Feb 14, 2012 18:26:16 GMT
Looks like it has 'RSI' stamped into the back, could they be an early set of RSI alloys?
Feb 14, 2012 18:26:27 GMT
I doubt they will be 4x100 but looks like the holes are ovaled aswell. fit out what they came off and then you would have a better idea
Porsche
West Midlands
Kev from B'ham.
Feb 14, 2012 18:33:57 GMT
Thanks guys. They aren't to far from where I live so I might be able to go and trial fit one before I bid?
Just done a quick photo shop....they wouldn't look too bad don't you think?
Last Edit: Feb 14, 2012 18:34:45 GMT by Porsche
Feb 14, 2012 18:53:52 GMT
I'd ask him what they were fitted to before. My instinct says they're either Ford or something like a Triumph 2000 in which case the PCD will be way off what you need.
If they did fit then they would look extremely good with some suitably low profile tyres on a slammed Corsa.
Porsche
West Midlands
Kev from B'ham.
Feb 14, 2012 19:08:59 GMT
Yeah, I've asked for the bolt hole mesurement and what car they were on before. Just waiting for a reply.
Feb 14, 2012 19:10:37 GMT
Don't forget to budget in a set of sleeved wheel bolts and possibly spigot rings too, even if they are 4x100 (Which is unfortunately not too likely on a wheel of that "vintage")
Feb 14, 2012 20:21:54 GMT
American Racing Spectre's
Or at least that is how they were sole here in the states. Common on Datsun 510's and 240/260Z cars.
Probably 4X114.3
craig1010cc
Club RR Member Number: 35
What are these wheels?craig1010cc
@craig1010cc
Club Retro Rides Member 35
Feb 14, 2012 22:40:04 GMT
but you could get them welded and redrilled? looking at the holes, could they be multi-lug?
Feb 14, 2012 23:13:03 GMT
Ditchdigger is spot on there, Google proves it. Also, this from BaT. 1966 Datsun 1600 RoadsterAs well as these on an MG B GT Looks like they were available in quite a few different PCDs
Porsche
West Midlands
Kev from B'ham.
Feb 15, 2012 12:51:45 GMT
Here's the sellers reply...
Hi, we have checked the PCD on the holes. It looks as if the holes have been opened up a bit to fit something they didn't fit. The holes are approx 11/16" dia and the PCD is between 3 15/16" to 4". We think they came in to the U/K with a Mk1 Sprite USA import but not sure. Hope this helps. Thanks.
....so, I think you're all spot on.
I think I'll arrange a meeting with him an see what I think then.
Feb 15, 2012 14:51:04 GMT
well if you can find out what pcd a mk1 sprite is, someone on here will know then you will have a better idea of if they will fit.
What are these wheels?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Feb 15, 2012 15:16:24 GMT
Sprite is 4x 3 3/4" aren't they? Possibly been ovalled to fit on 4x100 but could be forty.
Feb 15, 2012 15:21:51 GMT
Sprite is 4x 3 3/4" aren't they? Possibly been ovalled to fit on 4x100 but could be forty. 4 x 4" - same as A30, A35, A40 Farina, Minor and all Spridgets
Feb 15, 2012 19:40:28 GMT
Ahh! Unilug. That is what that style of mounting was called in the 60's and 70's Slots like this That require special washers to match your PCD and "mag lugs". Like these Some were round, some were oval. Heck some steel wheels just used a flat bottomed bolt/nut and no washer since there wasn't a conical seat. Finding the hardware might be a challenge. A machinist could make some if all else fails.
Dez
Club RR Member Number: 34
What are these wheels?Dez
@dez
Club Retro Rides Member 34
Feb 15, 2012 19:50:39 GMT
id put money on em just being 4x4" that someone had a file to to make em fit 4x100, given how wobbly them holes look.
RobinJI
Feb 15, 2012 19:59:36 GMT
I'd tent to agree with Dez there, sounds likely that they're 4x4, ovaled to fit 4x100. The definitely look like the holes have just been attacked a bit by hand, rather than originally being uni-lug.
Feb 15, 2012 21:21:07 GMT
if they are 'unilug' which tends to be mainly an american expression (i think) then Raceways of Donnington will probably be able to help you out with the hardware to fit them. www.raceways.co.uk/
1980 Derby GLS 1992 Rover 216 Gti - Sold 2006 Hilux - Sold (boo hoo) need a 2wd pickup. Anyone? 2009 Avensis Tourer - Gone 1993 Mk1 Golf Cabby 1983 mk1 golf. Project rust bucket 1998 Toyota Corolla. Project crash repair 2007 Volvo V70. Daily for sale!
Looking for a winter project - any suggestions?
mikeymk
'85 Polo Coupe S 1.6 16v
Feb 15, 2012 21:51:32 GMT
Look like a reasonable offset (any rwd wheel is gonna poke on a Vauxhall though), but not so good brake clearance. Fwd calipers stick out quite proud of the hub face, so once you've factored in spacers too, expect them to poke a bit.
Porsche
West Midlands
Kev from B'ham.
Feb 15, 2012 23:09:47 GMT
Thanks for the advice, all. After reading all the replies, I think I'll give these wheels a miss and look for some others that will be more suitable.
