craig1010cc
Club RR Member Number: 35
Jun 27, 2008 14:25:46 GMT
About 10 years ago whilst visiting my uncle he asked if i would like the twin SU's he had fitted to his 850 mini back in the late 60's/ early 70's? Of course said i (expecting a set of cooper twin 1 1/4's) and he came out with these I was having a sort out of boxes in the new lock-up and found them again and thought it was about time i found out what they where. Any idea who made them and what they where originally for? Cheers Craig
Davenger
It's only metal
Club RR Member Number: 140
can you identify these carbs??Davenger
@dminifreak
Club Retro Rides Member 140
Jun 27, 2008 14:31:12 GMT
Well, they look like inch and a quater SU carbs, but I've no idea what the manifold is for
Jun 27, 2008 14:37:46 GMT
Definitely SU.
I think they are H2's rather than the later and more normal HS2.
Jun 27, 2008 14:38:37 GMT
Well, they look like inch and a quater SU carbs, but I've no idea what the manifold is for It's a conversion jobbie to save having to split the exhaust manifold
craig1010cc
Jun 27, 2008 14:46:38 GMT
I think your right that they are H2's (def not HS2's) and as such pre-date most (if not all) mini's so i am wondering what car they where originally aimed for
Jun 27, 2008 14:51:28 GMT
I think your right that they are H2's (def not HS2's) and as such pre-date most (if not all) mini's so I am wondering what car they where originally aimed for There's a pair on evilbay now, listed for the sidevalve lotus 7
Jun 27, 2008 14:58:04 GMT
Might be H1s, which are 1 1/8 flavour, as fitted to Frogeye Sprites.
Last Edit: Jun 27, 2008 14:58:15 GMT by Paul H
Seth
Jun 27, 2008 15:00:52 GMT
AUC738 carb comes from an early Minor Van.
They're actually H1 carbs so 1 1/8" not the more common 1 1/4"
They look like mirror image ones though so does the other carb have a different number?
Excellent looking set up and definitely aftermarket I'd have said. The manifold flange looks like a 1 1/2" SU one. Could be interested in your selling (for what I don't know!)
craig1010cc
Jun 27, 2008 15:09:48 GMT
I think your right that they are H2's (def not HS2's) and as such pre-date most (if not all) mini's so I am wondering what car they where originally aimed for There's a pair on evilbay now, listed for the sidevalve lotus 7 Have you got a link for them as i can't find them??
craig1010cc
Jun 27, 2008 15:13:11 GMT
AUC738 carb comes from an early Minor Van. They're actually H1 carbs so 1 1/8" not the more common 1 1/4" They look like mirror image ones though so does the other carb have a different number? Excellent looking set up and definitely aftermarket I'd have said. The manifold flange looks like a 1 1/2" SU one. Could be interested in your selling (for what I don't know!) I'll have a look at the weekend to see if the other carb has a tag (I don't remember there being one). the carbs are a mirrored pair and only 1 of the carbs has a choke lever on it. I would consider selling them,, but i too don't know what they are worth
craig1010cc
Jan 20, 2012 11:24:09 GMT
Digging this thread back up in the hope that someone might recognise them (or point me in the right direction )
craig1010cc
Jan 20, 2012 12:31:52 GMT
I am wondering if thet where fitted to the A series powered series 1 lotus 7's in the Lotus Seven "America" spec?? Can't find any pic's, only a description Compression ratio 8.9:1. For the US market ("America" model), Austin Healey Sprite (Mk. 1 Frog-eye) with twin SU H1 carburettors on special manifold developing 43bhp at 5,200rpm.
robg2
Jan 20, 2012 20:35:42 GMT
Can't be from an A series - that has a two port head and there wouldn't be space for two of these assemblies (one for each port) - and 4 carbs would be nonsense.
But maybe the manifold in your photo would bolt onto a standard single carb manifold, ie two carbs into one manifold then another manifold then the head. But that wouldn't make much sense either...
I think it must be from a single port engine, or maybe a V or flat. Beetles have something like this don't they?
Or... maybe they were fitted to a supercharged engine, ie two carbs into one manifold into (single port) supercharger into inlet manifold. That's more likely. Superchargers weren't uncommon pre-war, so are they from something like a 30's MG?
craig1010cc
Jan 21, 2012 17:22:27 GMT
Dunno, I think that they are most likely a bolt on conversion for single carb'd engine as the separate manifolds would have been hard to get hold off and expensive. Anyway, those going to the autojumble tomorrow can have a butchers at them (or even buy them )
Jan 21, 2012 18:06:53 GMT
I owned an Austin 7 special a few years ago and they look like something from 1950's that was fitted to such. "At the end of the day" I wouldn't be surprised if they were a cheap and cheerful twin carb set up for an 850 Mini - as they were originally fitted !
Paul H
Jan 22, 2012 12:49:06 GMT
Id say they are meant for the willment overhead valve conversion on ford prefects ... they used to convert them from sidevalve to ohv and fit twin su carbs
its not a rust hole its air conditioning
Jan 22, 2012 13:28:53 GMT
Id say they are meant for the willment overhead valve conversion on ford prefects ... they used to convert them from sidevalve to ohv and fit twin su carbs I had to Google Willment as never heard of them before but don't think that is what they are as you can see below - Paul H
craig1010cc
Jan 25, 2012 12:19:37 GMT
I owned an Austin 7 special a few years ago and they look like something from 1950's that was fitted to such. "At the end of the day" I wouldn't be surprised if they were a cheap and cheerful twin carb set up for an 850 Mini - as they were originally fitted ! Paul H The thing that makes me think its not for an A series is that the carbs would have been from a bug eye sprite, so you would have thought you'd have fitted the inlet and linkages as well? But something for a 50's special is what seems to sit right in my head.
