Oct 22, 2012 17:12:17 GMT
Thanks for looking guys, The repairs are not so bad when you look at them one bit at a time, although some have to be done in a sequence. It was only after seeing TonyBMW's postings of his repairs that i got the bottle and inclination to make a start at these rust repairs Go for it !!! Cut the arch off of the old front wing, drew around it onto the rear wing and cut the rusty arch off leaving a 10mm band i will joddle to rest the arch section on before welding Will not fit this yet as it gives more working space to do the repairs to the chassis and get the new wheeltub in and out
deanchad
http://retrorides.proboards.com/thread/131936
Oct 22, 2012 18:06:10 GMT
Super work there mate. Did you have a plan when you started the project or is it developing all the time?. Hats off for the work on the bodywork.
Oct 22, 2012 22:18:02 GMT
Hi Deanchad, my plan is to keep the car as stock as possible but with the new engine and box and cooling system. Also trying to use standard car parts rather than after market parts to keep the authentic look. The body repairs i am doing right now are a necessity as the rust was so bad in the inner arches etc. would have preferred to keep it standard but replacement wheel tubs are a fortune. Tonights progress repair piece to the inner section of chassis Then the outer section mate came round and cleaned some of the doorshut He specialises in making a mess of my garage, but its more progress so i shouldnt complain
Oct 25, 2012 21:55:57 GMT
This bit looked drastic but it come out ok in two bits (thanks to my newest best tool the stretcher / shrinker) rear section front half a bit on the top will try to get the tub in over the weekend
Oct 27, 2012 21:38:52 GMT
This afternoon i have been mostly fitting the nearside wheel tub Trimmed and a lip shrunk stretched to shape front view boot view
Oct 28, 2012 19:24:33 GMT
Shock turret next. Buy a £40 steel turret, offer up, measure and cut away £20 worth Cut corresponding hole in my new tub Slip in place will weld tomorrow
Love seeing more work done on this
Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
Oct 30, 2012 21:56:31 GMT
Love seeing more work done on this Same here, this is a must check thread every time I log in
Had a little weld up will dress the welds tomorrow and fit the rear panel repair section
Ginge
Hi Ginge.
Thanks for the photobucket tip, as you can see the pics are oversize now!
Whats gone wrong ?
This is going to be the nuts once its finished
VWPowered
No-Rice - Est 2002
EPIC STUFF
81 Bedford CF 2.3D Cavalier Coachman Stratus 86 Volkswagen Polo Mk2 1.6 8v 87 Austin Montego 1.6HL 'Daily' 91 Rover Montego 2.0TD Countryman Estate 93 Rover Montego 2.0LXi Estate
ohh, where did the Turrets come from? might be useful for adding an upright damper to my pug.
Welshpug, The turrets came from Peter Lloyd Rallying £80 incl. Contractman & VWpowered, thnks Todays progress Moved these brace pieces to meet the new tub shape Fitted the lower rear repair panel piece i made and made and fitted this little piece to the lower rear quarter
more nice work thanks, PLR only down the road
Result Welshpug Fitted lowering blocks and wheels then sat on ground to check how the wheel arch looks and the ride height Sits ok with a battery, diff and 6 brake discs in the boot, so this should be the ride height when its trimmed, fueled up, and water in the system , plenty of scope for wider wheels
Nov 10, 2012 10:39:02 GMT
arch welded on wheel well has to come out cleaned up the hole paper template then steel panel, bent in my new stretcher
Last Edit: Nov 10, 2012 12:03:26 GMT by sierra1off
m3240z
Nov 10, 2012 22:36:50 GMT
Just read this build from start to now, makes me feel great that its all worth it and i'm not alone out there, in comparison mines looking easy cant wait for the xmas holidays i'v got 12 days off
Nice dedicated work Alan
