Sept 17, 2010 13:10:29 GMT
;D ;D
Yeah
My fuel tank has got pin holes on it does anyone know of someone that is brave enough to repair a fuel tank or a specialist. Unfortunatly a new fuel tank is pretty much unabtainable.
Paul
Fuel tank repairsstealthstylz
@stealthstylz
Club Retro Rides Member 174
Sept 17, 2010 13:30:06 GMT
Cover em with chemical metal.
Matt
Copey
Sept 17, 2010 13:33:07 GMT
Sept 17, 2010 13:33:49 GMT
I'm welding a couple of pinholes in a fuel tank as soon as I've finished my cuppa. I think I'll be fine as I havnt had any petrol in it for 6 months.
I have used plastic padding leak fix before to do a tempory repair to a petrol tank as I couldnt be bothered changing the tank in winter, and the repair lasted for 6 months until I changed the tank. if you then had it replapared later, they'd need to cut the pin holed section out and let some new metal in
robg2
Sept 17, 2010 13:41:35 GMT
I've seen it done by filling the tank with water and then (carefully) MIG-ing. Welding anything wet isn't easy, as anyone who's tried to weld a car outside when it's been raining not too long before will know.
As you can probably imagine, I'm not suggesting that you try this at home! It's really only for someone who really does know what they're doing.
The established way of repairing a steel fuel tank though is to get it steamed out first. You'll be able to find a specialist who can do this for you.
But I'd try Chemical Metal / Petro Patch first and only resort to welding if you really can't get it to stop leaking.
But don't worry, there will be a solution!
Fuel tank repairsHARDCORE
@hardcore
Club Retro Rides Member 190
Sept 17, 2010 14:16:02 GMT
How big are the holes? I've used this in the past with good results.
Sept 17, 2010 14:42:33 GMT
When I've been working on Quarries, the specialists come when the tank is full of fuel and weld it then.
It's not the fluid that's flammable, it's the vapour.
Sept 17, 2010 14:46:30 GMT
I'm welding a couple of pinholes in a fuel tank as soon as I've finished my cuppa. I think I'll be fine as I havnt had any petrol in it for 6 months. I have used plastic padding leak fix before to do a tempory repair to a petrol tank as I couldnt be bothered changing the tank in winter, and the repair lasted for 6 months until I changed the tank. if you then had it replapared later, they'd need to cut the pin holed section out and let some new metal in I would make sure you smoke it out or similar... basically fill it with something inert.... it isn't the petrol which makes them go bang but the vapour that is left. I'm sure you know what you are doing - but it is best to tread carefully.
- '80 Mk1 Vauxhall Cavalier Saloon, 3.0l 12v... in progress with some special plans ahead - '94 106 Rallye, Endurance Rally Car
Sept 17, 2010 15:23:30 GMT
How big are the holes? I've used this in the past with good results. pinhole and only 1 in an otherwise sound tank
Sept 17, 2010 17:08:40 GMT
Empty it out as much as possible, leave it for a few days to vent then blast a CO2 fire extinguisher down the neck before welding. Filling it with CO2 should prevent any big bangs.
I pressure washed the tank on my Pony very thougroughly before attempting the weld it and that was no problem. It was really shagged with hundreds of pin holes. I welded up about 60 of the worst ones then used an epoxy sealer to treat the rest from the inside. I used black Por15 on the outside ( 2 coats) followed by some Por15 'Tie Coat Primer' then after all that had hardened, I rubbed it down to key it and whacked a few thick coats of black 2k on. It's never leaked since.
Sept 17, 2010 19:15:06 GMT
I have a different approach I've used before, last time on a splitsrceen camper fuel tank.. I filled it full off water, used an air hacksaw and cut along the seem until it was in 2.. then I just cleaned well & treated, repaired everywhere it needed to be, then welded the 2 half's back together, whole process had taken about 4 hours, I then refilled with water to check for leaks, job done, safest way I could think of?..
1970 Beetle 1600
1973 Rover P6 2000SC
1993 Audi 80 Avant 1.9TDI
1996 Transit SWB pop top camper, 2L Twink
93fxdl
Enter your message here...
Sept 17, 2010 19:45:10 GMT
couple of suggestions a way of making the tank safe would be connect to the exhaust of a running engine to fill it with non flamable fumes give the tank a good clean to make sure that there is just the one pinhole and not a piece of lace held together with muck i once heard a quick fix can be made by rubbing a bar of soap into the hole how about soldering the tank finally i have fixed a tank using araldite ttfn glenn
stefan
If it isn't broken fix it till it is
Sept 17, 2010 20:15:52 GMT
just get a better tank they would not be that hard to get for eather of your cars
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
Sept 18, 2010 7:46:01 GMT
Unabtainable for the Triumph its unique to the 1300 FWD and none of the specialist ever remember seeing one in the last ten years
Sept 18, 2010 8:18:47 GMT
I have repaired loads of Porsche 356 tanks, best way is to hose it out with water, keep that thing in there for a good half hour, drain it right down, plug up any breathers and fuel take offs but leave the filler neck open!! Fill if back up with water, just below where the holes are then use normal electrical or plumbers solder and a plumbers torch to seal them up!! Oh, and make sure the filler neck is facing away from you!! Have you not tried Pete 33 Grinder on here? Him and his mate Matt have loads of new and used Daf parts, I think Matt has just broke up a 66, should have the same tank...
Mine
2003 Honda Accord Wagon 1963 Buick Riviera x1 1/2 1964 Cortina Estate 1932 Ford Tudor sedan 1964 Honda C50 Step thru
The Missus
2000 Toyota Bb 1972 Daf 33 1968 Triumph 1300 1946 Chevrolet Fleetmaster
Sept 18, 2010 9:04:34 GMT
unfortunalty its the triumph tank not the DAFs which is an awkward shape. When the car was built it was sat on 2 felt strips to stop it rubbing holes in the tank. Which was all very well except that at some point in its 40 odd years the boot has leaked or been left open. The result they soak up and hold the water like a sponge and are in permanent contact with the tank Would it be safe to do away with them or am I going to have to put some strips of carpet or similar to replace where theyve rotted away
Sept 18, 2010 10:21:23 GMT
use rubber or neoprene , at least it wont hold water itself
bortaf
Sept 18, 2010 13:26:53 GMT
When I've been working on Quarries, the specialists come when the tank is full of fuel and weld it then. It's not the fluid that's flammable, it's the vapour. yes but that will be diesel not petrol, totaly differant ball game you try setting light to diesel vapours (if you can find some that is) petrol vapours at -43C wereas diesel it's about 60C, drop a match into a petrol tank it's good by drop a match into diesel it goes out ;D just get the tank steam cleaned, a valeters will do it for a drink
R.I.P photobucket
Fuel tank repairsretrowagen1234
@GUEST
Sept 23, 2010 10:28:49 GMT
handy thread.... Gonna have to try some of these myself... The carlton has what looks like a leak on the seam.. Its been tarred up before but still seeps.
robg2
Sept 23, 2010 11:28:27 GMT
handy thread.... Gonna have to try some of these myself... The carlton has what looks like a leak on the seam.. Its been tarred up before but still seeps. I'm not surprised, petrol dissolves tar.
Last Edit: Sept 23, 2010 11:29:25 GMT by robg2
