spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
1970 MG Midget 1275spiny
@spiny
Club Retro Rides Member 167
History: My dad bought this car sometime around 1973, he is the second owner. We used it as a family car right up to about 1981ish I think, when me and my sister got too big to fit in the back. It was then parked up in my Grans external garage. Presumably my dad expected to tinker with it and use it at weekends but for whatever reason just never got round to it. I remember sitting it it most weekends when we used to go and visit my gran and pretending to drive it, and also managing to burst a brake line at some point ... My gran died about fifteen years ago and as the house got sold the MG was moved to my parents garage - this involved me and my dad taking a number of hours to free up the brakes and snapping a few wheel studs in the process ... It then stayed in my dads garage, slowly getting covered in lawn movers and other garage cruft. Fast forward to just over three years ago and my dad asked me if I'd like the MG, which has only one answer really So transport was arranged and it got moved to the house I was renting at the time, where work began. As found: hmmm: moved to new garage for work to commence: I have been taking plenty of pics of the work I've done and to save duplicating them, they are all posted here: www.spiny.org/van_progress/it says 'van progress' as it was initially about my bus, which is currently 'on hold' the pics are organised in chronological order, newest at the bottom. I'll use the thread here to add recent and future updates
Last Edit: Feb 3, 2010 10:16:21 GMT by spiny
spiny
Wiki Admin
@spiny
current status: it moves and stops under its own power still loads to do, needs panels fitting, switchgear looking at, lights sorting and so on.
spiny
Wiki Admin
@spiny
Jul 13, 2009 10:43:04 GMT
not planning ahead: I fitted a fuel regulator a few weeks ago as the facet pump I'm now using is a bit 'strong'. I mounted it on the inner wing where it looked good alas, it fouled the outer wing, so had to move it a bit lower. This then meant I had to 'trim' the stock air filter: the old mounting holes are the three you can see on the flat bit.
spiny
Wiki Admin
@spiny
Jul 13, 2009 10:44:57 GMT
Nathan
1970 MG Midget 1275Nathan
@bgtmidget7476
Jul 13, 2009 10:54:41 GMT
EXCELLENT MATEY.
Looks wicked, and has spurred me on to get in the garage now and weld my sill on LOL.
spiny
Wiki Admin
@spiny
Jul 13, 2009 12:27:48 GMT
just popped over to Moss to get a few bolts for the wings as I'm fed up of wirebrushing the old ones I have and still they bind scored a choke cable too as I can't find mine
Jul 13, 2009 19:55:55 GMT
love these, good luck with the project! looks like you've a bit of work on your hands there!
spiny
Wiki Admin
@spiny
Jul 13, 2009 21:29:46 GMT
managed to squeeze in a few hours tonight. choke fitted (took about 10 seconds) but making an 'end' for the cable took about an hour I carefully drilled holes in all manner of bolts, tried claming the cable in washers and considered welding a blob on the end like a bicycle brake cable, but in the end the simplest thing worked, an electrical connector block, squeezed a bit in the vice to make it 'flat' at the bottom: then spent some time fitting lights to the wings, the headlamp bowl and the indicator 'bowl' are pretty knackered, but in the interests of time, they are 'fix it later' - what I have works and fits, it just needed a few extra bolts here and there to stop it wobbling. and
Last Edit: Jul 13, 2009 21:30:15 GMT by spiny
lae
Jul 14, 2009 11:57:58 GMT
Yes!
These cars are SO much fun, I really really wish I hadn't got rid of mine (although as a daily they are completely hopeless). Unfortunately going back to university for another four years mean I won't have the space or money for a project for a loooong time...
Are you keeping it stock? First thing I would do to mine is sort out the rear suspension, live axle + leaf springs + bumpy road = rear end jittering all over the shop. You can uprate the suspension and brakes quite cheaply. The engines are pretty easy to tune too, loads of books on them.
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
Ray Singh
More German exotica in my garage now
Jul 14, 2009 12:06:55 GMT
Mrs Rav had one of these a few years back 1969 SWA. These things very quickly turn from concourse to rust piles. Keep on top of it fella. It looks a good project.
spiny
Wiki Admin
@spiny
Jul 14, 2009 12:23:46 GMT
Last Edit: Feb 3, 2010 10:17:30 GMT by spiny
spiny
Wiki Admin
@spiny
Jul 14, 2009 12:24:35 GMT
same story on the other side: sill fun: oh dear. braced the door gap just in case: gah patching inner:
Last Edit: Feb 3, 2010 10:18:14 GMT by spiny
spiny
Wiki Admin
@spiny
Jul 14, 2009 12:25:06 GMT
Last Edit: Feb 3, 2010 10:19:03 GMT by spiny
DutyFreeSaviour
Jul 14, 2009 12:26:15 GMT
Nice work so far fella. I loved the fact my MG was just like a big Meccano set.... Good luck with the rest of it.
spiny
Wiki Admin
@spiny
Jul 14, 2009 12:28:03 GMT
Last Edit: Feb 3, 2010 10:19:34 GMT by spiny
spiny
Wiki Admin
@spiny
Jul 14, 2009 12:32:38 GMT
other side: [no pics of the welding for some reason] ebay marina engine (bought in 2007 )
Last Edit: Feb 3, 2010 10:20:51 GMT by spiny
spiny
Wiki Admin
@spiny
Jul 14, 2009 12:35:18 GMT
moved the battery to the boot: sizing up: (tray is from a rover 200, they unbolt - very useful) welded on some bolts weled on obligatory paint fitted
Last Edit: Feb 3, 2010 10:24:42 GMT by spiny
spiny
Wiki Admin
@spiny
Jul 14, 2009 20:09:40 GMT
finished fitting one wing this evening. I think I must have damaged the valance or wing at some point over the last three years while moving them round various garages as the wing simply did not fit in the end I fitted the highest bolts then used a long bolt at the bottom to pull it together. fitted the other bolts then realised that i'd forgotten to drill a hole for the lower wing mount after plating the inner sill so made a tiny bracket instead: long bolt used: looks ok though can't do any more work on it for a week as i'm off to cyprus for a friends wedding, not sure i'm going to make the rr show deadline that i've set myself - i might trailer it there if it's not road legal
spiny
Wiki Admin
@spiny
Jul 15, 2009 11:38:17 GMT
even if it's not ready for RR09, a guy I work with has said I can borrow his car trailer, so I might be able to bring it anyway
spiny
Wiki Admin
@spiny
Jul 15, 2009 20:06:58 GMT
picked up some doors I bought off ebay this morning, only meant to bid on one, but you know how it goes after a drink .... should be able to make a decent pair though
