I need some suggestions / recommendations of four cylinder petrol engines and gearbox for a mid-engined application.
REQUIREMENTS
Must be compact and lightweight and car not bike. The lighter the better. All-alloy?
Needs to be normally aspirated - not enough bay space for turbo cooling / pipework etc.
Nothing too rare. Ideally something around 1300cc to 1800cc, that'll rev a bit, with about 150-180bhp easily and reliably achievable.
Am I asking too much?
Renault? Peugeot? Fiat? Alfa? Ford? Something Japanese? Nissan? Toyota? Honda?
I know that people put Suzuki Swift 1.3 GTi engines into Minis and kit cars and that they are light but they have 100bhp as standard and I'd like to start with something more powerful.
Any sites out there that provide info. about the weight and dimensions of various powerplants?
Rover K-series. All-alloy, 113kg with transmission, 160bhp VVC variants are available, Lotus VHPD (Very High Performance Derivatives) ones make about 190bhp, really mad-spec can make 230bhp-ish.
Head gasket problems have been largely sorted out - fit a multi-layer metal head gasket from a Land Rover Freelander, with the correct metal dowels and the problem is mostly overcome. Provided the head's not warped or porous. And the cylinder liner protrusion is correct.
Treat them with a bit of respect (let it warm up before you thrash it, let it cool down at the end, make sure your cooling system is in top condition) and you should be alright.
Citroen GSA flat four. 1300cc, easily tuneable, rev like mad.
"Chasin' the gash, with a four-out-the-dash"
4A-GE 1.6 engine & box from an MR2 Mk1 Plenty out there, cheap to buy, uber reliable, easy to tune, rev like mad...real little screamers - and the best bit is they are already set-up for a mid-engine. Some details about the engine here: en.wikipedia.org/wiki/3AC#4A-GE_.2816-valve.29Another alternative might be the later 3S-GE 2.0 engine from the Mk2 MR2 which started out with 150bhp and rose to around 175bhp in standard form (there is a 197bhp version, but these are harder to find and a lot more expensive!) Details of the 3s-GE engine here: en.wikipedia.org/wiki/3S-GEWell worth looking into either of these powerplants. Super reliable and quite easy to find. Sound nice too when screaming their lungs out....
kee
toyotas arent alloy though are they?
lightweight engines you need to be looking at the latest ford stuff. sigma engines, found in the mk4/5 fiestas and focuses, found in 1.25, 1.4 and 1.6 sizes. 1.6 can reach 220 on standard valve sizes. these engines where designed and made by yamaha, they are tiny and weigh around 80kgs with ancillaries. also look at ford duratec engines, probably the best 4 pot for years, stupidly strong and can do 270 from the 2.0.
i want to put a sigma in my fiesta at some point.
Another vote for the Ford lumps, especially the mondeo 2 litre lump, being put in a lot of 7 style kits these days due to high power, reliability and lightweight, don't look at the Ford name and think they are rubbish, they'll do 200bhp on stock internals and are lighter than an old xflow.
Subaru boxers? Relatively light per bhp, and comes with a wide array of (LSD) boxes.
Alternatively: Alfa boxers. Look much nicer, yet seem to be heavier.
Last Edit: May 26, 2009 8:21:20 GMT by mkickert
gazwad
I'd also say k series, get a complete mgtf rear set-up with subframe, hubs, brakes, suspension etc then bolt the lot in as one unit (4 mounts). you can use the cable gearchange, exhaust system and even the ecu system is easy to wire up. the vvc is a great engine 200bhp + is easily achievable n/a, i'm running around 170-180bhp with just a ported head, 421 manifold and better airfilter all on the standard mgf ecu! it still has the highest bhp to kg ratio for car engines and the vvc has great torque from idle to 7.5k rpm +
berendd
1600 16v tritec engine?
mini cooper, dodge/chrysler Neon and PT cruizer?
The one that immediately sprang to mind was those Yamaha-built Ford Zetec SE engines.
The Doctor
Club RR Member Number: 48
May 26, 2009 10:07:58 GMT
150 bhp will be hard to reach, but a Suzuki Swift GTi engine is VERY light. I don't know what they weigh exactly, but I do know that the engine + a RWD box from a Suzuki Samurai/SJ413 weighs 90 kg in total! some googling gave me this: //edit: got to learn to read... you don't want a Swift GTi engine...
Last Edit: May 26, 2009 10:09:14 GMT by The Doctor
May 26, 2009 11:22:16 GMT
Great responses, thanks a lot folks. Rich - thanks for the useful info. on the K-series. I'll sock it to my VW friend who likes muttering about their head gaskets everytime I say " Lotus Elise" to him. Shedspeed - I would never have thought of a GSA engine! Sounds interesting but I doubt I'd find one easily and I found this: Citroën A-Type Tuning * 100bhp is maximum useable power for normally aspirated 4 cylinder Citroën boxer engines * higly tuned engines have a greatly reduced life expectation * tuning is VERY expensive ... I'd like to have potential for a bit more reliable bhp Mystery Machine - "4A-GE 1.6 engine & box from an MR2 Mk1" I'd thought of an MR-2 set-up. Seems like an wise and obvious choice. D you know what puts me off a little? It's the fact that it is obvious / predictable. Apart from that it sounds like a goer. I'll not shut down any options at this early stage, though, especially not a sensible one like this. Kee - I wouldn't have thought of Ford and didn't know anything about their modern engines ... which is exactly why I needed to start this thread. The 1.7 Puma and Fiesta engine is part of the family, yes? Which is the best one to go for if I'm looking for an easy 150+bhp? One point seven? popuptoaster - That'll be the Duratec, yes? Any idea if these weigh much more that the Sigma mentioned by Kee? gazwad - Aside from the MR-2, the MGF running gear sounds like the other obvious choice. You're a good salesman ... "it still has the highest bhp to kg ratio for car engines". That's exactly the sort of statistic I like to hear! ;D berendd - Tritec (new MINI) engine ... again something that I know nothing of. I'll read up.
May 26, 2009 11:23:22 GMT
//edit: got to learn to read... you don't want a Swift GTi engine... No ... it's not that I don't want one, I just thought it might be easier to go with something else to achieve say, 150bhp without turbo. Maybe I'll get power hungry and want 180-200bhp in future. ;D 90kg for Swift GTi engine and Samurai gearbox sounds excellent. Is there anything much to rival this weight-wise? What about the engine in the new model Suzuki Swift? There is a Swift Sport 1.6 VVT which puts out 123bhp. Is this a relative of the engine in the previous model and if so is it anywhere near as light?
May 26, 2009 11:34:47 GMT
Is there anything French, modern, normally aspirated, rather sweet and crucially lightweight that I should consider?
If there was a website which gave some data on engine weights and dimensions it would be handy.
Honda V-Tec (again everyone loves 'em) ... lightweight or ...?
Alfa boxer engines 1.7 from the Alfasud Sprint for instance, are these fairly light?
Something French or Italian would be my ideal choice but I'm not shutting down any options.
Don't thing I can do turbo because limited space will cause cooling issues ... what about a supercharger? I've never had one ... best avoided for the same reasons or ...?
kee
May 26, 2009 11:37:34 GMT
the best sigma engine to choose is the 1.6 as the 1.7 comes with VVT. the 1.7 is the same engine yes. although they only come with 100bhp standard, the exhaust and inlet is very restrictive, although it isn't too cheap to tune though. www.shawspeed.com/these tune both the 1.6 sigma and the 2.0 duratec. the duratec is heavier than the sigma but still about 30/40kg lighter than the original zetec. look towards sbd for duratec tuning. www.sbdev.co.uk/Main.htmwhat project is the engine going in?
kee
May 26, 2009 11:39:03 GMT
honda vtecs arent light, block is iron.
i think the peugot Mi16 engine is alloy and can get pretty good power from them. the 205 boys have claimed most though for conversions.
kee
May 26, 2009 11:43:23 GMT
May 26, 2009 11:52:46 GMT
Honda V-Tec (again everyone loves 'em) ... lightweight or ...? Not that lightweight. Something like the K20 out of the Civic Type-R comes in at about 160kg, without gearbox. However, they are 200-odd bhp out of the box and have the potential to do much more if you could find space for a turbo or supercharger (cf. Z-cars Mini, Ariel Atom) Have a look here for a bit of comparison on weights and powers. It's off Austin Rover Online, so there is a slight K-series bias As for superchargers, have a look at CR500Dom's Kadett running a supercharged Zetec-SE. I'm not suggesting just nick his idea, but... Well, I might be suggesting that. Does seem like a pretty good idea...
May 26, 2009 12:14:15 GMT
Thanks for the info., Key, I'll check those links. what project is the engine going in? I should have said. Thing is they're quite scarce and it's not everyone who might approve of a transplant. It's a Matra-Simca Bagheera (series 2) and like most it needs a bit of welding and a full rebuild. This is why something French would appeal, engine-wise, since it's a French car. Or a Fiat or Alfa engine might seem more appropriate than something Japanese ... however your Ford suggestions make sense AND racing Matras often had Ford power! The engine in my car (and all series 2's) is the 1442cc Simca/ Chrysler Alpine unit complete with 4-speed gearbox. They're tuned to 90bhp in the Bagheera and I'm not sure how easy, affordable or practical it would be to get more than about 20 or 30 more horses out of them. I know that someone has transplanted an Alfa V6 into one but I'd like something that would keep the car closer to it's kerb weight of 1000kg or even better, reduce it. These clickable thumbnails will give an idea of the size of the engine bay (reasonable boot behind it):
Seth
May 26, 2009 12:18:42 GMT
4A-GE 1.6 engine & box from an MR2 Mk1 Plenty out there, cheap to buy, uber reliable, easy to tune, rev like mad...real little screamers - and the best bit is they are already set-up for a mid-engine. Some details about the engine here: en.wikipedia.org/wiki/3AC#4A-GE_.2816-valve.29Sorry for jumping in on this thread but is there an easily available (ie cheap!) RWD gearbox that goes on these engines?
