Apr 24, 2011 14:01:19 GMT
Now, this is definitely not a normal RR post so here are some nice pics before I start on my dull topic - Right, now I've got those out of the way, if you have no knowledge or interest in babies, you may as well stop reading, this will bore you. I'll try and make this as straightforward as possible - - Baby on the way - Want to be able to take baby out with us occasionally in the Triumph, otherwise I fear I'll hardly ever get to use it - Triumph now has no rear seats or rear belts Trying to figure out how to fit a baby seat in the back. 1) I could put the rear seats back in and mount baby seat fixed with rear belts. Lots of people have done this but complained that the baby seats never fit all that well. It will also be pretty tight for space with baby seat on top of rear seat. 2) I am thinking about using an Isofix base, mounted to some bespoke mountings on the car body. I presume this can be done somehow, by someone with metalworking skills. This base would then be permanent to the car and the seat can just be clipped in and out. Potential issue with this is that the baby seat would in effect be 100% secured via the base and not leant against a rear seat. Would this make the seat any less secure? Any ideas or experience welcomed. Cheers
Apr 24, 2011 14:08:01 GMT
Fit the rear seat, put the adult passenger/s in the back and the baby seat in the front seat perhaps? I gather some people prefer to have the baby in the front seat than the back.
Apr 24, 2011 14:09:21 GMT
Hmm if the toledo is anything like my 1300 which it really ought to be being the same body shell! You will find that there are existing seat belt mounting points. At either end of the rear parcel shelf and 2 in the centre under the seat phob. The third mount needs to be installed as they where designed for 2 point diagonals. Anyway what I'm getting at is there is sufficient space to mount an inertia real on top of the parcel shelf. Make a lower mount through the wheel arch and use the existing centre mount. Then you should have a seat belt that is as effective as a moderns. However do bear in mind that once seat belts are installed they become MOT testable and therefore rust that may not previously have been a fail could well now fall into a prescribed area.
Paul
Apr 24, 2011 14:55:11 GMT
I don't see why a permanant seat mounting is an issue, your supposed to pull them down tight so they don't move anyway, i would say an ISO mount welded directly in is probably better, the idea is that the seat does not move, bubs should be strapped in and in the event of anything bad happening, the seat protects and prevents any whiplash type injuries hopefully.
we had a lot of trouble finding a modern seat that would fit the rear belts in a Mk2 Astra securely and that was 9 years ago, so even if you refit the rear seat and the belts, you may still have problems.
Apr 24, 2011 16:36:38 GMT
I don't see why a permanant seat mounting is an issue, your supposed to pull them down tight so they don't move anyway, I would say an ISO mount welded directly in is probably better, the idea is that the seat does not move, bubs should be strapped in and in the event of anything bad happening, the seat protects and prevents any whiplash type injuries hopefully. we had a lot of trouble finding a modern seat that would fit the rear belts in a Mk2 Astra securely and that was 9 years ago, so even if you refit the rear seat and the belts, you may still have problems. Exactly what I was thinking, why do I need a rear seat? If I can fix the Isofix direct to the floor, that will be the safest and most compact option.
Apr 24, 2011 18:44:42 GMT
First off, congratulations on the impending arrival ;D ISOFIX is only a pair of U shape loops at the point where the seat back and base join, the baby seat locks into this and then rest on the seat base and back to steady them. You'd need some frame to support the whole seat anyway in the same way a seat base and back does. We bought a base that uses a 3 point belt to fasten it down, then the carrier locks into that, takes a couple of minutes to fit it into any car (we swap ours from Passat to Camper to Beetle to Lupo) and then 5 seconds to click the seat in place. Ours has a height adjustable leg that braces to the floor to steady it as well, fits in all the above no problems. Personally I've never had any trouble fitting the seat and getting it nice and solid. Failing that I just lob my daughter in the boot of the Camper on a blanket and hope that she can hang on!* *I'm joking, she was helping me fix the tailgate lock
Mar 17, 2012 21:51:01 GMT
Thought I'd bump this up rather than starting a new thread to keep all the info together A few questions regarding sprog seats in old heaps classic cars.... What's the deal with retro fitting ISO mounts - is this a potentially better idea than using seats / travel system base unit that is secured by the seatbelts, assuming it can be done properly, or do the Feds get very upset (e.g. due to lack of type approval)? Also, can anyone recommend any specific seats / base units that work well with static belts (I believe the length of the belts may be an issue), or alternatively, which ones don't work? Oh, and the reason for asking - Mrs H is expecting twins at the end of the summer
Last Edit: Mar 17, 2012 21:52:42 GMT by Paul H
Mar 17, 2012 22:00:10 GMT
Mrs H is expecting twins at the end of the summer Crikey Moses - congrats! ;D
WHat pOG said is true - I used to fit them and to be honest, I wouldn't take anything other than a Maxi-Cosi. Maybe a Recaro but it's twice the price and not quite as good fitting. Maxi Cosi do seat-belt mounted bases that the seat then clips into, rather like Seths example above, but also without the floor-steady.
FWIW I found in the back of an E46 BMW I'm breaking, torx-bolt mounted isofix loops, so a) that must be legal and b) it means they can be removed and mounted to another floor with the addition of a welded in captive nut. Might make things easier in some situations.
Mmm, this thread has reminded me that I still haven't completed my intention and got the Toledo child friendly. I did buy an isofix bar to fit though, came as a pair actually and only need one, so one is available. Bolts directly to the floor, I will get a picture up. Not sure if I will fit now as I've actually gone away from isofix for the forward facing seat. In terms of seat belted mounted seats, I've actually just bought one based on recent safety tests. It's been shown that a 5 point harness can actually lead to some pretty horrible spinal injuries, as the baby is held tight from the neck down, meaning the neck takes the impact. The range from kiddy go a different route, difficult to explain so just look at their site. We got the energy pro. I mention it because it would seem to work well with a lap belt because of the way they are secured, although the company won't committ to that - I've asked.
I'm just entering a world of pain with this as I have a 4 year old (5 in April) and a car with no belts at all... Not sure how I'm going to deal with that one. Possibly that one gets to be a non-child car.
As I understand it there is no particular "legal" issue with how you fit ISOmounts or anything else. However... In the even of an accident should any injury befall your little un you will have to deal with your own guilt, your partner's accusation and satisfying the forces of law if there is any suggestion it was not done properly.
I would say a well bolted mount will be as good as a well welded one and better than a badly welded one. Consider the metal where you intend to mount it - you may want to weld in a larger plate as a load spreader so your bolts/welds don't just pull through in the event of a rapid deceleration event.
I note a number of seat makers go to the bother to say "not suitable for lap belts" I used a really nice seat from Britax which worked from age 1 - 4 pretty much which specifically said OK for lap belts.
I'm really not sure what the safety issues are re: child in front or back? Its traditional wisdom that kids should ride in back but is there any actual grounds in safety for this? 70's 80's American stuff has 3 point belts in the front and lap belts in the back so when Isabel got too big for her lap-belt chair and I couldn't find a booster seat thing which said it was OK with lap belts so Isabel rides up front now.
I think seats in older cars are more upright than moderns because sometimes it does seem to be tricky to get a child seat to sit nicely against the car's seat in older vehicles.
Because its almost impossible to get a 4, 5 year old to sit still in the approved safe position in the child booster seat I'm wondering if a booster cushion type thing may not actually be safer. Possibly with the lap belts in the back? I dunno. Does my head in trying to think around these issues.
Problem being that the manufacturers will give you no advice other that what their product was tested against, and if you go on a forum for parenting or general motoring you just get screamed at to buy a modern "safe" car before you kill a bus load of nuns and kittens (and forums for older / modified cars tend to go with the "impale the child on a spike on the front of the car, we never had any of this safety nonsence when I was a kid and I survived OK")
So finding good actual advice on child safety in older cars is hard. (and you and I both need to recognise its a compromise, I think we know that though)
For those of you fitting ISO fix bars - our maxi cosy base had provision for both ISO connectors and a belt, the mrs scenic 1 has isofix connectors in the seat but because the post stands on the lid of a storage box you are not supposed to use them. A bit of wood under the post sorted out one problem and I used the seat belt as well as the isofix stuff just to be sure. I would recomend if you have a belt - even a static one, to fit it AS WELL as the isofix stuff, better to be safe than sorry. When I was a nipper my baby sister and I had child seats in the back of my dads triumph 1500 tc but as we sold it in 1983 I am sorry but I cant remember much except for the pain of sitting on sun heated vinyl! I am another fan of the Maxi-cosy stuff, (Now 2yrs ) has a maxi cosy and a recaro forward facing seat and seems to be much more comfy in the recaro but it cost almost as much 2nd hand as the maxi did new! Good luck with all the little ones people.
The feller I bought the desoto off had a little un.
He used a ratchet strap... (tbh, it looked awful but was certainly solid)
polo6n1600i
All I need is WD40 & Duck tape!
Mar 19, 2012 12:36:25 GMT
One of my friend has a stripped out Mk1 Firsta XR2, when his Mrs got pregnant he had a childs seat mount welded to the floor & used that to mount the baby seat too. It was more secure than anything I'd seen & it was check over my an MOT man too.
2002 Vw Polo 1.9 TDI sport - Daily Diesel 2006 Vw Passat 3.2 v6 estate - family wagon 1990 Rover Montego 1.6 LX - Project 41
Seth
What AlistairK said regarding ISOfix. But then fitting seatbelts to a car that doesn't have any mounts from the factory is similar in that there's not going to be any stress/crash test data for the chosen position. I managed to get hold of the actual ISO standard (may have changed by now) so that the mounts I made were as close as possible to that. I think there is advantage to a later forward facing seat with ISOfix too, even when the child is restrained using the car's three point belt. In the event of a front end impact the seat has its own restraint and is not effectively crushing the child between it and the belt. I don't think it would be easy to fit ISOfix points into an old estate though, due to the folding of the back seat. I imagine moderns have the ISOfix points attached to the seat itself so that they fold with it.
It is most convenient to get a rear facing seat that clips on to a base as it means not having to adjust the static belts everytime. But it is useful to get one that has the provision for going in a car using a seatbelt without the base, so that it can be used in another family member's car or a taxi or whatever.
If you were to get seats/bases that can be fitted with just a lap belt then you could fit the lap belts additionally as well as the normal rear static three points, so that there is no problem with needing belts of different lengths depending on carrying the children or adults.
If you do need a belt re-webbed to be longer/shorter then I can recommend Quickfit SBS in Stanmore. They did one for us and I have used them several times now.
I've heard nothing but good about *that* Quickfit I think I may speak to them about the belts for the Chrysler rather than going to Securon / Scrapyard which are the other two obvious sources of belts. Despite it being "legal" with no belts and me being the sort of person who forgets to belt up I am not comfortable having no belts at all of any type in there.
