Nov 11, 2012 18:25:27 GMT
Hi Terry, didnt know you were in here, Will try and get down to see your 240 in the flesh this week you looked to have made a fair bit of progress I have been on this a while but other things come along and take priority , its a hobby so it will get done when its done A bit of progress Made new side and bottom for wheelwell
Nov 18, 2012 22:35:22 GMT
Nov 30, 2012 19:10:57 GMT
Because of the closeness of the radiator enclosure i wouldnt be able to remove the spring shackles, so i have to alter the top pivot to a bolt that can be withdrawn through the wheelwell fitted a new cill end section Then started on the major rust around the bootlid opening Then with my shrinker / stretcher
Nov 30, 2012 19:21:05 GMT
Krikey,how do i alter the size of the pictures
Dec 11, 2012 10:31:54 GMT
Ha- I have one of them lights- from screw fix. Bloody brilliant. Took it back to nz with me.
Dec 30, 2012 23:06:59 GMT
Good lights them but sometimes it seems to adversely react with the welding mask and all goes black just when i'm about to start a weld Anyway made a plenum (posh description of a box) over the rad which will seal to the rear panel I was about to weld these side pieces in place with just the lid removable when i noticed that i wouldnt be able to remove the rad in future. Will now make the whole unit removable Cut holes in the rear panel, bent lips inwards on one, still to do the other , these will stiffen the panels and allow fixing points for the two mesh inserts Whats going on with the size of these pics, ?? How can i reduce the size in photobucket anyone
sowen
Club RR Member Number: 24
Good progress There is a setting somewhere in the photobucket upload bit, it's gone really slow on me so I can't find it now . You should be able to go back to each photo and resize them in the edit function aswell.
Thanks sowen, have tried that, but it wont allow me to resize. These last two pics were taken with the camera at a higher resolution so maybee that was the cause all along Grills in rear panel, these will be painted black with the rear panel and the number plate will be fixed over these, but set away from the panel to allow airflow out
v8ian
Al, you could always spray the mesh black and stencil the numbers over it in white??
Great minds think alike Ian.
Plan A was to spray a white or yellow number plate size oblong then fit the old style black raised digits
Plenty of time to think that one out
Is your cortina on together and on the road at the moment ??
lotdave
only one gerry
Nice work Al, cant believe how much much you've done since i last see it! ill have to pop down for a proper butchers
Hi Dave, has the Viva got a MOT yet ?? Tonights progress...... primer Thanks John
Jan 15, 2013 23:41:29 GMT
v8ian
Great minds think alike Ian. Plan A was to spray a white or yellow number plate size oblong then fit the old style black raised digits Plenty of time to think that one out Is your cortina on together and on the road at the moment ?? Hi Al, I had to sell the cortina about 15 months ago due to ill health. I don't know how the car is, but the fella who bought it was doing little bits on it, I do miss it, Ian
Jan 16, 2013 23:38:15 GMT
Engine be gone !!!!!!!!!!!!!!!!!!! Got to drop the gearbox steering and crossmember then replace the inner wing tops
Jan 19, 2013 21:58:25 GMT
paint stripped the inner wings and bulkhead Make it bufty before the primer
Jan 20, 2013 10:27:31 GMT
I have to refit the sump ( waiting for special sealant) as I removed it when in the car to modify to clear the steering rack 6 bolt main caps, should be strong enough,,
Last Edit: Jan 21, 2013 11:35:48 GMT by sierra1off
Jan 22, 2013 20:32:40 GMT
Now to sort out rot in the tops of the wings still more to remove yet
Jan 27, 2013 20:54:03 GMT
Getting engine ready to start up on the stand Most of this cannot be seen when in the car
