Sept 27, 2005 12:05:09 GMT
Did you know….. that Alfa 166 door mirrors are fitted to Maserati Quattroporte V8 Evo's. so they can be bought in an emergency from Maserati dealers countrywide. Make sure you don't tear the Maserati wrapping bag though - it just cost you an extra £203
Exterior door handles on a Ferrari Mondial are the same as on a S3/4 Alfa Spider ........... no doubt once again a huge cost difference
The headlamps on the Italian built MG SV-R are from a Mk II Fiat Punto
Alfa SZ headlights used on the Lancia Hyena
Morris Marina door handles on the Mk1 Land rover Discovery.....yuk
Oh, and the starter switch on Anakin Skywalker's 'Pod Racer' in Star Wars Episode 1, is a headlamp switch from a Mk1 Fiat Punto
I'm sad, I know.......before anyone points this out ;D
71 Alfa GT 1300 Junior 89 Alfa 75 3.0 V6 Veloce 89 Alfa 75 3.0 V6 America 2015 C220 estate Daily shunter
Sept 27, 2005 12:09:30 GMT
Maestro van rear lights on the Disco'?
Mazda 323F (89-94) rear lights on Aston DB7?
Not 100% on both above.
Sept 27, 2005 12:15:56 GMT
The Pod switches are from a Fiat UNO MK1 Lancia Stratos tail lamps same as Fiat 850
Sept 27, 2005 12:30:32 GMT
Yep Mastro rear lights fit early Discovery's ...Fact! ... I 've done it But ... beware in 1994 they changed style slightly, then in 1995 went back again for one year and...Disco one has 'Land Rover' badge stamped on bottom of lens ;D I could be here all day saying (from experiance) what inter changes on the electrical and trim side between: Austin/Morris/Triumph/Rover/BMC/BL/Leyland/MG/TR/Damilar/Jaguar/Land Rover/Reliant built between the 1950's to about 1980.
Sept 27, 2005 12:38:01 GMT
Marina Door handles are present on the Range Rover too... and a variety of other BL cars... ha ha!
Mazda interior door pulls on Aston DB7 Mondeo Electric Window Switches on DB7
Sherpa Van headlights on Disco 1 (200TDI)
Sept 27, 2005 12:45:23 GMT
Rear lamp unit of Triumph TR4, TR4a and TR5 same as Aston Martin DB6Rear Lamp unit for 60's AC Cobra also fits Jensen 541 and ... older Hillman MinxLH Rear lamp for MK1 Mini fits later MGA as RH Rearlamp and Vica Versa Interior Lamp on Dashboard for MGB (up to 1975) also is same in Rover P5Sidelight/flasher lamp unit unit for Mini Clubman is same as 70's/early 80's Lotus Elite,Eclat and Elite and ...the part is cheaper of Lotus Perhaps we should try and do a 'Parts interchange section' I remember Car Mechanics Magazine in the Early 90's started to do this but got stopped by the SMMT in some way
Sept 27, 2005 12:52:29 GMT
Is it the Noble that has Mondeo rear lights?
Sept 27, 2005 13:15:12 GMT
Fiesta tail lights on TVR Griffith (right model?).
Rover SD1 tail lights on Esprit?
Sept 27, 2005 13:32:40 GMT
Yeah - Mondeo lights on Noble (or noble lights on mondeo?)
Plenty of stuff has got Ford parts such as the XJ220, where most of the interior switches are fiesta-sourced. Even the interior door handles are generic late 80's ford ones. TVR also use a lot of ford bits such as fester back lights, interior bits and bobs, although most of their locks seem to be Vauxhall sourced.
Sticking with the XJ220, the wing mirrors are the same as the Citroen CX. And the late Lotus Esprit. And the McLaren F1.
Scirocco back lights appear on the Aston Martin Vanquish.
Maestro and Golf gearboxes are interchangable.
Sept 27, 2005 13:37:48 GMT
Scirocco back lights appear on the Aston Martin Vanquish. Aston virage? The vanquish does use Renault megane interior door handles though.
Sept 27, 2005 13:39:35 GMT
Corolla ae86 back lights on Lotus Esprit.
RetroMat
Column Shifting!
Sept 27, 2005 15:22:52 GMT
The Griffith uses upsidedown Mk3 Cavalier tail lights. ;D
Toledo headlamps also used on the Allegro
Sept 27, 2005 16:07:17 GMT
I wind my Elise owning mate up about the Corsa indicator/wiper stalks & Pug 205 switches in his car ;D
Sept 27, 2005 16:11:19 GMT
When you realise that these so-called Supercars use parts, however well disguised, from mundane mainstream cars it somehow reduces their appeal somewhat. I remember seeing the same column switches from my old rusty Viva in a Scimitar, after I'd opened the door using a Marina door handle. Same goes for Ferrari, a lot of it comes from Fiat's parts bins. Mark 1 Polo dash switches in the early Porsche 944. It looks like a Mini/Marina/Allegro Lucas wiper motor in TVRs. The list is endless.
Last Edit: Sept 27, 2005 16:57:23 GMT by ScotsDave
sciroccorrado
Scirocco Storm/Corrado Campaign
Sept 27, 2005 16:33:15 GMT
TVR Cerbera (?) Used VW Corrado wing-mirrors, and they are cheaper from TVR... (go figure) The Aston Martin Virage/Vanqusih Scirocco tail lights are upside down on the Aston. Lancia Stratos uses the same door handles as a Fiat X1/9. Door pins from Mk3 Polos are the same fitting, but much better design than those of Mk1/2 Golfs and Sciroccos and Pre-facelift Corrados. They aren't mushroom shaped, so you can't get a coat-hanger around them. Passat Mk4 Rear Handles are a fairly straight swap for Corrado door-handles, but easy way of de-locking them and are much harder wearing. Land Rover headlights are the same as Mini ones... Fiver
www.autoposter.co.ukVW MotorSport Corrado Campaign (Dusty Mauve, Red Leather) | Scirocco Storm (Cosmos Blue, Blue Leather) Passat 20v (Oak Green, black cloth ) | Seat Toledo Mk2 (Green, no longer with Teddy Ronals, but Blue Recaros)
Sept 27, 2005 16:35:37 GMT
austin healy sidelights make good clear lenses for imp indicators
Sept 27, 2005 16:38:36 GMT
The Aston Martin Virage/Vanqusih Scirocco tail lights are upside down on the Aston. No they aren't!!
Sept 27, 2005 16:55:22 GMT
70's tvrs used mk3 tina door handles
60's tvr griffith and vixen used mk1 and mk2 tina rear lights respectively lotus elan sidelight indicators used on mclaren F1
citroen cx mirrors used on maserati bora and merak too i think
a40 farina hatch back light used on bazillions of fx4 taxis
rear light on virage vantage used on mclaren F1 and corvette they some from a truck maker apparently
2001 HONDA CT110 (NOT RCV)
Sept 27, 2005 17:50:58 GMT
How about this for an odd one then koenigsegg and 3rd gen rx7
Last Edit: Sept 27, 2005 17:51:56 GMT by mikelmr
Sept 27, 2005 17:54:05 GMT
P.S Isn't the reason for poaching other cars lights because they are very expensive to get E-marked and the like ? (or more likely the americal equivilent)
