Philj
Philj
Philj
том
"If in doubt, flat out!"
PCD is 5*112
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
5x112 you say - well that begs for a set of vw bus or merc rims then i spose!
том
so far the bay has been unkind to me on the wheel front, only sellin brand new merc type wheels, no tyres for thr 3-400 mark, doesn't seem to be many/any good 2nd had, tyred bargins about.
There is debate on this - I've also read several times that it's 5x4.5" (ie 5x114.4)
том
i know, which will be really annoyin if thay are, what are yours?
том
those brabus would work
i know, which will be really annoyin if thay are, what are yours? Should be the same as yours! Will try to measure the pcd at lunchtime.... The Cosmics are Amazon pattern, as the guy who sold them to me was an extreme old Volvo nut, and was very specifiic about them being for PV, Amazon & B18 engined P1800.
Mar 15, 2006 10:50:08 GMT
I'm pretty sure that Amazons are 5 X 4.5" (same as US Ford 5-stud). If that's the case, then the possibilities are endless. I'd say Smoothies with no hubcaps and wide whites, sort of '58-'60 kustom style. They'll look great whether the car's rat or not.
Mar 15, 2006 10:52:00 GMT
Tom, save any confusion just measure the PCD on yours.
том
Mar 15, 2006 10:56:28 GMT
how? i couldn't work out how to do it accurately. specially as they're 5 studs, so i can't go hole to hole. (tell me if i'm being simple)
Mar 15, 2006 11:04:21 GMT
Ack...there's a ratio but I can't remember it.
*n
Mar 15, 2006 11:05:54 GMT
Measure between the centres of two adjacent holes and multiply by 1.7012.
*n
том
Mar 15, 2006 11:07:27 GMT
in mil?
Mar 15, 2006 11:09:54 GMT
I'm pretty sure that Amazons are 5 X 4.5" (same as US Ford 5-stud). If that's the case, then the possibilities are endless. The US Ford fitment sounds right, but be careful as apparently most wide wheels won't fit in the arches, especially at the front, where it will also end up limiting the steering lock... Also, if the rear tyres are too wide, the brakes will need balancing to avoid the rears locking up in the wet. Should be plenty of info about wheels on www.brickboard.com as it's US based
dp
DP Race Tech
Mar 15, 2006 11:10:17 GMT
rmad in da house: Moon discs or Flipper caps.I'll second that!!!! Other alternatives are gloss black or red with chrome trim rings & spiders.... or flipper caps.... Or why not match the "Lucky Lady" with some nudie girl caps..... Since the PCD is American Iron there's a bunch of rim sizes available and you can get a perfect "leadsled" look with the right rims & hub caps. IMO alu wheels is a big NO NO on a car like yours but to each his own.... DP says: Painted steelies & hub caps rule.......
Last Edit: Mar 15, 2006 11:17:22 GMT by dp
