IT'S ALIVE !!!:)BenzBoy
@benzboy
Club Retro Rides Member 7
Sounds sweet as a nut mate! Glad you got the ECU probs sorted in the end
IT'S ALIVE !!!:)rustingdeathtrap
@GUEST
Woohoo I was starting to wonder where you'd got too, now i know ;D How many vacuum pipes did you blank off in the end ;D
WooooooooooooooHoooooooooooooooo ;D
Neil
Top work! Awesome bit of kit!
IT'S ALIVE !!!:)Deleted
@Deleted
Woohoo I was starting to wonder where you'd got too, now i know ;D How many vacuum pipes did you blank off in the end ;D just 2 blanked off lost count how many i removed altogether ;D heres a retro shot of the yard
Last Edit: Apr 2, 2006 21:27:15 GMT by Deleted
that sounds fantastic!
WAAAHHHEEEYYYYY!!!!!!!!!!!!!
Nice one. Sounds good. So what were the other problems then?
;D That`ll be what that missed call was about then I take it ;D Glad you got it running fella...... When do I get a go then ;D ;D
@Deleted
WAAAHHHEEEYYYYY!!!!!!!!!!!!! Nice one. Sounds good. So what were the other problems then? just the amount of things that needed to be connected to the wiring to get it going realy spent most of the weekend tracing cutouts and relays there were sensors on the origonal car that needed bypassing to get it going also had a few bits setup wrong it has a pulse feed from the alternator that stop the engine firing if there is no belt and the kadett didn't have enough live feeds so i had to fit an auxilary fuse box to give me enough power feeds to the injection and fuel pump , still a few small jobs to do got a mojor oil leak from the oil cooler i must have damaged one of the o rings when i removed it from the piazza ' happy with the work that i did on the engine as it now has much better throttle response than it did and a bit more boost as well ;D
@Deleted
;D That`ll be what that missed call was about then I take it ;D Glad you got it running fella...... When do I get a go then ;D ;D once i get the brakes and the mot sorted mate
slater
Club RR Member Number: 78
IT'S ALIVE !!!:)slater
@slater
Club Retro Rides Member 78
sounds good!
excellent, glad you got it all sorted!
Love that mk3 wagon Glad its running for you now as well.
Mr Vincent
Hiding In The Shed ......
Whos is the mk3 estate?
Rusty`s Motorcycles
OLD SKOOL RETRO CAR CLUB
i want a yard like yours
antdat
is a good feeling when you get a project running good work!
@Deleted
;D you need to ask ;D ;D its my new daily driver karen is now useing the cressida
racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
WOOOTINGTON!!!! top work, next vid siiideways!
[Bill & Ted]Excellent!!!![/Bill & Ted]
Are you bringing it to CARS (RCS)? If so, I'll look forward to seeing it there!
