longman
Club RR Member Number: 3
Apr 16, 2016 13:39:48 GMT
Last Edit: Apr 16, 2016 13:40:19 GMT by longman
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
adam73bgt
Club RR Member Number: 58
Apr 16, 2016 14:02:49 GMT
Can't get too much done this weekend, but am mostly cleaning up the 'new' exhaust system for the RX7 And trying to find someone to weld up the BMW
ems1
Apr 16, 2016 17:29:33 GMT
Trying to get the C20XE in the Manta to run for more than 10 minutes before it cuts out and refuses to start again, at the moment the car is winning!
1985 Manta GT/E 16v 2001 VW T4 Caravelle
vulgalour
Club RR Member Number: 146
Apr 16, 2016 20:36:58 GMT
Going to be brave and attempt some gutter repairs on Peugeot 206.
Apr 16, 2016 20:41:09 GMT
headgasket on a bandiit 1200, battery on my mk2 golf then a ride round to remind me how bad it is then possibly go do the avenger
Apr 16, 2016 21:48:00 GMT
I'm off on a rescue mission soon, a local ex avenger owner is cleaning out his shed, whatever's left behind is off to the tip
Apr 16, 2016 23:05:38 GMT
One of these days my wife is going to divorce me citing my being distracted by your annual Worthersee thread as grounds. Nothing so exciting for me, changed the oil on my S-type. 6.5 litres is a lot of the black stuff when you try to get it in a 5l container.
Jaguar S-Type 3.0 SE
