Feb 14, 2011 18:24:30 GMT
MMmmm-kay.
I just shoved the space saver onto the Cadillac and I have to say, they'd make neat front-runners. Now Other than "inflate to 60PSI" theres nothing I spotted on the tyre to suggest its not a regular and normal tyre. I know the ones I've seen on EU spec motors are plastered with "max 50 mph" and so forth.
Any reason we can think of I can't run a pair of them up front on a car as a budget way to get propper skinnies?
Space saver tyres...retrowagen1234
@GUEST
Feb 14, 2011 18:27:02 GMT
MMmmm-kay. I just shoved the space saver onto the Cadillac and I have to say, they'd make neat front-runners. Now Other than "inflate to 60PSI" theres nothing I spotted on the tyre to suggest its not a regular and normal tyre. I know the ones I've seen on EU spec motors are plastered with "max 50 mph" and so forth. Any reason we can think of I can't run a pair of them up front on a car as a budget way to get propper skinnies? Strange you should say this. My dads looking for some new 125's for the bug. Currently on michelins which are expensive as fook. Now my mums 207cc has a 125 space saver (albeit in 16") Continental make some retro looking 125 space savers in 15s too. Only just came in from swapping wheels around to sort the puncture on my mums 207 so just seen this BUT they do say in large letters on the sidewall. TEMPORARY USE ONLY
Feb 14, 2011 19:11:20 GMT
i put one on my golf and forgot the next day and when i hit a corner like i would with a normal tyre it just peeled straight off the rim! i now wouldnt even use one as a spare....
SPOTS MUSH!
60six
Feb 14, 2011 19:21:59 GMT
Very scary tires - Different kind of rubber compound which has very little grip - and they need to be inflated to extreme PSI. Never f**k with space savers - Made driving my bug very vague indeed.
Dez
Club RR Member Number: 34
Space saver tyres...Dez
@dez
Club Retro Rides Member 34
Feb 14, 2011 19:26:52 GMT
MMmmm-kay. I just shoved the space saver onto the Cadillac and I have to say, they'd make neat front-runners. Now Other than "inflate to 60PSI" theres nothing I spotted on the tyre to suggest its not a regular and normal tyre. I know the ones I've seen on EU spec motors are plastered with "max 50 mph" and so forth. Any reason we can think of I can't run a pair of them up front on a car as a budget way to get propper skinnies? Strange you should say this. My dads looking for some new 125's for the bug. Currently on michelins which are expensive as fook. Now my mums 207cc has a 125 space saver (albeit in 16") Continental make some retro looking 125 space savers in 15s too. Only just came in from swapping wheels around to sort the puncture on my mums 207 so just seen this BUT they do say in large letters on the sidewall. TEMPORARY USE ONLY tell ya dad to go to 135/70R15. same rolling radius, indistinguishable really, and a pair of hankooks is about £50!! its what i fit to my customers bugs when i induce much lowness in their undercarrage........
Feb 14, 2011 19:54:19 GMT
Also, an MoT fail (even if you have a matched pair on the same axle). Not allowed to run spacesaver/temporary tyres except as temproary.
Feb 14, 2011 20:53:53 GMT
How about putting proper frontrunner tires on them, i think i've never seen that done!
robg2
Feb 14, 2011 21:05:18 GMT
Size is one thing, but don't abuse the load and speed rating on tyres or you will be risking a failure. Space savers are generally limited to 50mph (M rating I think), but I've seen a few rated to Q (80mph).
I like the thinking though...!
