retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Mar 16, 2012 21:33:04 GMT
Personally, I'd be inclined to go with the black bonnet on this one rather than the rising sun. If I did do the rising sun, I'd be tempted to mask off the current bonnet and just spray the white bits on top, make it look like it was done ages ago and has faded a bit. Yes still got my doubts on the rising sun I think it may be a step too far
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
retrolegends
Mar 16, 2012 21:35:00 GMT
Nice Little Datty that........ nice work P.S. I was parked next to you at RRG ;D Thanks mate,I remember you have got the super low B310 have'nt you! ;D Are you going to RR this year?
Mar 16, 2012 21:57:43 GMT
the front struts on these are pretty long. and the front arches are quite high so you'll be hard pressed to get it low enough without serious work. mine was runing cut springs on the front and had to rig up some spring retainers. was nearly hitting the bump stops and still wasn't quite low enough
retrolegends
Mar 19, 2012 17:40:38 GMT
Hmmm sounds expensive Al,I think I will leave it as it is for the time being then, Love the GT-R badge btw!
Mar 19, 2012 21:38:45 GMT
i wish i stll had that cherry, as i now want to try some rwd offset 14's with streched tyres. ;D
retrolegends
I wish I stll had that cherry, as I now want to try some rwd offset 14's with streched tyres. ;D Theres a nice one on ebay at the mo
Mar 20, 2012 20:56:09 GMT
I wish I stll had that cherry, as I now want to try some rwd offset 14's with streched tyres. ;D Theres a nice one on ebay at the mo haha. the last thing i need to be doing is buying another car ;D
retrolegends
Added my Markopolo valve caps!
I just noticed - because I are slow - your centre caps properly... are they aerosol can lids with Datsun stickers?
retrolegends
I just noticed - because I are slow - your centre caps properly... are they aerosol can lids with Datsun stickers? heh! they are the original (but a bit battered) caps sprayed black,the Datsun stickers were an ebay purchase
They're huge! I'm guessing they were chromed or something originally?
retrolegends
Just plain ally by the looks of them,probably sprayed silver and originally had Datsun centre caps. They are MASSIVE though!
retrolegends
Apr 24, 2012 16:51:06 GMT
Spring is here and its time to start using the old tin box! Had a few staring issues but seemed to be a loose connection on the starter soleniod. Changed the fat,gapped the plugs and points and shes good to go! ;D ;D ;D Still not got the bonnet sorted so there is a bit of unintentional "Rat" going on at the mo' TBH tho' I quite like it! ;D Got the rack back out of storage to ready for the summer, need to try and find my lager crate for the roof though!
I keep looking at your rear lights and thinking they should be freshened up with some satin black paint and a bit of aluminium tape. That Dunlop sticker is awesome, where'd you grab that from?
I don't like the bonnet, but funnily enough the age of the little Datsun means you can get away with it.
retrolegends
Apr 25, 2012 16:17:00 GMT
I keep looking at your rear lights and thinking they should be freshened up with some satin black paint and a bit of aluminium tape. That Dunlop sticker is awesome, where'd you grab that from? I don't like the bonnet, but funnily enough the age of the little Datsun means you can get away with it. The sticker was from "I say ding dong" on the bay of E, I do have another set of lights that I am thinking of cleaning up and fitting. The bonnet is going to be black its just a matter of time and inclination to do it,I will probably spray it myself now instead of have the vinyl which means in six months it will be "RatLook" again! ;D
retrolegends
Apr 30, 2012 17:15:07 GMT
Hmmm Its seems I have either bought a dodge battery or the alternator is on the blink because the battery is dead. I thought at first it was the rubbish cd player dragging down the battery but I have disconnected that and I am still getting starting problems.Also I have checked all the earths and terminals I can think of. This morning I jumped it off the wifes Polo and took it for a ten minute drive,disconnected the battery and left it for an hour when I got back,when I reconnected it the car would barely turn over. I would not have thought it was the battery as I only fitted it in January but you never know! STUMPED! Anyway here is a side profile for Mr Volksangyl
Apr 30, 2012 22:21:02 GMT
get yourself a votmeter or borrow one. and measure the voltage at the battery with the ignition off. then start the car and measure the voltage at the battery with the engine running.
best start with a fully charged battery if you can get it on a charger?
you should get 11.5-12.5 volts engine off and around 12.5-13.5 engine running.
check that out first.
these have a voltage regulator in the engine bay and that could be at fault.
retrolegends
get yourself a votmeter or borrow one. and measure the voltage at the battery with the ignition off. then start the car and measure the voltage at the battery with the engine running. best start with a fully charged battery if you can get it on a charger? you should get 11.5-12.5 volts engine off and around 12.5-13.5 engine running. check that out first. these have a voltage regulator in the engine bay and that could be at fault. Thanks Al,the old man was an auto electrician before he retired so he will have a volt meter for sure,I will get on it!
retrolegends
Right charged the battery,gapped the plugs (again) and managed to get it running, (eventually),pulling good volts at the alternator so I went for a ten minute blast.
Came back turned the ignition off and back on again and the starter motor whirred and then started to make a really slow lazy noise, the only conclusion I can come to is the starter is knackered so its the motor factors for me tomoz! TBH its probably the original starter so fingers crossed!
retrolegends
Managed to get a recon starter motor from Greens in Leicester for £66 inc vat which I didnt think was too bad compared to some of the ridiculous prices I was quoted (£86 plus vat one place!) One 37 year old starter motor! The Datsun seemed suprised! And the new one. I lightly oiled the pinion and it went on a treat,First flick of the key and the old gal fired up! Well Chuffed!! ;D
