Nick
Came up with this slightly rubbish idea,
pass on one piece of advice when it comes to working on cars/withcars etc etc you get the idea.
right here is mine
!! when dismantling cars for a project, label everything and keep everything, because as much as you think you will remeber where you put stuff and where it goes 6months down the line...you wont.!!!
end transmission
this weeks car count "5"
thevert
Mini builder
Always do "look overs" on the work you have carried out that day. Wouldnt want to be firing your engine with no oil or screaming off with loose wheel nuts! ;D
bstardchild
Club RR Member Number: 71
One piece of advicebstardchild
@bstardchild
Club Retro Rides Member 71
Digital Pictures taken before stripdown also help with the after bit!!
том
"If in doubt, flat out!"
get a mechanic to do it
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Wear disposable gloves.
If I'd have known about disposable gloves when I started working on cars I would have done so much more!
things progress better with tea and biscuits.
Wilkinsons do an excellent hand cleaner and grease remover. for post car fiddling cleanup.
slater
Club RR Member Number: 78
One piece of adviceslater
@slater
Club Retro Rides Member 78
Spend all your time and money on the wheels because they are all that relly matters when it comes to building cars! don't share a garage with your dad?
paul4be
'86 Capri Laser, Frontera 4x4
Buy the best quality tools you can afford. Cheap tools are often just not worth it.
tea breaks at regular intervals cos you will get annoyed/hacked off and take it out breaking the car..............
2001 HONDA CT110 (NOT RCV)
If you have a short temper have a punchbag close to hand so when you loose your rag you can have instant stress relief ;D
When removing steering wheels, DON'T TAKE THE CENTRE NUT RIGHT OFF until the wheel is "loose" on the column. Loosen the nut, then bash the wheel from behind to free it. Don't take the nut off, then pull the wheel towards you, because when it comes off you will be pulling it towards your face at 100mph, breaking your nose, and your glasses, and bleeding all over your t-shirt and interior. People will mock you for AT LEAST ten years. So far. ;D ;D ;D
My fleet: Suzuki GSX-R600Y SRAD with bald, melted tyres A borrowed Mondeo
onlyrwd
'78 Cavalier 4 door / '78 Manta Berlinetta
When taking on a rebuild or a big job, don't just spend weeks doing the same thing or you will lose interest, swop jobs if you start to get fed up. Welding for weeks, then go sort the engine. Later on the welding wont be as much as a problem when you've had a break.
Mick Gradually trying to own one of everything
the time and money spent on the right tool will be worth it, instead of using the wrong tool and breaking both the tool and the part you're trying to tighten/loosen/adjust.
i managed to break a dizzy and a whole set of mini screwdrivers trying to remove a locking pin, instead of buying a £1 punch thing.
том
because when it comes off you will be pulling it towards your face at 100mph, breaking your nose, and your glasses, and bleeding all over your t-shirt and interior. yep, i've done that, but whats worse, is i've done that twice
read and reserch what your doing. it took me 2 weekends to remove a pug diesel engine from the top. if id read id have found out they come out of the bottom. ended up cutting the front of the car off. ;D also don't lower your daily driver 5 inches.
Before you strip a car down, invest in a number of large & small plastic tubs, freezer bags, sticky labels and a marker pen. Putting all the bits that need to be together in a bag or box & clearly labelling what it is saves no end of hassle later.
forgetting to put the dizzy cap on is a good place to start looking when the car wont fire ;D
Mr K
don't put lumps of lead in your petrol tank... It is not a way to make unleaded petrol leaded!!! it just bungs up the fuel pipe.... dumb pervious owner. don't try turning your engine over with no oil filter on to 'flush the last of the oil out' (my brother did this - certainly was messy!)
