Feb 28, 2011 21:21:15 GMT
Any clutch or prop related work on a DAF means engine out. B body front panel, bonnet and tiebars need to be removed to do that. I challenge anyone to not swear when trying to refit them bonnets on their own!! Changing the cross resonating silencer on my 44 is an ![](http://www.wired.com/images_blogs/underwire/2009/11/fox_60.jpg) of a job!! Theres not enough clearance for a socket, a spanner needs to be at a stupid angle and the worst part is getting to the nut on the other end is just as bad
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
MR2 turbo alternator change. Comes off fine, never leaves the engine bay.
Vectra V6 spark plugs. Easy to see, impossible to access.
andyf
South West
One I`m doing at the mo. Cylinder head studs on a TR7. 5 bolts (which all come out easy), then 5 studs. All the nuts came off easily, leaving the studs still in place. 2 studs out eventually, 3 still in, one of which is now snapped off level with the head. They are corroded into the block and the head. I started it end of last year. Just take me a few hours thought I. ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png) Why they didn`t use 10 bolts is beyond me.
1980 Triumph TR7.
CIH
IIRC Dolly 1850 heads stick to the blocks too ?
glow plugs on a citroen C15 van - ask silvermachine - 3 hours later, manifold, wires & pipes all over the floor & copious swearwords later he did it, but it was a barsteward lol!
I have determined that my sole purpose in life is to serve as a bad example...
CURRENT vehicles - '84 Saab 900 turbo classic, '93 Nissan 200SX S13, 2021 Volvo V90 Inscription.
Marina van clutch slave cylinder replacement. If I met the bloke who designed that he'd get a dig in the chops.
Exhaust manifold on a BX 16v. Because of the 16v head, the manifold is tight up against the bulkhead. There isn't enough room to remove the studs (assuming you can find 27 UJs to fit to the socket to get it undone in the first place).
glow plugs on a Citroen C15 van - ask silvermachine - 3 hours later, manifold, wires & pipes all over the floor & copious swearwords later he did it, but it was a barsteward lol! yes that was a complete monkey nob to do... like finding panels for a chevette, but a lot faster!
![](http://i24.photobucket.com/albums/c38/themostamazinggeezer26/04e07811.gif) 2006 Audi A3 2003 Fusion 2 looking for a project....
Taking the engine out of a beetle! 4 bolts!!!! Ones a little bit tricky to get too! Can take up to 20 mins to take the engine out on one of them!!!! Ruddy German design!
;D (sorry)
Remember the days when sex was safe and motorsport was dangerous. Vintage bling always attracts pussy. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
340s aren't bad. The gearbox/diff unit at the rear weighs about 50 kilos though and has to be lifted as one object. Too much for stringy people like me!
bortaf
Jun 25, 2011 12:09:11 GMT
Jag Straight 6, try getting a head off the block when it's been on there for 40 years, i scrapped 2 420 engines compleat last week cos after 5 hours all i'd done was snap the stud extractor tool with me breaker bar and shatterd the head with a sledge hammer LoL
R.I.P photobucket
col
wut
Jun 25, 2011 12:32:58 GMT
on my old fiat stilo changing a bulb was either a matter of taking out the battery tray, fuse box, washer bottle and airbox or taking the front end off. i opted for the front end.
dubzi
Jun 25, 2011 12:41:22 GMT
Rear spheres on self levelling mercs.... Easier to cut the pipes and fit new ones but even then barely enough room to turn the spanner or get your fingers in to start the thread off.
Happiness ain't at the end of the road. Happiness is the road.
Jun 25, 2011 15:42:40 GMT
IIRC Dolly 1850 heads stick to the blocks too ? Yup. This is why I bought a replacement engine rather than fight with my cylinder head anymore, after 5 hours fighting, I gave up... Still have the broken engine though under a sheet. One day...
Jun 25, 2011 16:19:42 GMT
changing the front UCA on my passat
instead of having the bolt so it can be removed without taking the whole strut out, they have put it in the other way so you have to remove the whole shock, and the sizes are 16mm and 18mm bolts which i don't have many tools that size,
so after removing loads of bolts etc i had to put it all back together and wait until tomorrow, curse word!
megzy
Jun 25, 2011 16:25:47 GMT
turbos on a td6 land rover discovery. Body has to be removed to get access to them :S
Jun 25, 2011 19:03:49 GMT
the clock in an avantime is horrific,
the one in my mums has gone and we went about finding out how to replace it and after looking in the manual it says to remove the dash.
look up how to remove the dash and it needs the front end removing then parallel bars bolted to the body as it needs removing at a steady and uniform 15degrees up from level.
needless to say you could never tell the time in that car.
ewokracing
Snuffling for food in a river
Coming from working on 70's Mazdas where nearly everything was nice and easy to get to...
THREE DAYS to change the rubber engine mounts on a Rover P6b with Australian spec aircon.
There's no way I'm even touching the rear inboard brakes...
I can add removing an Alfa 156 gearbox to the list. On my own on the drive it was a 4-day nightmare. 3 months on the scars have nearly healed and the fingernail I surgically removed has almost grown back.
The guy who runs my local garage was telling me that they attempted a clutch slave swap on a Renault Espace. This requires removal of the dash. After several hours they had a massive pile of self-tappers but no other obvious further progress. They subbed the job out at that point.
Jaguar S-Type 3.0 SE
Kai
Installing the stock oil feed for a CT26 turbo on a 7M-GTE, irritating banjo bolt that won't line up!
