Feb 24, 2006 23:52:41 GMT
1) Rebuild the Sprite engine 2) Play with the Amazon.... Sort out tyres & wheel nuts for those Cosmic alloys that I bought recently so I can fit them ;D Find a good passenger side front door, get the rear end (arches, 'side valences', corner of the boot floor, below the reflectors and under the rear loadbay windows) welded, and then it's respray time!!!!* So far, I've bought: Pair front wings £275 - 1 new old stock, the other fitted to a car for just a year so basically as new (Volvo want £275 each ) Offside rear door - £20 new old stock bare door shell (an Amazon specialist would want £200 ) Driver's door, nearside rear door £25 each - second hand but vgc, with glass etc Top half of tailgate £30 - second hand but vgc I was expecting to have to pay about £150 / £200 per door, and to have to make a new tailgate top out of grp, so I'm very happy! *Sadly this won't happen for a while yet as the welding will swallow at least £1k since the bit under the windows is a sod to repair, but there's light at the end of the tunnel now! My brother has spray gear and the correct breathing apparatus so we will probably paint it ourselves next summer. In the meantime, my fiancee has forbidden me from fitting the new doors & tailgate top until they've been repainted (currently green) ;D
Last Edit: Feb 24, 2006 23:54:42 GMT by Paul H
Feb 24, 2006 23:58:54 GMT
You're prompting me to make a list of what I've got to do to mine.
finish welding on rear quarter
do the other side
repair rear panel
build engine
fit flipfront
wire up
pass MOT (ahahahahahahahahahahahahahahaha.... breathe, ahahahahahahahaha who am I trying to kid?)
Paint it maybe at some point.
- Sand, fill, prime, spray arches & valance - Touch up paint chips and light corrosion - Detail engine bay - Rebuild fuel pump - Possibly fit HS6's and TR7 manifold/water take off - Retune & Retime - Fit new HT leads and plugs - Flush coolant - Rebush rear axle - Respray black detail - Vacuum interior. Then see how I feel about changing car
Davenger
It's only metal
Club RR Member Number: 140
Things to do.....Davenger
@dminifreak
Club Retro Rides Member 140
Errr, finish paint I had to weld the roof, fit new rubber springs, fix scabby rust bits, sort exhaust mounts and sort paint
change susp bushes
fit shocks and (lower) springs
patch slightly floor to sill joints on boths side (sob)
tidy up paintwork (sob)
2001 HONDA CT110 (NOT RCV)
Feb 25, 2006 10:04:27 GMT
Monza. Paint rear arches and refit back bumper. Fit steering idler arm, fit koni adjustables make steering wheel boss for my new wheel. Change position of drivers seat.
Silvia finish off welding to floor then MOT.
Piazza rebuild head.
AE82 Two small bits of welding then paint and refit arches wings bumpers lights etc...
MK2 escort. New floor. Patch bodywork in places. Respray
MK1 Escort. New floor. Chassis rails suspension top mounts front panel slam panel radiator panel. Find 205 bottom end and rebuild with my BVH. Make inlet manifold for injection. Make MS for Injection. Turret and possibly 5 link the rear suspension. Fit four pot front brakes.
Locust. Build ;D
Feb 25, 2006 11:39:23 GMT
todays task.
fit gearbox.
fit propshaft
fit interior.
midweek - put tax on it
in the whole grand scheme of things: respray over summer 2.0i by september
Feb 25, 2006 11:40:59 GMT
Make inlet manifold for injection. why not use the standard pinto efi manifold? you megasquirting a pinto? I'm planning it on the one I'm putting in, any good links?
Feb 25, 2006 11:56:23 GMT
Make inlet manifold for injection. why not use the standard pinto efi manifold? you megasquirting a pinto? I'm planning it on the one I'm putting in, any good links? Because I have some bike throttle bodies for it I am considering an injection engine for the mk2 or the kit car but probably the DOHC just to be different
Feb 25, 2006 12:36:29 GMT
niiiiice. I'm plannign running MS with the standard efi lump, cos ive got a HT racing head (44 and 39mm valves) going in wiuth a stupid lumpy cam.
ill upgrade to throttle bodies later on in life, but just wanna get it running sweet with MS before i get them
ive read a fuckload, but nothing really caters for is specificaly for an NA pinto lump, you got any decent links?
Feb 25, 2006 13:38:17 GMT
bus- wire up engine and fill with oil, then she'll be a runner. take for mot, then commence turbo diesel fitment. lower it a sh1t load. fresh coat of red oxide. benz- sort some rust issues. fit more stereo, 2 subs and 1 amp aint enough. lose another 2 inches of height before rcs, which will bring the total to 7 inches of drop. could someone move that crisp packet, i cant drive over it. ;D ;D ;D
Feb 25, 2006 13:41:41 GMT
Todays job was to fit the 28/36 Weber to the Nymph. Found out there is not enough room in the engine bay I didnt realise that the Nymphs engine bay was a bit more cramped the the Imps Oh well i can save the carb for the next Imp i get. I am sure i will end up getting one at some point.
BS Nymph Singer Chamois Coupe Series 3 Landy
Nick
Feb 25, 2006 13:44:57 GMT
todays things to do. involves moving stuff from old workshop up to my(parents) house, where there is no space, biggest task is working out how to fit an e30 shell onto the back of a ford trasit drop side pickup.
this weeks car count "5"
