Hey all, I was just reading the truckdoctor's P5B thread, and I noticed something about the front sidelights- I'd noticed years ago on the P6B that the front sidelights have a little clear pip of plastic that sits up above the light surround... the P5B does too but it's red. Does it light up? Is it just there for show? Is it something related further back in motoring history that I'm unaware of? ...and why red, on the front? --Phil
stuey
ram thruster 4000
they are side light tell tales- mk2 jags have them too-
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Okay. That does make sense- I'm guessing it's just visible over the top of the wing from the driver's seat?
-Phil
v8ian
yep, you can see them when you are driving, quite cool, obviously informs you when your lights are on, don't quite understand the logic of that, unless they were put there to inform you if your bulbs are blown
yep, you can see them when you are driving, quite cool, obviously informs you when your lights are on, don't quite understand the logic of that, unless they were put there to inform you if your bulbs are blown Back in the days of weedy batteries and dodgy charging systems I suspect it was also to stop you getting out and leaving them switched on. I quite like the petrol cap hanger on my Volvo.
scruff
My Porker has an under bonnet light which is quite thoughtful....
1994 Lotus Esprit - Fragile red turbo with pop up lights. 1980 Porsche 924 - Fragile red turbo with pop up lights.
I spy a trend...
The Delica has an extra set of lights by the side repeaters. When the sidelights/dipped beam is on, each time you indicate the extra light will come on and illuminate the road to the side on which you are indicating/turning. It's pretty effective too....really lights up the road to the side as you indicate.
if you can see those little red fellas on the Rover from the driver's seat, are they not to help you know where the corners are when manouvering? Like those light sabres you used to see on J import cars from the early '00s? you see them on those Scanias that look like melted American trucks too:
A friend had a Soarer that used to switch on the fog lamp on the side you were indicating to illuminate the road for turning.
Badges that aren't just badges make me smile. ^^ the Seat Leon's boot badge is also the boot handle; ditto the old New Beetle which has a pivoting badge with a lock behind it. And the Fords whose grill badges swing around to reveal bonnet opening locks. **edit**Oh yes, and the grill badge on my old mkII Cortina operated the bonnet release too.
Last Edit: Apr 23, 2012 8:50:05 GMT by dbizzle
Humbers had the petrol filler hidden in the rear ligth cluster with the cap being a reflector - Paul H
A friend had a Soarer that used to switch on the fog lamp on the side you were indicating to illuminate the road for turning. Neighbour bought a brand new (59 reg) Seat Ibiza and I said front fog light was faulty as it kept flickering on when they were manouvering so they went back to the dealers. Turns out they have the same sort of system as the Soarer Paul H
AB car pix
Car mag' snapper
yep, you can see them when you are driving, quite cool, obviously informs you when your lights are on, don't quite understand the logic of that, unless they were put there to inform you if your bulbs are blown Back in the days of weedy batteries and dodgy charging systems I suspect it was also to stop you getting out and leaving them switched on. I quite like the petrol cap hanger on my Volvo. That's cool, and now I realise what the odd shape on the cap is for on mine! I always just slot it in under the pump's handle for 'auto-filling' though. Perfect size on the Volvo caps!
1979 Chrysler Horizon 1.3 GL 1980 Ford Granada 2.8 Ghia 1985 Ford Sierra 3dr 1985 Ford Escort Mk3 1988 Ford Sierra Sapphire Cosworth 1989 Ford Escort 1.3 Popular 1995 Volvo 960 1996 BMW 525i 1998 BMW 323i 1999 BMW 530d 2003 BMW 530i . www.facebook.com/ABCARPIX
bortaf
The Delica has an extra set of lights by the side repeaters. When the sidelights/dipped beam is on, each time you indicate the extra light will come on and illuminate the road to the side on which you are indicating/turning. It's pretty effective too....really lights up the road to the side as you indicate. My lucida had similar, the sidelight was a stop and tail bulb, 5W for side light then 21W when you indicated, total curse word anywhere with street lights but great in the country.
R.I.P photobucket
bortaf
yep, you can see them when you are driving, quite cool, obviously informs you when your lights are on, don't quite understand the logic of that, unless they were put there to inform you if your bulbs are blown Back in the days of weedy batteries and dodgy charging systems I suspect it was also to stop you getting out and leaving them switched on. I quite like the petrol cap hanger on my Volvo. Granada Mk2 plastic petrol flap has the similar, i've fitted the same one to every cortina (Mk3/4/5) i've owned for the last 20 odd years, bolt on mod, noone notices but I like it ;D
Last Edit: Apr 23, 2012 9:29:50 GMT by bortaf
R.I.P photobucket
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
How about the number plate on the Amazon estate that is on a flap which drops down when the tailgate is down so you can still see the plate. Enables you to carry long items.
Apr 23, 2012 10:02:52 GMT
How about the number plate on the Amazon estate that is on a flap which drops down when the tailgate is down so you can still see the plate. Enables you to carry long items. I was just about to say that ;D - the light is part of the rotating section, so all completely road legal. A friend writes for a modern car mag, and when he saw that, he commented that modern estates should have this! Another nice feature on the estates is the rear overriders - flat topped, with a rubber tread, for use as steps to load a roof rack
Little design featuresDarrenW
@darrenw
Club Retro Rides Member 74
Apr 23, 2012 10:29:26 GMT
How about the number plate on the Amazon estate that is on a flap which drops down when the tailgate is down so you can still see the plate. Enables you to carry long items. Early Minis have that too, really neat
lizardking
'zon the revelator
Apr 23, 2012 10:33:23 GMT
these are all excellent ideas from the days when cars had designers that went to the pub for lunch and not keyboard monkeys like today that think a different headlamp and taillamp setup makes yet another modern stand out
I'M SO RETRO , I SH1T SPANGLES
'68 Amazon,97 x300 jaaaaaaag,96 Mx-5,86 1300 mg Trike
L300 Delica ex MM
Apr 23, 2012 12:11:17 GMT
Not much on new cars makes me smile and say that's really natty, last thing was seeing the new door protectors on the new focus they hid in the door shut then when you open the door it pop's out and wraps around the door edge protecting the door, then just before the door closed it pops back behind the door, cool l thought until a saw the complected mechanism that controls it and come to the conclusion it was a waste of resources!
