keyring
Club RR Member Number: 47
Mar 29, 2011 22:10:31 GMT
hey guys, not posted for a while Just wondered if there was anyone near west lothian/edinburgh that would be up for doing a few jobs on my hillman imp so I have a chance of getting out for passing my test? I need inner and outer arches welded in on both sides at the rear, some metal shaped and welded in on the lower rear quarters, same on the scuttle panel, and around where the windscreen in. Also need a small plate put in right at the front of passengers sill. If anyone can help please post in here or PM me really appreciated any help, regards, Keyring
Last Edit: May 5, 2011 22:58:22 GMT by keyring
foxy99
Mar 30, 2011 22:37:11 GMT
I'd luv to help out mate as I too have a Hillman Imp and I have just been welding another car up to get thru an Mot and its a worrying time.
I'm a bit far away tho and short of time. Is your car a daily driver or will this be its 1st MoT in years?
The reason I ask is that the MoT guys don't care what it looks like so any patch over rust will often let you continue enjoying using your car however if you are doing a resto you probably want it to look good and this takes a lot longer.
If you need inner and outer sills that could take weeks to do well or days to do badly.
Any pics?
keyring
Mar 31, 2011 23:40:44 GMT
thanks man first MOT in ages, only turned 17 today so not a daily driver yet. sills are all solid apart from needing that small patch right at the front, think i may have found a person to do it, i shall keep you updated, thanks for the reply though, appreciate it
keyring
Apr 15, 2011 11:19:07 GMT
bump
super66
Singer Chamois Coupe 1969
Apr 15, 2011 12:07:00 GMT
Good luck with finding someone to do the work, would be great to see some pics of your imp, as a imp owner myself!
Apr 18, 2011 15:02:50 GMT
I am in cowdenbeath just over the bridge and just passed dunfermline and would be able to do the work for you if your still needing it done give me a call on 07967945610 cheers wullie
Last Edit: Apr 18, 2011 15:04:39 GMT by wjgautos
keyring
Bump.
how about glasgow side? would trailer it further if i can get a good price for the work
