I installed the poly bushings for the front end a while ago, it was probably one of the least-fun things you can do with a car. The first lower a-arm took about four hours including dismantling but the second only about 15 minutes once the correct technique using a angle grinder and air chisel was mastered, the upper arms were a whole other story... although they also were alot easier using the right tools. Here's proof that they're in place For future reference two jacks makes life alot easier taking things apart and back together without spring compressors. I also cut half a coil off the front springs, lowered it about an inch. Now i'm desperately trying to find some proper lowering springs as it's just too soft to lower any more on the stock ones. One of the header tubes is already half the size it's supposed to be. here's a pic of what once was a subframe, further rear most of the side is rusted loose. I've also come to the conclusion that connecting a vacuum hose to the distributor might have a positive effect on fuel consumption, but as the car runs rather sweet as it is I guess it needs ported vacuum. Anyone have any advice on this? The engine is running mercruiser thunderbolt ignition parts, and here's a pic of the carb without any connections whatsoever for ported vacuum, Which one is ported vacuum, or is there even one on this carb? If there is, how do you go about opening it an installing a connection? thanks in advance Edit: Now i've connected the dizzy to full manifold vacuum, which according to the butt-dyno was a good thing to do, it raised the idle a bit, which was easily lowered to 500 rpm, without getting the desired unstable idle ;D I don't have a timing light available, but i'll check it when I find one.
Last Edit: Aug 3, 2010 14:05:41 GMT by dude
Aug 12, 2010 19:07:33 GMT
The new rims redrilled. Redrilling done the low-brow way by using a brake drum for the pattern.. The taper angle didn't turn out exactly the same either, but there's plenty of material and it's rather soft so i think it'll be alright.
Potter
'E who dares wins,eh Rodders??!
Aug 13, 2010 11:06:52 GMT
Awesome car! Love it! It should look the nuts on those wheels? I assume they're going only on the back ?
More cars than sense or money!🙄
Aug 13, 2010 12:04:24 GMT
why not get drop spindles for the front and put stiffer springs in instead of lowered springs or for even more low get both
Aug 14, 2010 11:11:56 GMT
why not get drop spindles for the front and put stiffer springs in instead of lowered springs or for even more low get both I'll get it low enough with lowering springs when I have the founds for them, there's no need for drop spindles. Awesome car! Love it! It should look the nuts on those wheels? I assume they're going only on the back ? Thank you! The cragars are for the front, or acctually they're fitted already, haven't got any pics yet though. I got some 215/55's for free which look a bit modern, but they'll do for now. The rear got 15x6,5 caprice steels with 265/70 tires. They're huge. ;D
Last Edit: Aug 14, 2010 11:12:51 GMT by dude
Aug 14, 2010 11:30:56 GMT
ive always fancied an earlier front end on mine (sharknose) in Glassfibre like a flip front but they are megga expensive and even more to import ggrrr Here's the company I talked about in a previous post which I accidentally somehow deleted , www.rpglasfiber.com If I understand correctly all the glass parts for a 70-73 RS would be about 6000 swedish kroner. Obviously you also need lights, grill mesh and so on.. They've also had flip fronts, but i didn't find any on their page anymore.
Last Edit: Aug 14, 2010 11:31:45 GMT by dude
Aug 14, 2010 21:14:48 GMT
tak bra ! very reasonable prices on from them looking at other stuff they have as well
Aug 16, 2010 10:06:19 GMT
(try putting that side by side with the profile shot on page 1..)
Last Edit: Aug 16, 2010 10:19:25 GMT by dude
Aug 16, 2010 21:18:41 GMT
Love this car.
Aug 16, 2010 23:29:20 GMT
Mint!
Aug 17, 2010 15:09:24 GMT
Thank you!
backzilla
0 - 60 in 5.3 ............in the wet
Aug 17, 2010 15:39:51 GMT
niiiiiice.
Aug 17, 2010 17:54:53 GMT
Ooooh, I like that a lot
Em
Fuel Injected? Carb Infested!
Aug 17, 2010 18:57:38 GMT
This car just gets nicer and nicer.
There's just something unashamedly don’t-give-a-damn cool about a big, bruising 70s US coupe wearing its battle scars with pride. Top motor!
Always had a soft spot for these. Bullnose Firebirds too…
Good work!
Aug 18, 2010 21:03:50 GMT
thanks guys herald - you made my day
as you say they are 15's on the rear then what are the fronts are they also 15s as the profile picture makes it look like 16" on the front?
i have a spare set of 15" iroc rims the 5 gold spoke version so might need to up the tyre size from what is currently as as i believe they could be shot by the time i gets on the road!
lookins ace anyhow
andrzejbubez - the fronts are 16" A friend with a lathe made me some nylon bushings for the front spring eyes, so we did the herb adams mod while we were at it. And a whole lot of rust welding ;D The very solid bushings One of the spring mounts... I didn't get a chance to get a pic of the stock bushings and the 3 out of 6 bolt holes no longer connected to the car... But I guess you get the idea Reinforced for heavy duty use We used 16mm bolts instead of the stock 12mm(or was it 10?), just in case ;D Do you reccon we use a big enough welder? Also note the not-tinted rear lights. Cut to get some room for the spring, and painted. Intermission ;D Me trying to look like I acctually do something important. Finally everybody gets their mental image of "dude" ruined And finally a picture of them mounted. I haven't got a proper chance to try them out yet (as i'm so skint I can't afford petrol) But the 5 minute test drive I took felt promising, all the clonking and weird noises had gone away, no more rubbing issues and the car felt alot more responsive. I also had to get some new belts for mot, so I found some generic lap belts... Only for the test ofcourse
Last Edit: Aug 30, 2010 9:41:18 GMT by dude
VND
This car is perhaps my current favorite Retro ride.. the wind may switch tomorow, but its camaro day today. Lovely car.
Aug 30, 2010 15:43:46 GMT
This car is perhaps my current favorite Retro ride.. the wind may switch tomorow, but its camaro day today. Lovely car. Thank you very much
Copey
Aug 30, 2010 17:01:46 GMT
very very cool!! love the stance! nose down is a great muscle look!
