slot
Quick update The trusty Pinto removed with supervision now in the ownership of my old fella Look at all the space between . . . . . . my ears ! I've purchased a engine stand to check the BOA engine over as its believed not to check the timing chain and tensioners at this point is asking for trouble ! More soon Dave
slot
Nov 11, 2012 16:29:45 GMT
Currently working on the BOA engine, bolted upto the newly purchased stand What i'm doing here is nothing new, but after reading lots about cam chain tensioner wear and oil starvation on higher mileage engines I didn't want to just throw this beast in without a good look ! So all the nessesary parts removed, Plenum, cam covers, sump, water pump, timing cover, bottom pulley and injector rail etc, this was left ! And as the inevitable was stairing right at us, I could only feel relief we had took the time to check for wear ! I was sold the engine being told it had done less than 80k, so this is the start of the tensioner, slipper wear ! A quick look at the mains and liners and everything looks ok So I few parts to order, the cleaning of sump. oil pump and oil ways and then the rebuild ! Tar for Now Dave
Last Edit: Nov 11, 2012 16:39:39 GMT by slot
Smiler
Nov 11, 2012 17:21:47 GMT
Nice project! I have a few notes on Cosworth V6 conversions on my website that may be of use. Click on the link in my sig and take a look at the Cortina section. There's also a minor brake upgrade in there too that will apply to your car.
Nov 11, 2012 19:00:15 GMT
Good call to make those checks! That coulda been nasty.
slot
Nov 13, 2012 16:18:10 GMT
Thanks Darryl Smiler, you have just made my day matey ! I found your site a month or two back and then just as quickly lost it ! There's some cracking info on there pal, just what I need How far off finished is it from the last update mate ? Cheers Dave
Nov 13, 2012 17:00:09 GMT
looks loverly!
A small query I have over your 'increase of airflow to radiator'. With what you have done, you need to think of where the air is going to go as you push it in to your engine bay. With no exit for the air, the engine bay is going to act a bit like a sail and all that air pushed up and into it is going to lift your car as the air has no exit for now. Unless you can redirect it back down once it has gone through the radiator?
slot
Thanks for the info Monkey This is something I plan to look at once the new engine is in I'm pretty sure I will have to modify the bonnet in some way, given the extra height and width of the V6 So it would be right for some sort of exit holes Even toying with the idea of venting the wings ? Thanks for the comments Dave
Darkspeed
Club RR Member Number: 39
Nov 16, 2012 20:01:58 GMT
The G26 BOA Cosworth that I know of is on ebay at the moment - if I had the room and a few less projects I would snap it up and swap the running gear into my G31. That has the potential to be a really good buy for someone.
slot
Nov 21, 2012 21:20:46 GMT
Yep, went for a bargain price darkspeed, I will have to wait a few years for mine to go up in value, just so I can get back what I payed Well I think i've just extended the plans for the old girl ! I've decided to drop all the front subframe, to get it powdercoated and get it all polybushed up, this is the best chance i'm going to get ! Did I mention the old chap that originaly built this was a 1960/70's TT sidecar rider/builder ? Now i've had a proper look underneath, the level of detail in finely drilled bolts and safety lockwired is amazing ! Its a shame i'm going to have to cut it off to strip the whole thing down Anyway here's the latest The new void to look into, note the lockwire on the steering rack I've got a few things to do in here to fit the cossy ie, cut some of the angle cross member back, move some brake/fuel pipes around and modifiy the heater box etc Sorry theres not going to be many welding pic's even the chassis is galvanized Brake calipers and steering arms . . . . . . . . yep, you guess'ed it lockwired tar for now
Last Edit: Nov 21, 2012 21:35:36 GMT by slot
mrluke
Nov 22, 2012 16:29:57 GMT
Looking good
Nov 22, 2012 20:33:39 GMT
Have a GRP-bro high-five. 8)
You know these RR guys are into their epic welding. What possible interest could they have in a GRP car with a galvo'd chassis ;D ;D ;D
slot
Nov 22, 2012 21:25:01 GMT
You know these RR guys are into their epic welding. What possible interest could they have in a GRP car with a galvo'd chassis ;D ;D ;D Whoop's ;D Upset, Potential, Cart 'o' apple's Sorry ! no harm mean't
Last Edit: Nov 22, 2012 22:25:01 GMT by slot
slot
Nov 24, 2012 19:40:29 GMT
Last Edit: Nov 24, 2012 19:41:30 GMT by slot
mrluke
Nov 24, 2012 21:41:20 GMT
That was speedy, good effort.
Does it all come apart fairly easy once its off?
Last Edit: Nov 24, 2012 21:41:40 GMT by mrluke
slot
Nov 28, 2012 19:04:36 GMT
That was speedy, good effort. Does it all come apart fairly easy once its off? Yeah pretty straight forward matey, plenty of WD ! ;D It took about 25 mins a side, I didn't use spring compressers tho, just turned my head and shut my eyes Dave
Last Edit: Nov 28, 2012 19:05:44 GMT by slot
Surely the tidiest Cortina subframe in existence!
Yikes. I assume your head is still on your shoulders?
slot
Thanks Darryl, Head still attached . . . . just Been back in the garage to clean up the engine bay, in prep for the V6 Galvanised chassis also given a good going over with a silver wire wheel in the grinder Before After One of the opp side I'm not sure if to now paint it with silver Hi temp paint or to just leave as is ? Tar for now Dave
mrluke
curse word thats come up well
Wow. That DID come up well. Personally, I'd leave it as-is.
I completed an unfinished Metisse years ago and did the galvo'd chassis in black, but it didn't take very well and didn't look great either. It might have been the paint I used.
But now you've got tidy metal, I'd flash that as a badge of honour. 15/20 years and no rust? WIN If you do paint it, I don't think you'd need hi-temp paint.
Slot thank you for giving me an incentive to finish my G26 restoration and engine change (tame 1.8 zetec).
Will be watching with interest , Good luck with the rest of your build.
Dan
