Jul 26, 2010 10:00:48 GMT
Hi All,
Was after your help if you don't mind?
I have a jago Jeep with a 1300 x-flow and 4 speed box, runs really well, but I would like a bigger engine, fuel injection and a 5 speed box for it.
I can't go above 2000cc due to the insurance and was wondering what donor car you would all suggest, not bothered about make, but must be RWD as I want to get all the bits I need from 1 car.
And of course, needs to be cheap, as in under 300 quid.
Any ideas?
Steve
Making progress in small, easy to handle chunks of awesome
Jul 26, 2010 10:18:48 GMT
I second that good lumps when looked after and come with a mt75 5-speed Steve
V-Force
I like Hondas.
Jul 26, 2010 10:27:37 GMT
Mondeo Zetec? Honda VTEC? Vauxhall Redtop?
1999 Impreza WRX typeR STI Version 5 Limited 1999 Civic VTi-S Aerodeck 2005 Bora TDI daily
Several other 90s Hondas (shhh they're sleeping)
Jul 26, 2010 10:33:15 GMT
MX5 1.8 and 5 speed box?
kee
Jul 26, 2010 10:41:46 GMT
zetec, everything is readily available to convert to rwd easily
conrad
Here to fix your cabin.......
Jul 26, 2010 11:43:10 GMT
+1 great reliable power, and good torque that comes in early (plenty for a fibreglass kit jeep), REALLY cheap to buy and for replacement parts and still simple.
Last Edit: Jul 26, 2010 11:43:43 GMT by conrad
conrad
Jul 26, 2010 11:44:57 GMT
Mondeo Zetec? Honda VTEC? Vauxhall Redtop? he wants a 300 quid donor car so the vtec and redtop will be too expensive to find a decent one
Jul 26, 2010 11:53:46 GMT
vauxhall omega.
Jul 26, 2010 13:09:10 GMT
Sierra or granny scorpio twin cam, much easier to it than converting a fwd engine and having to buy all the extra parts you'll need, they are quite pokey and good on juice as well, I'm fitting one in me transit van.
Jul 26, 2010 13:11:56 GMT
TR7? Lots of cheap ones on e-bay post '77 ish have 2000cc, twin carbs and a 5 speed box......
Currently driving a 1972 BMW 1602 as my daily. Don't ask about previous cars - there have been way too many and I stopped counting at 160!
Jul 26, 2010 13:17:05 GMT
either a vauxhall omega 2 litre 16 valve ecotec, 130bhp and as long as the electrics are good and you clean out the air intake will go on for a long while. they can be picked up on ebay for 200 quid, i think a couple of guys on here have done just that!, alternatively (My memory of model numbers is poor) but i think it was the volvo 240 that was rear wheel drive with the 1.7 twin choke jobbie. they went well for what they were and I'm sure they can be piced up for next to nothing! hope that helps
Jul 26, 2010 15:15:47 GMT
thanks for the ideas, I need to have a measure up in the bay to see how much room I have between the turrets and then take it from there.
I really want to go onto fuel injection for reliability reasons.
Was also thinking about BMW 3 series as a possible?
Jul 26, 2010 16:12:32 GMT
loads of room in a jago for pretty much any 4 pot engine, you might run into clearance issues if your running the escort servo tower in it, it is possible to lower the tower though, often has to be done to fit 40's on a pinto in an escort.
I think you'll get a better looked after Granada for the same money you'll pay for a bmw though, garnnies don't have the yoof market after them so cheap ones don't tend to have had the noodles thrashed off them.
Jul 26, 2010 20:34:45 GMT
I've a jago myself and I plan (in the far future) to run a bmw 316 (m43)engine, I like it for it's short stoke revablity and there's plenty about at sod all moneys. With it denuded of several tons of bmw it should fly along, to tune it just need a proper down draft inlet(bike TB's!), big thread on tuning a 1.8 m43 on turbosport, negatives you gotta get a sliding propshaft and the lent over block might be too much to squeeze between the towers.
I'll probably still end up stuffing a bike engine in there anyway.
Jul 26, 2010 20:38:10 GMT
Vauxhall 1.7 TD?
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
ideas for donor car pleasespiny
@spiny
Club Retro Rides Member 167
Jul 26, 2010 20:42:27 GMT
sierra. it'll all bolt on to what you have already (more or less) and can be fixed with a hammer if it goes wrong.
Jul 26, 2010 21:58:41 GMT
sigh... they all told you already.... sierra granada twink. You can get a donor granada for as little as £50 if you are lucky and the remains will weigh in for more than that literally every bit you will need is already there on the granada, it's a pretty straight drop bar some prop shortening and some engine mounts.
Ads 19
My old r19
Jul 26, 2010 22:21:10 GMT
Honda VTEC? If you can find a a vtec that can go rwd for £300 i want to know. thought only the s2000 spins the right way. be pain in the having a car that has 5 reverse speeds one forwards. i suppose you could flip the diff over 180 degrees but still. anyway Sierra twink all the way
conrad
sigh... they all told you already.... sierra granada twink. You can get a donor granada for as little as £50 if you are lucky and the remains will weigh in for more than that literally every bit you will need is already there on the granada, it's a pretty straight drop bar some prop shortening and some engine mounts. yep, that is THE engine to use, simple as...
