Engine ideasblobbletec
@GUEST
I am looking to freshen the engine and bay in my ascona, it needs a bit of a make over as it was converted 6 years ago and it shows, rubbed through wiring, poor fuel consumption, rough running, rusty bits...blah blah blah..you get the idea So for me the best idea would be to rip it all out and start from fresh, but i cant decide which route to go down The budget is around a £1000+ I could spend all the money on the current engine, re-build, cams, head polishing, ecu re-map.. get it close to 190hp ish but id soon get bored of that.. i really need a turbo in my life.. the noise.. the power.. turbo it with a stand alone ecu, megasquirt or similar, aftermarket manifold and t28 turbo could come within budget..? Or just buy a c20let.. but these are getting rare and demand high prices,, maybe more than my budget can stretch to.. Any ideas or help would be most appreciated.. or am i shooting way above my budget..!?
z20let's and z20net's seem to be going for roughly 7-900 quid recently
passmethegun
"A closed mouth gathers no feet"
ca18det's are pretty cheap, even a s13 mot fail would be way less than 1k and it'd have all the wiring, gearbox, prop etc. my 2 cents
pass me the gun and ask me again........
Manta 400R Coupe (in lots of bits)
Manta Exclusive Coupe (in less bits)
BMW 320d (one big bit)
Gilesy
For a grand you could get a very well looked after Saab9000 with a B205/235 (2.0/2.3) lump in very good order. It's turbo'd straight out of the box, massively tunable (proven over 400bhp on the standard internals) and it'll come with the factory management - Trionic5, very very remap friendly) - so you won't need the expense of MS etc. Plus, by the time you've sold the other bits of 9000 you don't need, the running engine will be free, and there's not extra cost in self-turboing a.n.other engine.
1991 Mini Neon - Gone 1991 Polo Coupe - Gone 1987 Scirocco Scala - Gone 1991 Scirocco GTII - Gone 1980 Mini 1000 - Gone 1998 Fiesta - in flux 1999 Saab 9-5 2.3t SE - the tidy, blown Swedish modern
V8
Omega v6? Plenty of them filling out scrapyards now. Has rwd box already on it! Quite a short, light engine so wouldn't mess the handling up like a big V8 made out of pig iron would! Doesn't pop and whiz like a turbo but has a nice V6 roar to it even when standard. If you search about a bit you could find the 3 litre version, nice!
bigsyd
the saab lumps and the vauxhall lumps the same but tha saab have stronger internals theres been a few vauxhalls converted to the saab lumps i know of... vectra with saab turbo lump and a few novas/corsas and even v6's used too......
2001 astra sri {soon to get a retro inspired make over)
1990 golf(put away for now)
Not all V8's are heavy and lazy, they often just feel that way 'cos they are in lardy card with tall gearing and auto boxes, no one ever said an AC Cobra or TVR was a lazy drive and modern ally V8's are not that heavy compared to an iron turbo 4 pot.
oldskoolmule
Nova SR 1.6 16v coming soon :)
C20LET's aren't that rare and the common price seems to be £1000 have a look on some vauxhall forums (migweb/png/vauxsport)
4 litre jag straight 6? the AJ16 is bullet proof, makes over 250bhp and you can buy a whole car for 300 quid, you can find manual ones as well, they weigh about 230kgs i think, so not super heavy be an unusual conversion.
Not all V8's are heavy and lazy, they often just feel that way 'cos they are in lardy cars with tall gearing and auto boxes Exactly this. Put that Lexus V8 into a lighter car and put in some short diff gears and then see how lazy it is. LS400s apparently come with a 3.26:1 final drive, so a set of 4.11s should wake it up. They would be happier at revs than a traditional small-block as well.
`state
Yorkshire and The Humber
Saab lump every time for me,its what my chevette estate is getting.Although your xe shouldent be running that badly.In my cav i get 35mpg to 45mpg depending how i drive.Have you got the lambda sensor connected? Any fault codes? They`re a brilliant engine so think yours just needs alittle looking after. Or turn your xe into a let.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
joe90
3.0 24v Carlton or Senator, rwd and pretty quick.
Bryan
Dec 10, 2010 10:31:57 GMT
the saab lumps and the vauxhall lumps the same but tha saab have stronger internals theres been a few vauxhalls converted to the saab lumps I know of... vectra with saab turbo lump and a few novas/corsas and even v6's used too...... Does this mean that a RWD Vauxhall box will bolt onto a Saab engine? Or if not, are there any that are a direct bolt on without having to have an adaptor plate made?
froggy
Dec 10, 2010 10:55:22 GMT
another saab vote from me . buy a cheap lpt 2.0 9000 and keep the engine and loom ecu etc . keep the speedo unit and the valve from the evap canister and the stock management will work properly . the t25 will make 250 hp with a better downpipe and from there on its just a matter of how much power you want to make . i fitted a holset hx35 to mine with a set of 630cc injectors a 3 bar map sensor and a set of volvo t5 valve springs and it made 510hp with no drama. the 204block can cope with 600hp and the saab forums have plenty of support for home tuners.
i paid £300 for my 9000 with one owner and 70k on the clock .a good donor would be a 2.3 aero as thet have the tdo4 and with a 3" downpipe you will be near to 300hp with a re map , as you don't need the gearbox an auto aero will be a lot cheaper and they occasionally come up with auto box issues for a few hundred quid .
there is an ascona in greece with a saab lump in and I'm sure he has a buils thread on uk saabs .
`state
Dec 10, 2010 11:02:41 GMT
Think the saab lumps made between 1994-1998 will bolt straight upto the saab lump. Ive got a 1997 2.3 block with a omega box bolted on with no problems but thats as far as ive got.
froggy
Dec 10, 2010 11:05:00 GMT
the saab lumps and the vauxhall lumps the same but tha saab have stronger internals theres been a few vauxhalls converted to the saab lumps I know of... vectra with saab turbo lump and a few novas/corsas and even v6's used too...... from 94 -98 the saab used the same bellhousing pattern but thats it . the 204 /234 is a 16valve chain driven engine with twin balance shafts and an all steel bottom end with mahle forged pistons as standard . no matter how far you want to push these engines they need no fancy bits other than stronger valve springs so safely rev over 7000rpm . i pulled the head of my 2.0 to look for any signs of det as i had been running 2.6 bar of boost for a while and found nothing .the head gasket is a standard elring part and the head bolts are re useable .
