Dec 28, 2009 21:32:38 GMT
aij29
Hi
Great work going on here,
Whens the trial fit?
I`m desperate to see what it`ll look like on the chassis
Keep it up
Cheers Adrian
jo0lz
FucT FiAT
Jan 15, 2010 14:28:05 GMT
WoW Lot of work gone in to that already Like others want to see a trail fit of the body... Jo0Lz
Jan 15, 2010 17:15:16 GMT
Hi Great work going on here, Whens the trial fit? I`m desperate to see what it`ll look like on the chassis Keep it up Cheers Adrian All in good time. It will need to have a floor first so it sits flat and as it would when it is finally attched.
Jan 31, 2010 22:27:29 GMT
A few more updates. The floor frame has had the body mount holes drilled larger for the 10mm bolts it will use when that time comes to maount that body, and I have put the first coat of Hammerite on the subframe (although not on the underside yet). The loops aren't painted because I may still weld some extra metal between them to add tunnel rigidity. Still debating it, though. The rear brake lines are off because I am redoing them, but they should be replaced by next weekend if all goes well.
great work going on here!
Feb 12, 2010 19:36:40 GMT
Feb 12, 2010 21:08:02 GMT
slowly be surely getting there.....looking good
loving the dub
luckygti
I need to try harder!
Wow, loads of work getting done on this now, starting to come on nicely and those repairs look really good. I'm like everyone else wanting to see a trial fit, so massive respect for your superior self control to not do it. If it was mine I'd have it on and off every chance I could get I'm a bit impatient mind!
Wow, loads of work getting done on this now, starting to come on nicely and those repairs look really good. I'm like everyone else wanting to see a trial fit, so massive respect for your superior self control to not do it. If it was mine I'd have it on and off every chance I could get I'm a bit impatient mind! Me too. Reason I don't have it on and off the chassis for a trial fit is with that cross bracing it physically can't fit now the new floor frame is on the chassis, and if it did, the cross bracing is lower than the 4 inch channeled floor would be, so it would sit too high up anyway. And the arches need to be radiused to fit around the wheels, so if I put the body on for a trial fit now, it would be more of a case of just laying the body on the chassis. Not ideal really.
Feb 24, 2010 22:51:59 GMT
Last Edit: Feb 24, 2010 22:59:30 GMT by Deleted
Looking good.
Peace,Max signature height = 80px
Sven
Great project, this! Love the precision chassis table ...
1969 Chevrolet 4x4 C10 Pickup 1969 VW extended cab pickup (doka) 1980 Volvo 240DL 1995 Mazda Miata MX-5 2007 Toyota FJ Cruiser 2007 Dodge Ram 2500 Cummins Diesel 2011 MK Indy R (building)
Mar 13, 2010 15:53:17 GMT
Mar 27, 2010 18:50:41 GMT
Last Edit: Mar 27, 2010 18:59:23 GMT by Deleted
Mar 27, 2010 19:28:16 GMT
looking good
