tomeyers
1990 Micra K10
Sept 23, 2010 18:05:30 GMT
Well, I have removed the bump strips from my K10 and managed to get the glue and foam off from one side using a plectrum and white spirit but it took about 2 days. I still have the other side to do and was wondering if anyone knows a remedy for removal?
I have already tried a cheap tar and grease remover and adhesive remover.
Any ideas?
Tom.
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
Removing bump strips, help!spiny
@spiny
Club Retro Rides Member 167
Sept 23, 2010 18:09:21 GMT
heat it all up with a hairdryer first, makes it a lot easier
Sept 23, 2010 18:10:33 GMT
Sept 23, 2010 18:12:08 GMT
Use an axe and run at the car, fast.
If you want to keep the side of the car reasonable, try as above, using a little heat. You can get a toffee wheel for a drill that drags all the stuff off dead easy, but they are about £20. Depends how much your time is worth!
EDIT: BEATEN and OH BLIMEY THEY ARE CHEAPER THAN I THOUGHT!
Last Edit: Sept 23, 2010 18:12:50 GMT by cobblers
Sept 23, 2010 18:16:05 GMT
TBH, once you've tried a toffeee wheel to get this stuff off, you'll never bother doing it any other way. It makes really light work of it.
rodit
Sept 23, 2010 19:26:10 GMT
Be cautious of areas where dodgy repairers have only painted up to mouldings as a toffee wheel love's destroying this.
Also don't put too much pressure on or get the area too hot with it, they will smoke though as the wheel gets hot, basically keep it moving.
Oh and try to not let it bounce else you will end up with a panel that looks like someone thought there was a rubbing strip when parking.
Best of luck.
Low and slow
Why can't i tune it?
93fxdl
Enter your message here...
Sept 23, 2010 19:50:16 GMT
a suggestion is, aswell as heat try using a piece of fishing line like a cheese wire to slice the strips off ttfn glenn
Sept 23, 2010 21:15:17 GMT
WD40 is surprisingly good at removing glue.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
alex77
Sept 23, 2010 21:37:07 GMT
lighter fluid the zippo stuff rinse well
1978 Capri MK2 Ghia Zetec
1990 Ford escort mk4
1996 Nissan Rasheen
1998 Honda CRV (my wifes)
2002 Alfa 156
tomeyers
1990 Micra K10
Sept 23, 2010 22:45:39 GMT
Thanks people
Sept 23, 2010 23:16:21 GMT
I've used a heat gun and all sorts of acetone, paint thinner etc, but the store bought tar/glue remover works best, and lots of heat. It's a huge pain tough, and next time i'll absolutely buy a toffee wheel. And remember to check so the paint behind the strips are the same colour as the rest of the car before ripping them off
