markbognor
Club RR Member Number: 56
There's about 7 threads protruding, at 12x1.25 thats 8.75mm of stud being used. I suspect that that is no where near enough. Is the rule of thumb 150% of stud diameter? That would be 18mm of stud, that seems quite a lot.
MrT
Just who did Mr Hitler REALLY think he was kidding?
Small furry animals will die, more global warming will occur, and the world may come to an end by mid-October.
You need longer studs...
Last Edit: Jun 9, 2009 14:34:31 GMT by MrT
I think i would only use those if i did a maximum of 5 mph and always in a straight line
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
markbognor
Yeah, I pretty much knew really. now I have to buy some studs too.
The Doctor
Club RR Member Number: 48
with the normal wolfrace type nuts, it would be no problem, but with this.. i'm not so sure..
^^^ Yeah, sleeve nuts would work, but then you'd need bigger holes. New studs look like the cheapest option
'67 Vauxhall Viva HB Deluxe
General rule of thumb is 1.5 D, ie on and 8mm stud, 8* 1.5 = 12mm stud length.
However this is open to argument/judgement etc, common sense however would dictate that if it doesn't look right then it probably isn't ;D
'A' series trigger wheels and sensor brackets, 205 GTi radiator brackets, general fabrication and machining - www.gsmotorsport.net
Jun 10, 2009 13:36:14 GMT
Wow - thanks for that - I need some new studs for my revolutions and he is just down the road - perfect!
Porsche 924 - gone Citroen Saxo VTR - not very retro but I loved it - now gone... MK4 Golf GTi 1.8T - gone but hardly remembered... Mini Cooper S R53 - gone BMW 125d Coupe - gone (mostly sideways)
Ford Focus RS Mk1 - hello low MPGs and "wanna race me" at every set of lights... 1973 BMW 2002 - Twin 40's, 284 Cam, Revolutions, E21 Recaros + more Porsche Cayman 987 3.4S - here and due to cost me more money than I have
dubzi
Jun 10, 2009 21:54:36 GMT
No need for longer studs, just cut the nuts in half!
Happiness ain't at the end of the road. Happiness is the road.
