Feb 21, 2009 20:24:20 GMT
hey all, this is my first post so ill try to do it right. here we have my new honda vision 50cc moped. it was a flea-bay bargin of 160 quid and only an hour up the road I couldnt resist. its been in a shed for 8 years and the battery was missing but ive got a new one and all the lights work and it even turns over. it just wont start. anyone got any ideas? anywat enough chatting - pics
Last Edit: Jun 6, 2009 17:52:19 GMT by iang
MrT
Just who did Mr Hitler REALLY think he was kidding?
Feb 21, 2009 21:25:07 GMT
If it's been sat for that long, the first thing you've gotta do is clean all the stale fuel out - it'll be like varnish in the carb.
Feb 21, 2009 21:44:26 GMT
Lounge is a great place, better than the kitchen. More space.
Welcome here.
cheers for the comments guys, ive managed to get all of the pertol out of the tank. I'm just strugling to find how the carb comes off so i can clean it down.
updates soon
bootsy75hst
"scrap the caddy clyde"
Feb 22, 2009 10:20:36 GMT
if i'd have taken a scooter to bits in the front room my lass would do her nut in
"when the going turns weird, the weird turn pro" hst
Feb 22, 2009 16:54:55 GMT
If Id done a scooter in the lounge SWMBO would do MY nuts in!!! ;D ;D
If I had two brains I,d still be a halfwit 1969 Morris Minor Traveller
Feb 22, 2009 17:15:37 GMT
also check the spark plug is not covered in carbon gunk. Take out the spark plug and check if it's wet (fuel is getting in good) or dry (no fuel bad). Once you have fuel in the system, make sure you have spark, lie the connect spark plug again the engine head spin/kick the engine over, you should be awarded with a healthy spark.
Don't know how much mechanical skill you have, but you do realize this thing has to have two stoke oil in it before you start it up?
Feb 22, 2009 17:26:06 GMT
i have 2 stroke oil in it. i have a spark but it aint a bright one. guessing i need a new spark plug.
i stripped the carb down today (in the sink), cleaned it and put it back together, bolted it to the ped dragged it out side and if fired up! wasnt sounding too good but I'm guessing thats the plug at fault.
Feb 22, 2009 20:11:50 GMT
Good! glad it fired up for you.
how bad sounding? check exhaust for the brown cancer, lots of mopeds die there.
Feb 22, 2009 20:25:10 GMT
mmmm 2 stroke pipe full of gunge.... spent months trying to get an express to run right because of that curse...
dungbug
'Ooligan!
Feb 22, 2009 20:31:20 GMT
Nice little Honda, I had an '87 NE 50 (practically the same machine). Great little thing, albeit very slow! Mine was a bit noisey as the exhaust was loose so check that for that, if it has been sitting for a while the exhaust box is probably holed., the box on my daily ped seems to corrode overnight! Also check that the oil is getting through the mix with the fuel, I had a ped a while back and the mechanism which allowed the oil through was seized so that's something worth checking for whilst you've got it in bits. Here's a few pic's of my old one. Parts are easy to get on fleabay for these & if looked after I've found that they outlive the modern cr*p that's available. Nice find fella, hope you get her up & running.
Feb 22, 2009 20:33:06 GMT
Yep, if you've got a lot of carbon & unburnt fuel deposits in the exhaust then it'll really hurt it.
Take off the exhaust pipe and look into the cylinder, you may well find that black/brown goop is resticting the outlet. Clean it out carefully with a butter knife or pallet knife.
Then, pop the whole exhaust pipe onto a BBQ for a couple of hours, really cook the sucker, then after its cooled, bash the now powdered deposits out using a rubber mallet.
Clean that begger right out and it should be able to breathe better
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
1990 Honda Vision 50retrowagen1234
@GUEST
has this one got the vaccum fuel tap? as in it only opens when you kick the engine over? they sometimes get jammed,.... once the tank is cleaned out. chuck some fuel in and take the fuel line off from the tank. suck the vaccum pipe (not fuel pipe) and see if any fuel comes out of the fuel line. (it should) if so then connect it up to the carb. and take the drain plug from the carb base out. suck vaccum again and wait till it pours out of carb (that way you know the carb is allowing fuel in) refit the plug in the bowl. check for a nice fat blue spark (earth the plug against the exhaust manifold or head (if accesible) clip on the ht cap and kick it over with the ignition on. it should be blue. if its orange first stop is change the plug. then regap it. and try again. if its blue. and you have fuel in the carb. it should go if still no luck. remove the carb and clean all the jets (if any ) (ive had some wierd carbs on my old bikes)
dungbug
'Ooligan!
How are you getting on with this Iang?
Feb 25, 2009 11:52:20 GMT
I'm getting on ok cheers, some parts i ordered arrived so its all go go, I'm trying to get it road ready before the end of the month,and then its going matt black, pic update coming soon
dungbug
'Ooligan!
Feb 25, 2009 13:18:00 GMT
Sweet, seems to be moving along nicely.......Looking forward to the photo's. ;D
Feb 25, 2009 16:35:40 GMT
Get porting, polishing, fitting an expansion chamber and re-jetting the carb.
does anyonw know where the vin number is on this moped?
possibly under the footboard or stamped on the headstock
Feb 28, 2009 14:57:46 GMT
IT RUNS!!! but only for a few seconds, i start it up but it runs for about 30 seconds then dies, i then have to drain the carb to be able to start it again, does anyone know why it does this? heres a pic of the screws on the carb how do i adjust it to get it running consistantly? the bottom screw is the drain, the top one i believe is the adjustment for the idle, i have no idea what the middle one is, can any one help me?
