May 31, 2006 15:19:53 GMT
I'm just having a potter around on ebay. Looking at what affordable wheels i could throw on the MR2 - not sure what the offset is, something a bit wider would be nice. the 4x100 tresure chest hunt is new to me, any suggestions off the currents lots? I considered new Wellers like blownimps yet 13's might look wierd when standard is 14 inch
May 31, 2006 15:36:56 GMT
They're 4x100?
*ponders*
*n
May 31, 2006 15:40:17 GMT
Eeerrrrrmmmmmmmmm.................................No! I think they are 4x114. Like most Toyota's
May 31, 2006 15:49:48 GMT
They're 4x100, ET35-38, I'm pretty sure. Superleggeras work well: but they might not be cheap. I also saw one recently on what I think were Corolla T-Sport alloys, which worked well. Mk3 MR2 alloys seem to be popular, too. These could work...
Last Edit: May 31, 2006 15:59:22 GMT by angle
May 31, 2006 16:20:26 GMT
Interesting. I will eventually give the whole car a crazy makeover with any luck. Mk3 wheels and yaris jobbies are a popular, or well known additon with the mk1ers. I'd chuck wellers on if they were 14's or 15's, Maybe 13's being steel might clear the brakes and not look too daft with tyres.
4x100's are quite popular, so maybe theres some random, less obvious bad boys i could throw on.
May 31, 2006 16:24:33 GMT
they're not superleggeras... clickyI heartily recommend those red jobbies off a Pulsar GTiR that CappucinoCruiser had/has. *n
May 31, 2006 16:26:55 GMT
I did spare a thought for those actually. what would be really nice is these ;D would have to jack it up then probably!
May 31, 2006 16:33:33 GMT
Nah - just fit smaller rubber...
what's the going rate for a good mk1? Hows insurance on them?
*n
May 31, 2006 16:42:10 GMT
A 'good one ' is over 1k typically, only a matter of time till the tin worm gets it still £500+ should get something ok if you don't mind sorting the rust. thats how i see it anyway. I've only got quotes for it as a second car, reasonable though a £100 20% less that the V8 3door, but thats obvious! cheap but outta budget - from portugal..
May 31, 2006 16:46:04 GMT
Compo MOs = instant win, irrespective of application.
*n
May 31, 2006 17:51:53 GMT
(win) are these those TR6 steels, or am i barking up the wrong PCD?
May 31, 2006 19:53:06 GMT
hows about e30 steels? if those tr(?) wheels float your boat. 6jx14" or if your lucky, 6.5j (may even be 7j, can't remember) from a 325ix e30. if 13s fit, e21 mahle cross spokes for that retro J inspired look
May 31, 2006 19:56:49 GMT
Get your Harris on sausage bay and search for Mattig - felgeln aplenty in diameters, widths and offsets to taste.
*n
May 31, 2006 19:57:26 GMT
good ideas there. I might even, shock horror just paint the 'tear drops'...
interesting 4x100 cheap wheels DarrenW
@darrenw
Club Retro Rides Member 74
May 31, 2006 20:00:23 GMT
(win) are these those TR6 steels, or am i barking up the wrong PCD? Passat G60 Steelies? Not sure...
May 31, 2006 20:01:00 GMT
hmmmmmm
May 31, 2006 22:02:35 GMT
(win) are these those TR6 steels, or am i barking up the wrong PCD? Passat G60 Steelies? Not sure... their not G60s i don't think. but on that note, any 4 bolt vw rim will fit by the sounds of it
Glenn
SteB
May 31, 2006 22:19:25 GMT
May 31, 2006 23:03:21 GMT
Some beautys there SteB. Don't say owt but i'll be in asconadaz's boot for the next mission. SSSssshhh
The following is from my own experiance...
MR2 MK1's wheel size is:
PCD: 4X100, Offset: 35mm - 38mmm C Bore: 54
The same dimensions as Fwd 1980s and 1990's Toyota Corolla, Paseo, Starlet, Yaris.
The MR2 MK1 is the only rear-wheel- drive Toyota (to my knowledge) that has a a PCD of 4x100 all other rwd Toyotas (and Datsuns) of the 70's and 80's are a PCD of 4x114.3mm (4.5inch).
Warning! ... Although some Volkswagen are PCD of 4x100 the offset is around 28mm so would be totally WRONG!
Also as a side note (emergency measure) 1980 and 1990s Ford wheel nuts/threads will fit 1980's Toyota (although Ford Wheels a PCD 4X108 !!!) threads/nuts ...ALTHOUGH I recomend you make sure nut is a correct fit for wheel
