20" Steelsjettadeluxe
@GUEST
Nov 20, 2009 12:28:57 GMT
You can get Merc s/savers in 18", but they are only 3.5" wide. Which gives you all the more option for a lovely band on them! 5" band = 8.5" wide goodness YUMMY! Further research indicates VAG have a 19" space saver steel. There's one on eBay at the moment.
Nov 20, 2009 12:46:29 GMT
You can get Merc s/savers in 18", but they are only 3.5" wide. Which gives you all the more option for a lovely band on them! 5" band = 8.5" wide goodness YUMMY! Or massive skinny fronts, with banded ones on massive tyres on the back. ;D
kevfromwales
the conrod's REALLY out the block now!
Nov 20, 2009 13:00:12 GMT
my extensive lack of modern jag knowledge fails me at this point, but while last at chez seff in the big city, I saw a modern jag (the mondeo one?) - with some sort of sporty spec, and it was rocking a completely smooth 18" spacesaver, in a very useable 5x120 (4 3/4" chevy) pattern - can jamesp band an 18" do we know?
- kev
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
sowen
Club RR Member Number: 24
20" Steelssowen
@sowen
Club Retro Rides Member 24
Nov 20, 2009 13:07:10 GMT
My rover p6 with 15" chevy 1/2 ton truck wheels fitted: What was needed to get them to fit :
markbognor
Club RR Member Number: 56
20" Steelsmarkbognor
@markbognor
Club Retro Rides Member 56
Nov 20, 2009 13:13:09 GMT
The idea of a bandaed space saver is very cool. But is there a but with them in that some are made with a pretty unique bead shape, for their pretty uniqe space saver tyres, that isn't suitable for seating a "normal" tyre. I know its been done so this obviously isnt a problem for all types of spacesaver, but I'm i'm sure i can remeber reading that it can be. As for the 20"s one of these in satin black, gloss black moon logo maltese cross on the flanks, minimal ride height gloss black wheels, low pro, with a very narrow white band.
@GUEST
Nov 20, 2009 13:23:16 GMT
- can jamesp band an 18" do we know? - kev No apparently his lathe can take anything that big. I was looking around regarding the 18" Audi space spavers for my T4 ages ago on a whim.
Nov 21, 2009 12:10:41 GMT
Sorry to use your car and go off topic but thats why you shouldnt run modern rims on old cars!! Same rims but smaller might suit better, like 15/16"
Nov 21, 2009 13:20:39 GMT
- can jamesp band an 18" do we know? - kev No apparently his lathe can take anything that big. I was looking around regarding the 18" Audi space spavers for my T4 ages ago on a whim. What was the biggest he could do? 16? 17? or limited to 15?
@GUEST
Nov 27, 2009 22:16:06 GMT
No apparently his lathe can take anything that big. I was looking around regarding the 18" Audi space spavers for my T4 ages ago on a whim. What was the biggest he could do? 16? 17? or limited to 15? I've PM'd him, and he can do up to 19" now!
@GUEST
Nov 27, 2009 22:18:17 GMT
A little bump for this one. I've just discovered that Dodge also make a 20" steel wheel for the Nitro, in 7.5J. The PCD is 4.5", or 5*114.3!!!!!!! eBay US link
Last Edit: Nov 27, 2009 22:18:45 GMT by jettadeluxe
misteralz
Nov 27, 2009 22:30:13 GMT
I saw an amazing looking Cossie powered Corsair on those in Retro Ford in early 2008, gave me the right horn. A great example of how everything has potential to work if applied correctly. Stays just down the road from me, and is a serious rival for my S3 on the twisties up here.
Nov 27, 2009 23:24:05 GMT
A little bump for this one. I've just discovered that Dodge also make a 20" steel wheel for the Nitro, in 7.5J. The PCD is 4.5", or 5*114.3!!!!!!! eBay US linkI hate you! That's giving me evil thoughts ;D ;D
my extensive lack of modern jag knowledge fails me at this point, but while last at chez seff in the big city, I saw a modern jag (the mondeo one?) - with some sort of sporty spec, and it was rocking a completely smooth 18" spacesaver, in a very useable 5x120 (4 3/4" chevy) pattern - can jamesp band an 18" do we know? - kev Modern Jags are on a different PCD, cant remember what it is, but the last Jags to have 4.75" PCD are the X300 saloons (so upto 2002) and the original XK8's. The S type, X350 saloon (the all ali one), the new shape XK and the X type all have the smaller PCD. Sean
20" Steelsstealthstylz
@stealthstylz
Club Retro Rides Member 174
Think the newer ones are 5x108 same as Ford?
Matt
misteralz
Nov 28, 2009 10:29:04 GMT
Are Ford 5 studs not 5x112? Which is why you sometimes see Granada wheels on late bays and T25s?
Nov 28, 2009 13:32:40 GMT
Personally, I reckon the Viva looks good on 19s...too much Street Machine in my youth I suspect (although obviously, it'd need to be lower).
sowen
20" Steelssowen
@sowen
Nov 28, 2009 16:27:56 GMT
Are Ford 5 studs not 5x112? Which is why you sometimes see Granada wheels on late bays and T25s? I think earlier fords were 5x112, and the late ones are 5x108 as on my old mk3 mundano, don't know when they changed over though.
@stealthstylz
Front wheel drive 5 stud is 5x108mm
Rear wheel drive 5 stud is 5x112mm (on European models)
IIRC.
Matt
A little bump for this one. I've just discovered that Dodge also make a 20" steel wheel for the Nitro, in 7.5J. The PCD is 4.5", or 5*114.3!!!!!!! eBay US linkI hate you! That's giving me evil thoughts ;D ;D Same bad ideas here, except I could never afford the tyres!
Remade In Australia thereimaginarium.com.au
Nov 30, 2009 11:14:57 GMT
Likewise. I priced up a set of the new 17" slot mags recently, and a set of decent tyres was about as expensive as the wheels, so I don't even want to know how much low profile 20" tyres cost
Last Edit: Nov 30, 2009 11:15:40 GMT by Paul H
