Cheers Chops ! Hard gettiing motivated as there are lots of repairs to do like this and some will be easier to do with the car on a spit, but i will need to remove the engine and box and i don't want to do that till ive had it runnung again so i am doing the repairs that are accessible from the top first. First a small hidden section was replaced Then made a piece for the outer chassis section and welded in where i could
Folded this up and welded in here prepared this panel Which allowed me to weld in the wheel tub
hey alan,very nice tubbs you have there, its a good job no one will see all that welding you have done,and i did say to you to keep that garage door closed to stop them seagulls flying in, and you spell sill with a s and not a c cill you nob.
Over axle section was gone too so cut off the reinforcing section, cut out the main chassis, make new plate Weld it tomorrow!
Oct 13, 2012 22:49:12 GMT
The chassis repair welded up OK, still got to make a strong bump stop bracket but will do that when its upside down later. spent today making panels for the o/s boot floor and lower rear wing They would have cost about £300 from Expressed steel panels
Oct 15, 2012 22:38:23 GMT
Rot in the lower rear panel , cut out New bumper pick up plate, New panel section, needs a bit more fettling before i weld it in Fed up with notching and welding to get curves so have ordered a stretcher / shrinker Wheel arch tacked on and wing sanded back and a coat of etch primer On four wheels ready to turn around tomorrow and start the other side wheelarch and floor
Its really coming along now, great to see it on its wheels
Oct 16, 2012 11:33:11 GMT
Thanks Tony, only temporarily on wheels whilst i turn it around to work on the nearside, but it is a bit of a boost to the mojo Anyway why are you posting at 5.33 am ?
Oct 16, 2012 21:04:25 GMT
Oct 17, 2012 22:57:30 GMT
The other side Condition of nearside is same as offside , inner wheeltub badly patched cut out tub and floor
Oct 18, 2012 22:56:31 GMT
Had to remove the end of the inner and outer sill and make a new end section to the outrigger
Oct 19, 2012 13:49:02 GMT
A M A Z I N G !!!!!
Oct 19, 2012 21:53:28 GMT
another piece in the jig saw inner sill
Oct 20, 2012 22:59:51 GMT
first repair today second section then made this to go here
Last Edit: Oct 20, 2012 23:00:38 GMT by sierra1off
Oct 20, 2012 23:05:37 GMT
Looking good
Oct 21, 2012 21:08:18 GMT
Open up this area first section second piece welded in here next piece is around the bolt for the anti tramp ber
Oct 21, 2012 21:11:31 GMT
On a roll now, good job and great progress
Oct 21, 2012 21:18:18 GMT
Fantastic workmanship - something for me to aim for
eurogranada
Oct 22, 2012 11:19:49 GMT
Stunning work you do there!! Bookmarked!
Oct 22, 2012 14:00:07 GMT
I'm very impressed by the quality of work you are putting into this. The only way to go about a resto of something you love: thorough. Gives me something to strive for, although I'm not yet at the level where my repairs look this close to the original metal.
