May 21, 2010 21:54:53 GMT
I agree with craig with regards to the position of the brackets for the grille, mounting them inside the grille would give a cleaner look to the front end. Having said all that, have the brackets just been added to mock up the grille's final position? No they are permanent I'm afraid. I haven't sourced any headlights yet, but hoping to use some nice chrome ones or maybe get some painted red oxide to match the bodies colour. I got rome cardboard so I have begun making the floor section. Still need to trim here and there, but it is almost done. ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02170.jpg) ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02169.jpg) ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02167.jpg)
May 24, 2010 15:21:21 GMT
Jun 11, 2010 19:57:01 GMT
Jun 22, 2010 15:01:22 GMT
Even more floor in now. It is starting to get heavy lifting the body on and off ;D ;D ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02231.jpg) ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02230.jpg)
Jun 23, 2010 23:19:49 GMT
Neat little project. When I saw the grille I thought it could do with a bit of a rake , pulling the top back towards the body of the car. Wouldn't need much, only a few degrees, then it shouldn't look so stark against the rest. You should get some absolutely huge headlamps too, like the ones on Austin Sheerlines, mounted really low... although that might end up looking somewhat phallic >.>
Shall follow your progress gleefully now I've discovered this build. *attaches a bookmark*
Jul 21, 2010 11:38:01 GMT
Jul 21, 2010 11:43:42 GMT
lovely looking progress, I really should take note and build a g/box tunnel, unless you fancy a weekend off yours?? hehe!
Jul 21, 2010 17:21:02 GMT
thats looking good.
Jul 21, 2010 21:29:50 GMT
Thanks guys. Next I plan to build a sub frame which attaches to the floor, built from flat section. The idea is to bolt the rubber bobbins for mounting the body onto them, and this will in turn give the bolt heads from the trans tunnel clearance from the chassis.
Ads 19
My old r19
Jul 21, 2010 21:37:41 GMT
so long as it don't make it sit any higher looks spot on as it is.
Jul 21, 2010 21:43:21 GMT
Nice work your doing there,its given me the inspiration to pull my finger out and start on my Austin again. ![](http://i767.photobucket.com/albums/xx319/austinpowers30/austina30/HPIM0548.jpg)
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
Jul 21, 2010 22:20:17 GMT
Looks like a sweet little car you've got yourself there, and a nice little summer project too! Ads 19 It shoudl only raise it by an inch very at the most, and that is only if I do plan on going down this frame and bobbin route.
Right, I've decided (I think?!) to stick to the original bolt-on method of attaching the body and using rubber between both surfaces. I am hopefully nearing the end of the tunnel fabbing (still need to put spring washers on all those nuts though ![:o](//storage.proboards.com/forum/images/smiley/shocked.png) ), and then I can fully concentrate on the body mounting. ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02436.jpg) ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02434.jpg)
Aug 20, 2010 17:55:02 GMT
Aug 20, 2010 18:01:38 GMT
The rake on the grille is fine if you're keeping everything upright looking, but if you're going to be trying to make things lower and longer, it needs pushing out at the bottom. What's the plan for the front arches and other metal?
Aug 20, 2010 19:14:10 GMT
I agree with Volksangyl, the rake looks good as it is. Thou as the rest of the car comes together it will change how the car looks and you might want to adjust it again then.
Aug 29, 2010 17:14:17 GMT
Sept 9, 2010 20:16:20 GMT
I have installed the fuel lines and the fuel tank. Made some brackets, bolted it all to the chassis and mocked it up, then took them off and sprayed them. I think it looks pretty good. ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02515.jpg) ![](http://i725.photobucket.com/albums/ww257/Boulderdash_photos/DSC02514.jpg)
Sept 29, 2010 20:55:36 GMT
Sept 29, 2010 21:55:50 GMT
Great progress, looking forward to more updates
